98101 |
Michael in Seattle ![]() ![]() Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
After staring at that fresh air box I decided that I would chance ruining the new Vinyl over, most assuredly the air box. I used the old piece of Vinyl as a template and cut out the opening for the vent. Using an old dull hacksaw blade I removed the old padding and Vinyl from beneath the vent. I "skooched" the new padding under the vent then stretched the Vinyl over the vent on one end and carefully massaged it over the vent and then beneath it. After that I placed and glued the foam first, working from center out followed by the Vinyl. It took patience but not nearly the amount had I (IMG:style_emoticons/default/sheeplove.gif) with that airbox.
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
Looking good Kent... (IMG:style_emoticons/default/beerchug.gif)
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 02:39 AM |
