> Carbs pop sometimes
PanelBilly
post Sep 30 2017, 10:47 AM
I'll be driving along at a steady pace and I'll hear a pop. Any idea what's going on?
Running a 3.0 with PMOs
rhodyguy
post Sep 30 2017, 11:15 AM
Sound from where? Tail pipe or burping back thru a carb?
PanelBilly
post Sep 30 2017, 12:14 PM
Carbs. Might be a backfire. Not very loud.
rhodyguy
post Sep 30 2017, 12:27 PM
Take the filters off and see if you can get one of the venturi to sneeze. Does it happen at the same rpm consistently?
PanelBilly
post Sep 30 2017, 01:01 PM
I'll need to check. What do you mean "sneeze"?
GeorgeRud
post Sep 30 2017, 02:53 PM
Usually you start looking if the timing is too advanced or the engine is running lean. However, that will usually cause a fairly constant backfire through the carb, not just an occasional one.
IronHillRestorations
post Sep 30 2017, 03:35 PM
I. I. R. C.
Pull the idle jets and soak them in carb cleaner.
- Lo-Fi Version Time is now: 13th March 2025 - 01:24 PM
