| 914Sixer |
Sep 28 2017, 10:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,609 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I am looking at a Quick Jack 3500. It says it has 20.5" height with large lift blocks installed. Is that going to be enough room to install fuel injection engine with out air cleaner? Any experience with this?
| URY914 |
Sep 28 2017, 07:04 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 135,407 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Kinda depends on how high you jack up the car.
| iankarr |
Sep 28 2017, 10:35 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,612 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I've had the 2015 5000 model quick jack for the past few years and have done several engine drops with it. Works great. The only potential issue is that the angle of the lift frame can make it difficult to get a wrench on the engine bar bolts. This may be less of a thing with the newer models. But even if not, it just means you have to push the lift a little further forward and/or make a few extra turns of the wrench.
I like the QJ so much I'm going to buy the new 5000 SLX so I can also lift my Cayman. The 2015 model doesn't have a wide enough spread. If I were you, I'd go for the 5000...not the 3500. You'll find yourself wanting to use it on other cars and the 5,000 is more versatile. Plus you get an extra inch of lift for only a few hundred bucks more. And wouldn't we all like to buy an inch for 200 (IMG:style_emoticons/default/wink.gif). PS Definitely buy the engine jack plate from Tangerine. It makes dropping and reinstalling the engine a one man job. Once you try it, you'll never use a dolly or anything else. Also much safer since the plate is engineered to keep the engine/trans balanced as you drop it. |
| Elliot Cannon |
Sep 28 2017, 11:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Spend a few more bucks (if you can) and get a mid rise lift. You'll thank me later. (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 15th November 2026 - 07:25 PM |
