ajracer |
Member ![]() ![]() Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 ![]() |
Photo # 2 Rear View
(The mounts have been fabricated and installated since this photo) PS Even seems like enough room to add a Large muffler across the back ! Attached image(s) ![]() |
neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
Allan,
The photos are a bolted Boxster 5 speed to an Audi V6. I'm working in parallel with my V8 914 and 901 tall geared tranny, pictured. Attached image(s) ![]() |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
The Boxster tranny is not that great. The way I understand it the early trannies were not dealer servicable. The dealer threw the bad one away and got a new one. Here are the torque ratings on the Boxster tranny.
http://www.en.getrag.de/180/180 |
neo914-6 |
Allan,
BTW, have you addressed the axles? My 75 911 axles and CV's mated perfectly to an Audi 1.8t transaxle and were the correct length. They are too large, however for the boxster transaxle. I'm guessing the output flanges may be interchangeable. Are you positioning the Boxster transaxle in line with the wheels or behind them for engine clearance as with all the V8 conversions? |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,621 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Some of the parts I've had to replace are the throttle-body boot ("TBB"), diverter valves, and one that IIRC is fondly called the Y-pipe (but is really a hose). Apparently the stock hoses and clamps are not up to added boost. Also I had a water pump and a temp sensor fail early.
Check out the B5 S4 forum at www.audiworld.com for lots of info on these issues. I am still debating whether to hang onto this car and maybe mod it further, or sell it and get something else (an RS6 is one possibility) as it's over 60K miles and could start getting expensive real quick as stuff starts going out. The suspension is already feeling mushy. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Felix.. what kind of headers are those?
I dont like how my car sounds (actually I do because I blew out my header gasket and now its loud (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)) and I want to put something with more flow and bigger pipes. Andrew |
Dman |
Member ![]() ![]() Group: Members Posts: 163 Joined: 18-February 03 From: Sacramento CA Member No.: 311 ![]() |
Chris, if your front end is feeling loose you better take it in. There is a recall on the ball joints, while mine was in for that they also found the upper control arms were shot also. 60k miles on my car also.
This is a great thread! How heavy is the 2.7 compared to a flat 6? |
neo914-6 |
Hooker Competition, ceramic coated... |
neo914-6 |
Chris, I know about this weak part and would like the one-piece cast aluminum y-pipe... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) It's toast after 60k? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
Dman |
I think it is ~OK for a stock boost car but they say as soon as you chip this motor the Y pipe will
much more likely to go. |
Dman |
Although the site is down tonight, another good site for info is biturbo.com.
neo914-6 |
Duane, Thanks, always looking... Here are a few: http://www.audizine.com/ http://www.dynospotracing.com/ http://www.awe-tuning.com/ http://www.giacusa.com/ http://www.streetwerke.com/ http://www.newdimensions.com/ |
MecGen |
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 ![]() |
Shit I am late for work...
Hey Neo, just curious...why not use the Audi trans? Thats what I am leaning to, yours for sale ? Later Joe (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
ajracer |
Felix:
The Axle flanges on the tranny and my (911 axles) are the same size, which if I remember is 100 mm. with 6 bolts 8mm. The actual axles I will be using are likel going to be VW bus axles which I understand provide a broader range of movement and are the correct flange size. The length will be handled with axles spacers similar to the RH (already have a mock up adapter for machining purposes) which will speed up the process. The alignment of the tranny output flanges is slightly to the rear with of the axle flanges, however I have also modified my Front engine bar (DH) and Fabricated my new tranny mounts to both be adjustable ( +- 1.5") in order to allow for later installation of a FI trigger wheel off harmonic balancer when I start phase II of this project and conver everything to the Corvette fuel injection with MegaSquirt ! In my case the engine clearance look really decent and should not be a problem. (Attached photo shows the trial fitting of Right side only mount for tranny, which by the way is a 5 speed unit.) Talk again soon. Attached thumbnail(s) ![]() |
grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
Yep I followed a guys project using the 5 spd tranny. He converted an older 2.5 to 3.4. I just cant remeber if he did any level of fabrication to get it to mate to the 5 speed. I do remeber it went together pretty quickly. At one point he had a site but it isnt online anymore. I'd still love to see somone convert a 914 with either the 986 S 3.2 or the 996 3.4. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Felix will be able to have a bolt-on solution for shifting, no real fabrication needed to get the shifter to work..... The Audi tranny is more like a tailshifter/930 transmission, no bolt-on shift linkage |
Brett W |
neo914-6 |
neo914-6 |
That is a less costly alternative and Sonu has most of the linkage designed to the Audi cable shifter (looks identical to the Porsche). Like Mike said, I like that the Boxster tranny is already engineered for mid-engine... |
neo914-6 |
That's odd, my axle flanges are smaller than the 911 CV's. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) BTW, here's a tranny bracket from a guy who installed a Boxster 6 speed in his 914 (w/4cyl). Attached image(s) ![]() |
Lo-Fi Version | Time is now: 28th April 2025 - 06:22 PM |
