> Transmission Mounts, Are 911 mounts the same as 914?
mmascari
post Oct 6 2017, 06:37 PM
Can someone tell me if the transmission mounts for the 911 are the same used for the 914? My local shop has some 911 in stock but I need them tomorrow.
Replies(1 - 7)
ClayPerrine
post Oct 6 2017, 07:03 PM
QUOTE(mmascari @ Oct 6 2017, 07:37 PM) *
Yes, the 911 mounts are the same as the transmission mounts on a side shifter 914, and both the transmission and engine mounts on a tail shifter 914.
mmascari
post Oct 6 2017, 08:57 PM
QUOTE(ClayPerrine @ Oct 6 2017, 06:03 PM) *
Thank you!
GeorgeRud
post Oct 6 2017, 09:52 PM
Actually, there are slight differences (even between 914-4 and 914-6) in the mounts, but they’ll work fine.
post Oct 7 2017, 09:47 AM
Resident German
QUOTE(GeorgeRud @ Oct 6 2017, 08:52 PM) *
I use the 911 sport engine mounts as transmission mounts for my sideshifter and you may have to take a dremel to the mounting holes to make them fit perfectly but other than that they work very well.
(IMG:style_emoticons/default/smash.gif)
ndfrigi
post Oct 7 2017, 10:20 AM
installed it on my previous 75 1.8.
arne
post Oct 7 2017, 10:21 AM
Serial Rescuer of old vehicles...
This was good and timely info, thanks to all. I had replaced the front mounts in my '73 when I had the engine dropped, but didn't do the rears. Ive felt that the drivetrain still has a fair amount of rock on throttle changes, figured I should do the rear as well.
Years back, shortly after I bought the 911, I put 4 sport mounts in it. I discovered then that the mounts I took out were also sport mounts and were quite fresh. So I have spare 911 sport mounts on the shelf. I think a pair of them will go in the 914 this weekend.
mmascari
post Oct 7 2017, 11:55 AM
Cool thanks for all the info. See how it works out later today.
- Lo-Fi Version Time is now: 26th December 2024 - 11:37 AM
