Prying open heat exchangers..., ... and crimping them closed again |
DaveO90s4 |
Oct 16 2017, 11:50 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all,
It looks like the top section and the bottom section of OEM heat exchanges are simply crimped at the seams. Does anyone know if it is feasible to un-crimp them, take them apart and later on re-crimp them? If so, then I'll have a go at using the spare set of heat exchangers I have (with some modifications) for the heat exchangers on my to-be-built exhaust for my 2.8L Corvair transplant. Thanks all, Dave Oz |
80cap |
Oct 17 2017, 05:24 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
That is what I did. I took some patience but it turned out ok. I had the pipes ceramic coated and sprayed the tins with heat paint.
Brian |
bdstone914 |
Oct 17 2017, 07:53 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi all, It looks like the top section and the bottom section of OEM heat exchanges are simply crimped at the seams. Does anyone know if it is feasible to un-crimp them, take them apart and later on re-crimp them? If so, then I'll have a go at using the spare set of heat exchangers I have (with some modifications) for the heat exchangers on my to-be-built exhaust for my 2.8L Corvair transplant. Thanks all, Dave Oz So how do you adapt 4 cylinder heat exchangers to a 6 cylinder Corvair engine ? (IMG:style_emoticons/default/blink.gif) |
worn |
Oct 17 2017, 08:22 AM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi all, It looks like the top section and the bottom section of OEM heat exchanges are simply crimped at the seams. Does anyone know if it is feasible to un-crimp them, take them apart and later on re-crimp them? If so, then I'll have a go at using the spare set of heat exchangers I have (with some modifications) for the heat exchangers on my to-be-built exhaust for my 2.8L Corvair transplant. Thanks all, Dave Oz Worked for me. They are spot welded in places - it is a pita job, but it works. |
DaveO90s4 |
Oct 17 2017, 02:32 PM
(IMG:style_emoticons/default/blink.gif) [/quote] Thanks all for the confirmation that it is doable. Envisage the RH heat exchanger and exhaust intact. The cold air inlet part runs inboard front to back, then does a U turn at the back to wrap around the exhaust and runs forward to the heater flapper unit. I will open it up into two complete halves, top and bottom. I will use one half as a guide to bending the new exhaust so it will fit back inside the heat exchanger once recrimped. I will remove most of the inboard parallel cold air inlet section in the immediate vicinity of the engine - it would be in the way of each exhaust tube from the heads The top half and bottom half will each have three half round holes in the correct position to line up with the three exhaust tubes (these are J tubes and will run horizontally into heat echanger) The shortened cold air inlet section will have an end to receive cold air - a longer concertina cold air hose will run from engine bay heater fan and down through the new engine tinware I've already made to feed cold air to this point of the heat exchanger, Trial fit, finesse and once all is good recrimp the top and bottom two halves together with new exhaust in situ. Repeat for LH side. Assuming I plan it properly and execute it carefully I can't see why it wouldn't work - now that I know it is feasible to uncrimp and recrimp the two halves. Cheers Dave |
mb911 |
Oct 17 2017, 03:25 PM
914 Guru Group: Members Posts: 6,812 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Can't wait to see this unfold (IMG:style_emoticons/default/biggrin.gif)
DaveO90s4 |
Oct 17 2017, 07:52 PM
Good pun. My cunning plan may work. It may not. But nothing to lose by giving it a go. Can't legally register a car here where I live if the windscreen demisters don't work, so short of installing a 12v heater / hair dryer I've got to have heat exchangers. Can't think of a cheaper more pragmatic way than to try to modify a spare set I already have. |
mb911 |
Oct 17 2017, 07:58 PM
I completely get it.. Check out my heat exchanger design thread..anything is possible.
malcolm2 |
Oct 17 2017, 08:09 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Govm'nt meddling again....
I wonder if you could get the fresh air fan to work well enough to pass the test. How do they check for that anyway? Why do you want to take them apart? are there holes? You could wrap it with that stuff "as seen on TV" They make a high temp version. Can't remember the damn name tho. You dip the roll in water and wrap whatever you want to wrap and it cures hard as a brick. I used some on my HE. 40000 miles and it is still wrapped enough to blow super hot air. Good Luck. |
DaveO90s4 |
Oct 17 2017, 10:07 PM
Govm'nt meddling again.... I wonder if you could get the fresh air fan to work well enough to pass the test. How do they check for that anyway? Why do you want to take them apart? are there holes? You could wrap it with that stuff "as seen on TV" They make a high temp version. Can't remember the damn name tho. You dip the roll in water and wrap whatever you want to wrap and it cures hard as a brick. I used some on my HE. 40000 miles and it is still wrapped enough to blow super hot air. Good Luck. I have to take them apart to be able to either: 1. Weld 3 inlet tubes from the three exhaust outlets into place on the existing tubing, or 2. As above and add complete new exhaust tubing if the current tubing is beyond further use. Don't think I can do either without 'peeling the banana'. Dave |
porschetub |
Oct 18 2017, 04:42 PM
Govm'nt meddling again.... I wonder if you could get the fresh air fan to work well enough to pass the test. How do they check for that anyway? Why do you want to take them apart? are there holes? You could wrap it with that stuff "as seen on TV" They make a high temp version. Can't remember the damn name tho. You dip the roll in water and wrap whatever you want to wrap and it cures hard as a brick. I used some on my HE. 40000 miles and it is still wrapped enough to blow super hot air. Good Luck. I have to take them apart to be able to either: 1. Weld 3 inlet tubes from the three exhaust outlets into place on the existing tubing, or 2. As above and add complete new exhaust tubing if the current tubing is beyond further use. Don't think I can do either without 'peeling the banana'. Dave I guess it needs to work for you if that's the regulations,hair dryers are useless and draw to much current ...ask me how I know (IMG:style_emoticons/default/dry.gif) . I have deleted my heater control and just have a switch to run the blower on full speed ,demists the screen fine,I proved you don't need warm air,my Audi for instance will demist with the AC on for a short time. I think it would depend on your climate which I would say would be colder than where I live in NZ. |
DaveO90s4 |
Oct 21 2017, 04:56 AM
Progress.
Two photos. One showing heat exchanger opened without damage and other showing 914 exhaust in approximate position to be modified to fit the 6 cyl Corvair engine. Cheers Dave Australia Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 02:49 PM |
