dual carb gaskets and torque settings |
nditiz1 |
Sep 25 2017, 06:16 AM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I am reading conflicting information. Are you dual carb guys running the phenolic block gasket or the thinner fiber gasket on your intake manifold to head?
Also what are the torque settings for manifolds to head and carbs to manifolds? Thanks, trying to clean up some intake leaks with proper sealing. |
IronHillRestorations |
Sep 25 2017, 06:31 AM
I. I. R. C. Group: Members Posts: 6,793 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Phenolic blocks help reduce heat transfer and fuel boiling in the float bowl.
I've never been good at remembering torque specs so I always double check specs, which in this case would be intake manifold to head, but IIRC 8-12 ft lbs |
Lo-Fi Version | Time is now: 2nd January 2025 - 12:40 PM |
