Games with Stub Axles, (insert grumbling here) |
Verruckt |
May 22 2005, 05:45 PM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
Make him take you to Aggyville... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
SLITS |
If ya dig yer red sparkly shoes outta the closet, put 'em on, click the heels together 3 times and ****poof****. Ya gotta take Toto with ya too! |
skline |
May 22 2005, 05:46 PM
Well, I would love to come back and see my old Alma mater but I have to go to work at the port tomorrow and hopefully get 1840 hours as quick as possible. When I said use a puller, find a large 3 or 4 claw that will fit over the hub. Then push on the middle like you are removing the hub. The hub wont come out but the stub axle will push in. You can probably rent one from a local FLAPS. I have one here and it worked great for me. When you go to put it in is where it will get tricky. With any luck, you wont have to replace your wheel bearings. It can be done, I have done it a few times.
Eric_Shea |
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Let me know of you need a new stub axle. I can have one there in two days for $7.70 (flat rate box).
Eric_Shea |
May 22 2005, 05:49 PM
Is that where they grow "Eggplants" errrrrr Aubergines? |
hmeeder |
May 22 2005, 06:06 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
Stubs, hubs, schlubs.
I meant to say hubs, but on my keyboard the 'st' key is right next to the 'h'. Thanks for the good eye Eric. And you are of course right about hammering the bearing, though I think I meant the light 'tappity, tappity' style. I also like your tip about using the old bearing as a drift. That never occured to me. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
black73 |
May 22 2005, 07:05 PM
Senior Member Group: Members Posts: 517 Joined: 23-March 05 From: Nashville,TN Member No.: 3,801 Region Association: South East States |
I took the easy way out when replacing my rear bearings. I dropped the trailing arms and had Perry Kiehl fix me up a set with bearings, hubs and bushings already assembled. That was after I had wasted a stub axle and nut and decided I was in over my head.
ClayPerrine |
May 22 2005, 07:30 PM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
BTDT..... Colder than $hit in January, but Rusty is a good cook. (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) If you need a stub, I can send it next day air. I also have the special tool to pull and reinstall the bearings i can send too.... If you have a press at the base shop, just pull the trailing arm and take it to the press. A little hydraulic pressure will have that stub axle out in no time. |
Rusty |
May 22 2005, 07:59 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
I'm really dragging my feet about pulling the entire trailing arm.
The car rides pretty nice, and I don't trust the monkeys in BFK to do a decent alignment. Besides... ever snap one of the trailing arm mounting bolts? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
Rusty |
May 28 2005, 04:26 PM
I got the stub axle out! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
It took one whack with a 5 pound hammer to knock it loose. Maybe it was all the soaking with PB Blaster, too. Now that I have it out, I see that there was a bit of rust holding it in place. What I don't see, however, is how my bearings can be f'd up. It's like those little wooden Chinese dolls (no, not you, Jenny... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ) My visualization of the assembly is... Bearing inside trailing arm. Hub snugly inside bearing. Stub axle inside hub. Rapping on the stub axle shouldn't have caused the bearing assembly to move. Or is this just one of those things I won't understand and should just take on faith? -Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
Verruckt |
May 28 2005, 04:45 PM
No, that's where there is an abundance of intoxicated college age women... (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
RustyWa |
May 28 2005, 05:46 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Take our word for it. It's trash. Get a new one from www.europeanautomotive.com, something like $43 shipped to your door in two days.
SLITS |
May 28 2005, 08:03 PM
Rusty....stick your hand in there and rotate the bearing....if it feels rough at all, replace it. You can also look with a light and see if the seal is disturbed. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
ClayPerrine |
May 29 2005, 09:18 AM
The rear bearing on a 914 is made with 2 roller surfaces. Inside it has a split inner race. When the drive flange fits inside of it, the stub axle presses against the inboard half of the inner race. When you pull the stub axle, you probably disloged the inner race. That would cause the bearing to become loose. The only way to make sure that you don't have a bearing failure in a very short period is to replace the bearing.
Get a big assed slide hammer (O'Reilley here will loan you one. You just have to have a credit card for the security deposit) and use it to pull the hub. Most likely there will be half of the inner race left on it. You may have to have that pressed off. Then pull the bearing retainer plate and use the slide hammer and a big thick washer to pull the bearing. Or you can crawl under and hammer it out with a big punch. Then put the bearing back into the trailing arm (freezing it overnight will shrink it and help to make it easier to install). Bolt the retaining plate back on. Use the big assed washer and a long bolt to pull the hub into the bearing. MAKE SURE THAT YOU SUPPORT THE INBOARD END OF THE BEARING WHEN PULLING THE DRIVE FLANGE INTO THE OUTBOARD END OF IT. Sorry to shout, but I didn't want you to miss that. The bearing will be ruined if you dont support it. What I have is a couple of big thick washers and a picece of an old ball screw from a milling machine (A ball screw is precision machined tool steel piece of all thread). Two mounting nuts from a milling machine retaining bolt package make the rest of it. Order of parts from inboard to outboard, all hooked over the ball screw. Big nut --Big washer --- Bearing -- hub -- big washer-- big nut. Tighten the nuts to pull the hub into the bearing. Remove the ball screw and the washers. Put some anti-seize on the splines of the stub axle and install it into the hub. Hope that helps. |
Rusty |
May 29 2005, 10:10 AM
Good news/bad news.
Good news: The axle is in good shape. This morning I pressed off the CV. I cleaned, inspected & repacked them, put new boots on and pressed the CVs back in place. Bad news: I know I bought a set of rear wheel bearings... but I sure as hell seem to have lost them. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I hate it when I lose perfectly good parts. I'll tear apart the garage one more time to see if they haven't grown legs or something. More later. |
Rusty |
May 29 2005, 05:40 PM
Good news! I've now got my wheel bearings... let's just say they were in a garage in Des Moines, Iowa. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Pam |
May 29 2005, 06:47 PM
Unnumbered Lady of 914s Group: Benefactors Posts: 113 Joined: 30-May 03 From: Des Moines, Iowa Member No.: 756 |
Oh no...let's say more. Let's say how wonderful your toolwench is for driving six hours round trip to bring you your wheel bearings after allowing you to store them in her garage for years....
On the bright side - there were lots of yellow flags in the NASCAR race so I'm home in plenty of time to watch the finish. -Pam |
redshift |
May 29 2005, 06:54 PM
Hey Pammy!
M |
Lo-Fi Version | Time is now: 26th December 2024 - 01:37 PM |
