My High Amp Alternator, how I did it, and you can too |
McMark |
Feb 12 2018, 11:58 AM
My original thread with real pictures
I won't be making/adapting these anymore, so I wanted to share all the info I found. I used the MechMan Alternators 150amp (Part Number: 7771150) but it's been discontinued. It's listed for a 1991 Ford F-150 5.0L motors. There are two different alternators with the same body (pictured below), the wrong one has the connector at 2:00 and the RIGHT one has the connector at 10:00. There are other options, but if I were doing another one, I would order the Bosch AL562X which is a 75A unit. There are aftermarket builders who make these up to 220A. Adaptation should be similar for all. The image below should hit most of the major points, but here's a few extra details: *If I were doing more of these, I would look into just making an alternate version of the upper and lower brackets to work with an unmodified Ford alternator. That way if you need one while away from home, it's possible. *The unit I bought had an internal fan, the stock Ford units use a front mounted fan. If anyone tries this they'll have to confirm that the fan + pulley still line up with the fan pulley. Visually, it appears that the internal or external fan setup occupies the same space (compared to each other) but the internal just has extra material in the case to encapsulate the fan. So I suspect the fan will be a non-issue. *These Ford alternators also use a ribbed belt, so a V-Groove belt would need to be sourced. I looked quickly on eBay and it appears that they should be pretty easy to come by. *Offset drilling the upper hole is almost impossible to do freehand. You'd need to take it to a machine shop. I built a drill jig to keep my drill bit in the right place. The difficulty of this step is another reason why I'd recommend someone design new brackets -- you wouldn't need to drill this out and could simply loosen/tighten the upper bold 'from the back'. I'd be happy to loan out my drill jig. It worked for me and it should work on these, but I can't guarantee the location is perfect on all variations of this alternator. And finally, when grinding/milling/cutting on the alternator body make sure to tape off any holes where bits of metal could enter the alternator. Attached image(s) |
McMark |
Feb 12 2018, 12:09 PM
If anyone wants to undertake this project, I'd encourage you to do it now. I may not notice questions or posts about this in the future.
Also, this would best be handled with the engine out of the car so you can see what you're doing (specifically ensuring the fan and pulley are inline). |
gothspeed |
Feb 12 2018, 12:36 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
So does the V-belt pulley fit right on or does one source a different pulley?
malcolm2 |
Feb 12 2018, 01:32 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Thanks filling us in on your previous work. I do appreciate you restarting this Topic. I am going to dig deeper and see what might be out there with less mods. Might even take your advice and see what I can do about the bracket.
Here is what I found so far. Mechman has a 170amp model that looks a lot like the Bosch. This site has a nice dimensional drawing. I plan on comparing to my removed bosch this evening.... Fingers are crossed on that part. One of Mechman's vendors has info too. https://ceautoelectricsupply.com/product/me...ent-alternator/ Before Mark mentioned the 91 ford model, I thought someone said something about a GM Alternator, so here I am with it. Mark mentioned the 10:00 connection and this one has that. the dimension of 143mm from the pulley groove to the back case is the smallest I found today. Questions for anyone that knows more about ALT than me.... (IMG:style_emoticons/default/popcorn[1].gif) 1 wire vs. 3 wire. Differences...? Benefits...? Can either be installed on the 914...? where do the wires connect on the car..??? I did read that the 3 wire will NOT un-excite at idle. That is a benefit. |
McMark |
Feb 12 2018, 03:25 PM
Here's the drawing of the 7771150. The one in the post above has the mounting holes closer together, and moving/drilling the top hole would get really close to the edge I think.
