Rear wheel noise ?, Bearing or CV ? |
jim_hoyland |
Oct 4 2017, 05:54 PM
Get that VIN ? Group: Members Posts: 9,559 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m hear a sound from the rear at 50+ mph, esp on flat but not newly asphalted roads.
I’m trying to decide whether it’s the rear wheel bearing or the CV Any tips on how to pinpoint the problem ? Can the source be I pointed by running the car on a lift ? |
Steve |
Oct 4 2017, 06:00 PM
914 Guru Group: Members Posts: 5,765 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Find a parking lot where you can do slow doughnuts in both directions. If it's a CV you will typically hear and feel a clunk as it binds.
A bearing typically just squeals. |
914Sixer |
Oct 4 2017, 06:11 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Jack the rear end up and support it. See if anything makes noise by just turning the wheels. Go from there.
iankarr |
Oct 4 2017, 06:59 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Find a parking lot where you can do slow doughnuts in both directions. If it's a CV you will typically hear and feel a clunk as it binds. A bearing typically just squeals. (IMG:style_emoticons/default/agree.gif) |
cary |
Oct 4 2017, 07:09 PM
Jim my car is sitting under Matt's on the lift waiting for a new right wheel bearing.
CV's go clunk. Wheel bearings are more of a drown noise. Because of the size/width of the rear bearings they really don't change sounds when you turn. When I lifted the car and turned the wheel it just felt kind of rough. |
jim_hoyland |
Oct 4 2017, 07:25 PM
Jim my car is sitting under Matt's on the lift waiting for a new right wheel bearing. CV's go clunk. Wheel bearings are more of a drown noise. Because of the size/width of the rear bearings they really don't change sounds when you turn. When I lifted the car and turned the wheel it just felt kind of rough. Thanks, drone noise is closer to the sound I hear. Ca that Bearing be replaced without pulling the trailing arm? |
914_teener |
Oct 4 2017, 09:17 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Jim,
Not easily. Mine was groaning for quite a while before I replaced it. You should be able to get it up to about 50 and take it out of gear and listen with the windows rolled down to isolate it. |
cary |
Oct 4 2017, 09:36 PM
We're going to give it a shot. I have the late model 911 tool.
We'll if I can use some of my other bearing tools to create the pull and push I need. I too don't want to pull my trailing arms. |
914_teener |
Oct 4 2017, 09:42 PM
We're going to give it a shot. I have the late model 911 tool. We'll if I can use some of my other bearing tools to create the pull and push I need. I too don't want to pull my trailing arms. I.d drop the arm Cary.... But I don.t have Superinlaw or the toys you have. Let us know how that works out. |
Krieger |
Oct 4 2017, 10:07 PM
Advanced Member Group: Members Posts: 4,769 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I've never heard wheel bearings squeal. They make a lower droning/growling sound. A parking lot may not be fast enough to detect. On the highway at 30+ mph gently use the steering wheel to rock the car left and right to load each side of the car. If it growls when you steer left its the right side and vice versa. Could also be your gearbox.
rjames |
Oct 4 2017, 10:29 PM
I'm made of metal Group: Members Posts: 4,158 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I've never heard wheel bearings squeal. They make a lower droning/growling sound. A parking lot may not be fast enough to detect. On the highway at 30+ mph gently use the steering wheel to rock the car left and right to load each side of the car. If it growls when you steer left its the right side and vice versa. Could also be your gearbox. Shift into neutral when you hear the noise. If it disappears it's your transmission. I bet it's the wheel bearing though. If it disappears when you turn one way or another, then it's very likely the bearing. And yes, you can change them without removing the trailing arm. I made a tool using an allthreaded rod and a bunch of big washers/bolts to press out the bearing. I replaced both bearings for continuity sake. Removing the first one was a huge PITA, but after figuring it out, the second one was easy. |
porschetub |
Oct 4 2017, 10:39 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I've never heard wheel bearings squeal. They make a lower droning/growling sound. A parking lot may not be fast enough to detect. On the highway at 30+ mph gently use the steering wheel to rock the car left and right to load each side of the car. If it growls when you steer left its the right side and vice versa. Could also be your gearbox. My RH side on is (IMG:style_emoticons/default/stromberg.gif) ,the sound you get isn't anything like a CV,its a speed related rumble...fairly loud too (IMG:style_emoticons/default/rolleyes.gif) . |
PatrickB |
Oct 5 2017, 03:51 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Jim my car is sitting under Matt's on the lift waiting for a new right wheel bearing. CV's go clunk. Wheel bearings are more of a drown noise. Because of the size/width of the rear bearings they really don't change sounds when you turn. When I lifted the car and turned the wheel it just felt kind of rough. Thanks, drone noise is closer to the sound I hear. Ca that Bearing be replaced without pulling the trailing arm? Yes. Just did two two them. Biggest problem is getting the axle out. Not enough room. Pulled the hub them the bearing with a slide hammer, pulled the new bearing and the hub back in one at a time with a big threaded rod and washers we made the right size. |
76-914 |
Oct 5 2017, 07:57 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim my car is sitting under Matt's on the lift waiting for a new right wheel bearing. CV's go clunk. Wheel bearings are more of a drown noise. Because of the size/width of the rear bearings they really don't change sounds when you turn. When I lifted the car and turned the wheel it just felt kind of rough. Thanks, drone noise is closer to the sound I hear. Ca that Bearing be replaced without pulling the trailing arm? You probably don't remember selling me that tool that removes the bearing. (IMG:style_emoticons/default/lol-2.gif) Just a piece of all thread rod with some nuts and a plate, IIRC. I think I sold it at an old G&R after I purchased a press. |
914_teener |
Oct 5 2017, 08:20 AM
Jim my car is sitting under Matt's on the lift waiting for a new right wheel bearing. CV's go clunk. Wheel bearings are more of a drown noise. Because of the size/width of the rear bearings they really don't change sounds when you turn. When I lifted the car and turned the wheel it just felt kind of rough. Thanks, drone noise is closer to the sound I hear. Ca that Bearing be replaced without pulling the trailing arm? You probably don't remember selling me that tool that removes the bearing. (IMG:style_emoticons/default/lol-2.gif) Just a piece of all thread rod with some nuts and a plate, IIRC. I think I sold it at an old G&R after I purchased a press. (IMG:style_emoticons/default/av-943.gif) |
jim_hoyland |
Oct 5 2017, 04:31 PM
Jim my car is sitting under Matt's on the lift waiting for a new right wheel bearing. CV's go clunk. Wheel bearings are more of a drown noise. Because of the size/width of the rear bearings they really don't change sounds when you turn. When I lifted the car and turned the wheel it just felt kind of rough. Thanks, drone noise is closer to the sound I hear. Ca that Bearing be replaced without pulling the trailing arm? You probably don't remember selling me that tool that removes the bearing. (IMG:style_emoticons/default/lol-2.gif) Just a piece of all thread rod with some nuts and a plate, IIRC. I think I sold it at an old G&R after I purchased a press. Yup; when I installed new trailing arms the bearings were replace, probably 10+ years ago. |
Lo-Fi Version | Time is now: 26th December 2024 - 06:56 PM |
