> Anyone know what size the the hose is?
shelby/914
post Sep 28 2017, 02:41 PM
From the fuel filler neck to the expansion tank on a '73. Local NAPA had 1/8 (too small) and 3/16 (seemed a little loose). Since it's not under pressure the 3/16 might not leak but I would order the correct metric size from Pelican if anyone knows what it is. I have researched the limited books I have and didn't find any referances.
Thanks
Dan
arne
post Sep 28 2017, 02:45 PM
Serial Rescuer of old vehicles...
1/8” is just over 3mm, 3/16” is about 4.5mm, so must be 4mm.
r_towle
post Sep 28 2017, 02:55 PM
Custom Member
Use a heat gun and a sharp pencil to expand the 1/8 to fit.
IronHillRestorations
post Sep 28 2017, 03:01 PM
I. I. R. C.
A tapered punch and ATF
post Sep 28 2017, 03:05 PM
Resident German
Ductape
Rand
post Sep 28 2017, 03:13 PM
Cross Member
Plus a little bailing wire retainer.
shelby/914
post Sep 28 2017, 03:36 PM
Thanks guys, was just trying to avoid walking down to the barn to get the bailing wire. Will try the ATF, might do the trick.
Dan
Rand
post Sep 28 2017, 04:11 PM
Cross Member
QUOTE(shelby/914 @ Sep 28 2017, 02:36 PM) *
Dan
Good call. Generally advised to not use duct tape and bailing wire on the same job.
- Lo-Fi Version Time is now: 26th December 2024 - 03:27 PM
