Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,676 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem.
Did some poking around here on the site (IMG:style_emoticons/default/type.gif) where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal. (IMG:style_emoticons/default/idea.gif) Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version? Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out. (IMG:style_emoticons/default/confused24.gif) “Shark Fin” is on the far left. Thanks! (IMG:style_emoticons/default/white914.jpg) ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,767 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
You for a install without welding, you can drill 2 holes in the edge of the throttle arm to the outside section then use 2 bolts and nuts to attach. You can weld it later when you get a chance to remove. Use the holes you have drilled as a template to drill the fin. Do one at a time to make sure they align. You can add washers to get more grip, but will need slightly longer bolts. Lock nuts recommended.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Here's the "shark fin" welded on to the pedal throttle arm.
Clear as mud? (IMG:style_emoticons/default/smile.gif) ![]() And yes....likely easier to take the whole pedal assembly out to do this. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,790 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem. Did some poking around here on the site (IMG:style_emoticons/default/type.gif) where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal. (IMG:style_emoticons/default/idea.gif) Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version? Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out. (IMG:style_emoticons/default/confused24.gif) “Shark Fin” is on the far left. Thanks! (IMG:style_emoticons/default/white914.jpg) ![]() Jim,good description of the shape (IMG:style_emoticons/default/biggrin.gif) ,I mounted this plate with one bolt and moved it once till contact with the rod ,the bolt out and plug welded the hole . Every "6" on carbs should have one of these ,very handy for quick start up,I do 2-3 pumps on the pedal with the lever on full travel,mine starts straight up. |
Lucky9146 |
Here's the "shark fin" welded on to the pedal throttle arm. Clear as mud? (IMG:style_emoticons/default/smile.gif) ![]() And yes....likely easier to take the whole pedal assembly out to do this. Thank you, (IMG:style_emoticons/default/beerchug.gif) thank you (IMG:style_emoticons/default/beerchug.gif) , thank you (IMG:style_emoticons/default/beerchug.gif) ! A picture is worth a thousand words. I would have certainly have put it upside down having no clue which way the shark was swimming, but your picture says it all! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/white914.jpg) |
Lucky9146 |
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem. Did some poking around here on the site (IMG:style_emoticons/default/type.gif) where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal. (IMG:style_emoticons/default/idea.gif) Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version? Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out. (IMG:style_emoticons/default/confused24.gif) “Shark Fin” is on the far left. Thanks! (IMG:style_emoticons/default/white914.jpg) ![]() Jim,good description of the shape (IMG:style_emoticons/default/biggrin.gif) ,I mounted this plate with one bolt and moved it once till contact with the rod ,the bolt out and plug welded the hole . Every "6" on carbs should have one of these ,very handy for quick start up,I do 2-3 pumps on the pedal with the lever on full travel,mine starts straight up. Can't take credit for the term "Shark Fin" it came from Scott at 914 Rubber when I called looking for help. Plan to do the same as you on install. Thanks for chiming in. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/white914.jpg) |
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
This looks like a great product, and I am very interested.
Curious, however, on why the kit requires welding the shark fin onto the crank, and then presumably having said crank restored and replated? Why not make that an option? I am guessing a lot of customers would happily pay for it? In fact, I'd rather have that and the rod assembly without the kit's lever—as I already have one of those. As always, however, 914rubber's contribution to the hobby is more than appreciated. How great that this kit exists at all? |
Lucky9146 |
This looks like a great product, and I am very interested. Curious, however, on why the kit requires welding the shark fin onto the crank, and then presumably having said crank restored and replated? Why not make that an option? I am guessing a lot of customers would happily pay for it? In fact, I'd rather have that and the rod assembly without the kit's lever—as I already have one of those. As always, however, 914rubber's contribution to the hobby is more than appreciated. How great that this kit exists at all? Agree! I was surprised at what I received as the picture on 914 Rubber did not show the "Shark Fin" or mention there was welding involved, or drilling and bolting, as the case may be. Also agree it would have been great to have the thing all ready to install. Perhaps in the future. (IMG:style_emoticons/default/white914.jpg) Picture from 914 Rubber site. ![]() |
SixerJ |
Member ![]() ![]() Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England ![]() |
Here you go, I tucked the corner of the wood template into the leaver on the point where the flange changes direction
I assume 914 rubbers fin is exactly the same dim / shape. Looks very similar Real fin has a dimple for strength / held on with a couple of small spotwelds All dims in MM, dimension to the other fins corner is 55mm ![]() |
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,483 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
here it is on a complete assembly.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,735 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Here you go, I tucked the corner of the wood template into the leaver on the point where the flange changes direction I assume 914 rubbers fin is exactly the same dim / shape. Looks very similar Real fin has a dimple for strength / held on with a couple of small spotwelds All dims in MM, dimension to the other fins corner is 55mm ![]() Perfect illustration. |
Bruce Anderson used to talk about how he loved to use the hand throttle in his 914-6 as cruise control on long trips. While my car starts up cold pretty nicely, my last trip to LA got me thinking about adding this upgrade...
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Mikey914 |
Here's the drawing I have.
We colorized if on the site to try to make it more clear. Matt may have some pics, nit sure if he has completed the install yet. Attached image(s) ![]() |
Lucky9146 |
Here you go, I tucked the corner of the wood template into the leaver on the point where the flange changes direction I assume 914 rubbers fin is exactly the same dim / shape. Looks very similar Real fin has a dimple for strength / held on with a couple of small spotwelds All dims in MM, dimension to the other fins corner is 55mm ![]() Thank you most helpful! (IMG:style_emoticons/default/beerchug.gif) This REALLY is what is needed! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/white914.jpg) |
Lucky9146 |
Just for kicks, this is my set up. Genuine 914-6 set-up in the tunnel and on the pedal. I used a 911 arm for it, and there is a knob Porsche made that says "Throttle" for my type of lever too. I think Eric Shea's car has one....? ![]() It is good for cold starts, and it does work for "cruise control." Cruise control (IMG:style_emoticons/default/idea.gif) Nice! Thanks for the pic As an aside isn't the carpet suppose to be over the shifter base? I have an original tunnel carpet with a slit in the front the hand throttle lever comes out of. Just asking. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/white914.jpg) |
Larmo63 |
I like the look of the shifter bolted over the carpet. The stock carpet over the shifter looks so sloppy. Just my preference.
I'm Teutonic. I'm weird. |
Lucky9146 |
I like the look of the shifter bolted over the carpet. The stock carpet over the shifter looks so sloppy. Just my preference. I'm Teutonic. I'm weird. Good point! not that your weird but that it does look "sloppy" and could be improved. (IMG:style_emoticons/default/white914.jpg) |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,544 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Just send me the fins and I will weld them on quickly no charge for those that want it..
I am actually disappointed I didn't know this before as I will be adding this and already replated my parts .. Darn |
Just send me the fins and I will weld them on quickly no charge for those that want it.. I am actually disappointed I didn't know this before as I will be adding this and already replated my parts .. Darn You're a good dude, Ben. Just noticing the strengthening "rib" on the factory piece, likely due to the way the rod operates. Curious if that pressure has been dealt with in the new piece? Seriously, good on those who worked to make this product happen! |
Lo-Fi Version | Time is now: 19th April 2025 - 01:31 PM |