malcolm2 |
Feb 14 2018, 10:08 AM
I guess I will keep this thread going until I make a decision about being able to upgrade. Our other member, Pete Newman is more than willing to make his HO ALT kits, but will require 10 buyers and I can't wait that long. Spring is coming and I want to DRIVE. (IMG:style_emoticons/default/driving-girl.gif)
As time allows, I have been doing some research and I see WHY the ALT you suggest needs to have the holes modified. I found a video of an ALT being removed from a late model VW bus. I believe that is the ALT you suggested. It just did not make sense to me as to why a 79 bus ALT using a TIV engine would not be an exact fit. Now I see. The top bracket for the ALT is different than ours. I wonder if I can find that bracket for use on the 914. The bus bracket is also anchored on the exhaust. Not that I will do that, but that is part of the difference. You can almost see the anchor bolt in this picture. It is kinda behind the red line at the btm. And you can see the bracket in question is rusty at the anchor point, no doubt from the heat of the exhaust. Any BUS guys out there have a bracket I could buy? Know the part # or a good place to buy it? Here is the whole video, if you are interested. It is pretty long. This screen shot is about 8 minutes in. https://youtu.be/qwYcKWBbqjM |
malcolm2 |
Feb 14 2018, 10:22 AM
Well that did not take long. Here is a better view. Still no sellers found. EDIT: turns out this is not needed. The ALT i chose bolts up the the 914 OEM brackets.
ejm |
Feb 14 2018, 10:37 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Questions for anyone that knows more about ALT than me.... (IMG:style_emoticons/default/popcorn[1].gif) 1 wire vs. 3 wire. Differences...? Benefits...? Can either be installed on the 914...? where do the wires connect on the car..??? I did read that the 3 wire will NOT un-excite at idle. That is a benefit. An alternator with one wire has an internal voltage regulator while the 3 wire models require an external regulator. When rpms drop below some point the voltage regulator will stop the alternator from charging. Doesn't matter if it's one wire or three. |
McMark |
Feb 14 2018, 12:12 PM
Questions for anyone that knows more about ALT than me.... (IMG:style_emoticons/default/popcorn[1].gif) 1 wire vs. 3 wire. Differences...? Benefits...? Can either be installed on the 914...? where do the wires connect on the car..??? I did read that the 3 wire will NOT un-excite at idle. That is a benefit. Not exactly. The Ford alternator has a built in regulator. You've got it confused with exciting. A one wire alternator will self-excite. A multi wire alternator needs external power input to excite (thus the extra wires). |
malcolm2 |
Feb 14 2018, 05:29 PM
Nevermind....
More to come. |
malcolm2 |
Feb 15 2018, 08:26 AM
McMark suggested a 75amp model and I found a 70amp alternator. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
It was impossible to find a Bosch brand. But there is a brand called REMY. Part # 14062. They are all over and really not very expensive. Even found one vendor that will offer a 3 year warranty for $7. As stated above they are used on the 75 to 79 bus type IV engines that had gasoline heaters and extra fans. Not an option that was installed on very many vehicles. RATWELL.com has a nice write up about the differences in the 50amp and 70amp set up. There are a few parts and pieces that I am going to try to hunt down. * REMY rebuilt 14062 delivered w/ 3yr warr. $114 * The cooling elbow is slightly different and I found several sources $15 * I need a pulley with a fan. Some Samba guys get frustrated in searching for the exact part and go without, so there is that. Found a BUG one and a CHEVY one for $15. Might need to modify, but hey, it's cheap. * Might need a special top bracket. Found a Samba seller that wants $35 for the long bracket. Screw that. I think I can make one. * Ratwell and others say that the Wire harness is different since the back plate is not there to protect the connector from HEAT. $92 Up to $271 total with the bracket might need some additional BUS cooling tins I don't expect them to take me much over $300. So I am going to buy all this and keep posting. |
malcolm2 |
Feb 15 2018, 08:56 AM
Front looks exactly like our 50amp model. The back has a built in cooling tube and similar if not the same electrical connection. What I would really like to see is a dimension drawing. Can't find one of those for our 50amp model either.
gothspeed |
Feb 15 2018, 09:00 AM
This is a great thread with a lot of great ideas! Keep it coming! (IMG:style_emoticons/default/smile.gif)
McMark |
Feb 15 2018, 01:19 PM
AFAIK, the Type4 bus alternator is a direct drop in. They were impossible to find new and pretty uncommon used, but if someone started remaking them that's the best solution. The bus upper bracket is just a longer version of our bracket. The alternator should still mount up to our bracket just fine.
malcolm2 |
Feb 22 2018, 06:06 PM
I am dry fitting my 70 amp alt. I have a spare fan housing so that makes it easy to play with everything on the bench.
