> twin carb vac take off
JFG
post Sep 28 2017, 08:29 AM
I have twin weber 40idfs to fit and an 034 svda distributor for ignition. When i set my float heights last night i found the vac advance ports on the carbs have a blanking screw instead of a take off tube.
I can't remember my last twin carb air cooled set up so was wondering do i need to take off both carbs or will one work properly?
What have you done with your same carb/dizzy set up?
nditiz1
post Sep 28 2017, 11:30 AM
QUOTE(JFG @ Sep 28 2017, 06:29 AM) *
Use the vacuum port on cyc barrel #4. It is located here in green:
Also, recommended is an anti pulse valve. It smooths the vac adv. They can be purchased from Aircooled.net. The Bob Tomlison Weber book talks about it.
JFG
post Sep 28 2017, 01:28 PM
Thanks for that. I was looking at the 2 small screws in red thinking they were my take offs!
Double checked and mine have the take offs circled in green, they have a blank screw and i misread the exploded view diagram at first.
porschetub
post Sep 28 2017, 01:29 PM
QUOTE(nditiz1 @ Sep 29 2017, 06:30 AM) *
Dellorto's only have one port if the were used on Alfa's and the factory fitted the valve you speak of, not sure if the Webers ever had provision for that area in the casting to be drilled ,this can be done on the Dellorto's however.
I researched this on a UK bus website and to be honest I didn't know of this and always thought you could run off one vacuum point,ran single throat ICT's on my buggy with one pickup and it ran fine.
r_towle
post Sep 28 2017, 03:07 PM
Custom Member
If you merge the two carbs with a t-fitting before the distributor you can eliminate some if not most of the pulsing.
IronHillRestorations
post Sep 28 2017, 04:50 PM
I. I. R. C.
I ran both to a T and also added an anti-pulse valve that aircooled.net sells
nditiz1
post Sep 28 2017, 05:16 PM
I originally had just a T. John from ACN told me to only use the one side and also to get the anti pulse.
porschetub
post Sep 28 2017, 06:16 PM
No personal experience but research indicated port vacuum of 2 carbs sorts it if you can do it,the Webers appear to be changed castings over the years so maybe that's an option.
Who knows there a lot (IMG:style_emoticons/default/stromberg.gif) on the net any way.
- Lo-Fi Version Time is now: 26th December 2024 - 02:46 PM
