To Short Shift Or Not To Short Shift?, That Is The Question… |
Dr Evil |
Oct 25 2017, 11:43 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
My friend, mentor, and Porsche specialist says they are OK for a street car, but won't put one on a competition car I would support this comment, but most racers with my builds can pitch shift and get away with not clutching because they have that skill (IMG:style_emoticons/default/biggrin.gif) However, I have seen nothing in a regular short shift box, that was not run into the ground after a problem started. to indicated or support concern over use of a short shifter. I have personally driven 3 boxes in my personal cars, very hard, for at least 20K+mi each and have pulled the boxes apart for other reasons and not seen any appreciable, or abnormal wear. |
Lucky9146 |
Oct 25 2017, 11:57 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,663 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
I appreciate all the replies so far and hope more weigh in. I have some time to consider the options but I was looking at installing a 914-6 hand throttle and don't want to have to undo too much depending on decision. I make a hand throttle kit that mounts differently from the 914-6 unit. You wouldn't need to change your shift lever assembly. PM sent on your hand throttle thanks! |
Lucky9146 |
Oct 25 2017, 12:01 PM
My friend, mentor, and Porsche specialist says they are OK for a street car, but won't put one on a competition car I would support this comment, but most racers with my builds can pitch shift and get away with not clutching because they have that skill (IMG:style_emoticons/default/biggrin.gif) However, I have seen nothing in a regular short shift box, that was not run into the ground after a problem started. to indicated or support concern over use of a short shifter. I have personally driven 3 boxes in my personal cars, very hard, for at least 20K+mi each and have pulled the boxes apart for other reasons and not seen any appreciable, or abnormal wear. And this will be a street car! Good info all please keep it coming |
Cracker |
Oct 25 2017, 12:06 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Elliot Cannon |
Oct 25 2017, 12:20 PM
I have had a rennshifter on my car for about 12 years or so. THOMAS then overhauled my transmission and I have all the tangerine goodies installed and it shifts "like buttah". (IMG:style_emoticons/default/biggrin.gif)
Lucky9146 |
Oct 25 2017, 03:54 PM
Quite frankly, that is all you need... Tony nd this will be a street car! Good info all please keep it coming You are right I do have enough! Thanks everybody this has been a lot of help and I learned a lot. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/white914.jpg) |
PeeGreen 914 |
Oct 27 2017, 07:10 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I have had a rennshifter on my car for about 12 years or so. THOMAS then overhauled my transmission and I have all the tangerine goodies installed and it shifts "like buttah". (IMG:style_emoticons/default/biggrin.gif) This is really the only way to go. With as many 914's I have moded the shift linkage on I have found that there is so much you can do, but going cheap is NOT a good idea. The Rennshifter is the starting point. |
daytona |
Oct 28 2017, 06:51 AM
daytona Group: Members Posts: 447 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi guys,
Don't mean to highjack this thread, but I have a question. I am working on a 914-6 con version and have been thinking about installing a WEVO shift kit. Can anyone comment on the differences between wevo Vs.rennshift kit? I had not considered the rennshift until reading this thread. Thanks, Bill. |
Lo-Fi Version | Time is now: 25th November 2024 - 06:52 PM |