The silver alt cooling tin came off of my car. The black one came from Garold. Turns out my silver one had been cut by a PO. Garold's looks like factory. The main hole is smaller on his. And the flat plastic piece is also from my car. It also fits. So the alternator is a direct fit, as McMark stated. I used both 914 mounting brackets too. I have not fit it all up with the black tin, but I will. As it goes now, a slight mod (making the hole bigger) is probably a good thing. Making belt adjustment easier, I guess. More to come on the rest of the fit. still have to deal with the cooling elbow, the pulley and the front fan ( if I use it) |
Boomingbeetle |
Feb 22 2018, 11:28 PM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
Front looks exactly like our 50amp model. The back has a built in cooling tube and similar if not the same electrical connection. What I would really like to see is a dimension drawing. Can't find one of those for our 50amp model either. I can confirm that this unit is a direct fit, I installed one last year. No issues powering my HID headlamps and stereo |
malcolm2 |
Feb 23 2018, 07:08 AM
I can confirm that this unit is a direct fit, I installed one last year. No issues powering my HID headlamps and stereo Let me ask you a couple questions then.... Did you use the cooling air elbow for the 914 or a VW bus? Did you use the pulley with a fan on it.... also from the VW bus? Did you have an issues with the belt lining up? |
Mblizzard |
Feb 23 2018, 10:14 AM
McMark suggested a 75amp model and I found a 70amp alternator. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) It was impossible to find a Bosch brand. But there is a brand called REMY. Part # 14062. They are all over and really not very expensive. Even found one vendor that will offer a 3 year warranty for $7. As stated above they are used on the 75 to 79 bus type IV engines that had gasoline heaters and extra fans. Not an option that was installed on very many vehicles. RATWELL.com has a nice write up about the differences in the 50amp and 70amp set up. There are a few parts and pieces that I am going to try to hunt down. * REMY rebuilt 14062 delivered w/ 3yr warr. $114 * The cooling elbow is slightly different and I found several sources $15 * I need a pulley with a fan. Some Samba guys get frustrated in searching for the exact part and go without, so there is that. Found a BUG one and a CHEVY one for $15. Might need to modify, but hey, it's cheap. * Might need a special top bracket. Found a Samba seller that wants $35 for the long bracket. Screw that. I think I can make one. * Ratwell and others say that the Wire harness is different since the back plate is not there to protect the connector from HEAT. $92 Up to $271 total with the bracket might need some additional BUS cooling tins I don't expect them to take me much over $300. So I am going to buy all this and keep posting. Clark can you post the source for the boot? As far as the fan goes, I don't think you need one if you have the boot hooked up. With the boot air will be circulated out the front of the alternator by the impeller. The amount of additional cooling provided by a fan on the front is likely non existent. Also I have found a few of the 7771150 Alternators out there. |
Mblizzard |
Feb 23 2018, 10:20 AM
Also if you want to look at some of the other options like the 10SI, or 12SI GM Alternators there is some good information here.
Not sure of any modifications required to make them work but I have found them as cheap as $60. |
gothspeed |
Feb 23 2018, 12:17 PM
I can confirm that this unit is a direct fit, I installed one last year. No issues powering my HID headlamps and stereo Let me ask you a couple questions then.... Did you use the cooling air elbow for the 914 or a VW bus? Did you use the pulley with a fan on it.... also from the VW bus? Did you have an issues with the belt lining up? +1 ... I would like to know the above as well (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 11:45 PM |
