Cayenne motor swap, Let’s hear it all! |
Nov 23 2017, 06:15 PM
Custom Member Group: Members Posts: 24,565 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone managed to stuff a cayenne motor into a 914?
What transmission? What about fuel and ignition? |
914forme |
Nov 23 2017, 07:17 PM
Isn't that what Marty over at MSDS is doing (IMG:style_emoticons/default/confused24.gif)
rick 918-S |
Nov 23 2017, 07:18 PM
Hey nice rack! -Celette Group: Members Posts: 20,423 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
rick 918-S |
Nov 23 2017, 07:19 PM
. Oh Ya. Marty is doing one. |
Nov 23 2017, 08:06 PM
914Sixer |
Nov 23 2017, 09:02 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
V-6 or V-8?
Mark Henry |
Nov 23 2017, 09:08 PM
It's a tall engine would it fit?
Nov 23 2017, 10:26 PM
The MSDS build is crazy. In an awesome way.
Cayenne V8 TT mated to an inverted 996 GT2 Transaxle, Sequential 6 speed shifter, Centerlock hubs, etc. Attached thumbnail(s) Attached image(s) |
rick 918-S |
Nov 24 2017, 04:30 AM
I haven't checked out Marty's car since he first announced the build. Top shelf at expected. (IMG:style_emoticons/default/beerchug.gif)
Andyrew |
Nov 24 2017, 09:41 AM
The 6 is just a VR6. Mueller was going to do it on his old car and I think it would work. Just a brick of an engine (heavy) for the power outlet. However if you wanted to put a monster turbo on it and go for 700 hp thats not a bad choice.
Krieger |
Nov 24 2017, 11:05 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
How much does the Cayenne motor weigh?
GeorgeRud |
Nov 24 2017, 11:39 AM
I wonder if the V6 would be a candidate for a turbo setup? The idea of not having to impinge on the legroom of the 914 would be nice for taller drivers. The need to cut the firewall to fit a compressor has been the reason my -6 conversion doesn’t have AC (yet).
Mueller |
Nov 24 2017, 11:45 AM
The 6 is just a VR6. Mueller was going to do it on his old car and I think it would work. Just a brick of an engine (heavy) for the power outlet. However if you wanted to put a monster turbo on it and go for 700 hp thats not a bad choice. The better Porsche V6 would be from the Macan, it is a true 90° V6, basically 2 cylinders removed from the Cayenne V8. BradR thinks many wreckers would take as low as $1500 for one since there is no demand. George, the Macan V6 comes from the factory twin turbo'd! |
Maltese Falcon |
Nov 24 2017, 11:58 AM
Advanced Member Group: Members Posts: 4,634 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
How much does the Cayenne motor weigh? Haven't weighed the 4.5L prior to the hot rod build ( now 5.0L ) , the stock weight could easily be found online. Our engine is now void of ; the OE lower oil pan ( would hang approx 9" below center of crank ), its internal dry-sump ( the oe location is in the wet oil pan ) , starter motor, vvt system, iron exhaust manifolds , turbos and a bunch of emission gadgets. Now closer in weight to the Ruf RGT alum V8 at 396 lbs. I've calculated that the new drivetrain will have approx 2" clearence to the oe 914 firewall ( lower edge), no interior intrusion, and excellent cv joint / axel geometry. The alum engine adapter-to-trans adapter plate is only .750" in thickness , and everything hangs on Wevo HD mounts. Engine is now able to sit lower in the 914 (with a custom dry sump pan ) for better cg, and ground clearence equal to (or better) than a flat 6. Transaxle weighs 175 lbs. dry. Not familiar with the Cayenne v6 specs ¡ Marty |
Mueller |
Nov 24 2017, 12:05 PM
Pretty sure I read it is "modular" and shares some components of the V8
It just screams for ITB's if keeping it N/A (IMG:style_emoticons/default/smile.gif) |
Maltese Falcon |
Nov 24 2017, 01:22 PM
Pretty sure I read it is "modular" and shares some components of the V8 It just screams for ITB's if keeping it N/A (IMG:style_emoticons/default/smile.gif) Add this Pan to the bottom of the main-bearing girdle; that's where you will lose your ground clearence; OR jack the engine way up |
Mark Henry |
Nov 24 2017, 03:47 PM
Marty did you make a wide sump or did you go with an external tank?
Maltese Falcon |
Nov 24 2017, 04:50 PM
Marty did you make a wide sump or did you go with an external tank? Mark, the tank is a remote ARE dry sump tank, the new pan is custom billet + cnc : about 3" in depth. You can just see a Red #12 Cap plug sticking out of the side (from the pan ) in one of the pictures in this thread....turbo oil return. External belt- drive dry sump pump is on the lower Right side of the engine. Marty |
GeorgeRud |
Nov 24 2017, 04:59 PM
Beautiful work, Marty! Looking forward to seeing the completed project.
Maltese Falcon |
Nov 24 2017, 05:55 PM
Beautiful work, Marty! Looking forward to seeing the completed project. Thank you George , I will deliver an awesome vehicle built to everyones expectations (IMG:style_emoticons/default/driving.gif) Marty |
Lo-Fi Version | Time is now: 26th April 2024 - 10:52 PM |
