> Fuel Pump for Carbs, Fuel Pump
simonjb
post Nov 20 2017, 09:25 AM
KiwiMan
I was wondering what fuel pump folks are using and like for a Carb conversion. Engine is a 2.0 upgraded to 2.3 with two Weber 44 IDF carbs.
Spoke
post Nov 20 2017, 09:31 AM
Jerry
I'm using Mr. Gasket 12s on my 2056.
12s
theer
post Nov 20 2017, 09:35 AM
Tangerine sells everything you need (see fuel pumps at bottom left):
http://www.tangerineracing.com/stainlessfuellines.htm
GeorgeRud
post Nov 20 2017, 09:48 AM
Low pressure Pierburg pump mounted up front by the steering rack.
michael7810
post Nov 20 2017, 01:29 PM
QUOTE(theer @ Nov 20 2017, 08:35 AM) *
I've been using the pump from Tangerine for 3 years now without problem. No pressure regulator needed and is quiet enough that I don't hear it with the engine running.
porschetub
post Nov 20 2017, 01:35 PM
Low pressure Carter pump mounted on front crossmember,not too loud, fairly priced and runs well.
I seem to remember the same pump comes from CB performance also.
post Nov 20 2017, 01:55 PM
Resident German
QUOTE(porschetub @ Nov 20 2017, 11:35 AM) *
CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056.
http://www.cbperformance.com/product-p/3193.htm
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1511207757.1.jpg)
Friends don't let friends use facet pumps ...
(IMG:style_emoticons/default/barf.gif)
Mark Henry
post Nov 20 2017, 04:41 PM
that's what I do!
You can buy a PMO fuel pressure regulator and run your existing FI fuel pump.
forrestkhaag
post Nov 20 2017, 05:49 PM
Sir Andy's pump as illustrated is the one I have been running on my 3.0-6 without an issue and the pressure regulator and gauge shows consistent pressure at 2.5-3.
sportlicherFahrer
post Nov 20 2017, 06:14 PM
Nothing to see here.
Running that same Carter pump from CB Performance on mine as well. Constant correct pressure. I would recommend removing the supplied filter and either relocating it, or replacing the clamps at a minimum. I've seen a couple of them leak at those fittings fresh out of the packaging.
post Nov 20 2017, 06:45 PM
Resident German
And i forgot, whatever you do, please don't hack into your wiring harness!
You can mount and power the low pressure pump in the same spot as the FI pump and even use the same wires, fuses and relays without ever cutting anything.
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php
simonjb
post Nov 20 2017, 08:26 PM
KiwiMan
Thanks guys !
porschetub
post Nov 20 2017, 10:21 PM
QUOTE(SirAndy @ Nov 21 2017, 08:55 AM) *
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) Facet pumps stink ,the only good thing about them is you always know they are working because of the noise (IMG:style_emoticons/default/rolleyes.gif) .
Andy did you run @ full pump pressure or run a regulator ,I found my Zeniths ran better @ a lower pressure than pump supplied same with the carbs on my speedster (dcnfva Weber) seemed anything over 3psi was too much for the float needle and seats on both types of carbs.
IMO the use of a regulator and gauge is your best friend.
I go on but the use of quality (efi rated) fuel hose and correct fuel line clamps is a step ahead from a safety aspect.
thelogo
post Nov 20 2017, 11:23 PM
Group: Retired Members
QUOTE(SirAndy @ Nov 20 2017, 11:55 AM) *
Rotary all the way , my 2.3 needs that steady fuel supply
Since i have a slight fuel leak in the engine bay on startup i know its working
But honestly a 2.3 running premium fuel with webbbers in a 914
Turns it into more of a race car then a 914 .
Stock a 914 is like civilized but with big 4 its obnoxious
In a good way . (IMG:style_emoticons/default/bye1.gif)
Tbrown4x4
post Nov 21 2017, 04:32 AM
I really need to do a write-up on this. PO put a Facet on the engine tins and the noise was irritating. I had it running once to warm it up, and it died, leaving the pump to drain the battery. (IMG:style_emoticons/default/sad.gif) (Car would die sometimes as well.)
When I had the tank out to get to the wiper linkage, and decided to install the CB pump. I mounted the pump about where the 75-76 location is, and mounted the filter to the steering rack.
For power, I installed one of these:
http://www.revolutionelectronics.com/_Medi...in-2_med-2.jpeg
Wired into the fuse panel, and attached to the Tach, all the wiring is short and up front.
When you key up, the pump runs for 3 seconds to prime, then waits for a tach signal. If you crash your car, the pump stops running so you don't get drenched in fuel. So far, so good. Happy to get rid of that clicking!
ChrisFoley
post Nov 21 2017, 07:43 AM
I am Tangerine Racing
QUOTE(Tbrown4x4 @ Nov 21 2017, 06:32 AM) *
3 seconds isn't long enough to refill the float bowls after sitting for a week or more, but otherwise its a great safety feature.
North Coast Jim
post Nov 21 2017, 09:02 AM
QUOTE(SirAndy @ Nov 20 2017, 02:55 PM) *
I also run this setup but I purchased mine form Tangerine Racing. Also bought the SS fuel line for Carbs. Used the remaining grommet holes to run the wiring thru the tunnel. Bought a 2 wire multi stranded and flat jacketed wire from West Marine. Mounted the pump/filter combo under the gravel pan. It's tight but it works. Happy to see the pump outside of the car and the pressure line now in SS tube. As insurance I installed on the top of the engine a fuel regulator. I actually use a 2.5lb pressure with 40IDFs on a 2.1L engine. Runs great.
Mark Henry
post Nov 21 2017, 10:12 AM
that's what I do!
QUOTE(Tbrown4x4 @ Nov 21 2017, 05:32 AM) *
You could also do this by wiring a simple relay to the oil pressure switch, but it has no pre-run. you could get around this with dash mounted momentary switch to prime the pump.
$5 plus some wire.
Or you could use a fuel pump relay from a VW k-jetronic, uses the tach signal and has a simple 555 timer for pre-run.
$27 plus some wire. you might be able to find one in a scrapyard.
http://www.busdepot.com/321906059C
- Lo-Fi Version Time is now: 21st December 2024 - 11:58 PM
