> Aftermarket tachometer for stock dash hole?
tornik550
post Sep 26 2017, 05:23 PM
Are there any aftermarket tachometers that fit in the stock dash hole?
Keyser Sose
post Sep 26 2017, 05:45 PM
Yes, it's 4.5" or 115mm opening. I have a VDO with a programmable shift light, chosen because the font is similar to stock gauges.
DBCooper
post Sep 26 2017, 05:58 PM
14's in the 13's with ATTITUDE
VDO Comp Eliminator. It comes with a programming tab that's removable. Not exactly a stock look but not bad and it works well. There are other styles if you prefer.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1359386016.1.jpg)
wndsnd
post Sep 26 2017, 06:53 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Or just use the stock teach and drive over the red line. (IMG:style_emoticons/default/smile.gif)
DBCooper
post Sep 26 2017, 06:58 PM
There's a post from a couple of years ago describing how a guy put a modern tach inside a 914 tach housing. I don't know how it turned out long-term but it looked pretty good.
Beebo Kanelle
post Sep 26 2017, 07:13 PM
Check out timothy_nd28 in the member vendors forum
http://www.914world.com/bbs2/index.php?showtopic=217100
timothy_nd28
post Sep 26 2017, 08:30 PM
Sadly the modern tach they sold isn't being sold anymore. It was a good answer, I did over 30 conversions with great results.
GregAmy
post Sep 27 2017, 06:27 AM
QUOTE(DBCooper @ Sep 26 2017, 07:58 PM) *
Why am I not able to find this at a retailer? Is it still being sold? Any idea what the VDO part number is?
Mark Henry
post Sep 27 2017, 10:34 AM
that's what I do!
Autometer monster fits, a hair loose, but 3 small blobs of RTV sticks it in good.
You lose the high beam and turn indicators.
DBCooper
post Sep 29 2017, 03:39 PM
QUOTE(GregAmy @ Sep 27 2017, 05:27 AM) *
Huh, I don't see it. Sorry, that was from ten years ago and VDO has apparently moved on. There are other options though, just look for 115mm/4.5" tachs with a switch for number of cylinders. And an LED shift light option is really handy, it's bright enough that you don't need to be looking at it to see it come on.
- Lo-Fi Version Time is now: 26th December 2024 - 04:11 AM
