Oh no! Lost oil pressure ... |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
Feb 15 2018, 08:58 PM
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise. Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) That sucks. I would cut open the oil filter and look for gold. |
flyer86d |
Feb 15 2018, 09:07 PM
Member Group: Members Posts: 422 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Yes, I agree. Cut the filter open.
What would starve the pressure pump? Charlie |
MartyYeoman |
Feb 15 2018, 09:08 PM
Senior Member Group: Members Posts: 1,517 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Ouch (IMG:style_emoticons/default/sad.gif)
aharder |
Feb 15 2018, 09:10 PM
Advanced Member Group: Members Posts: 4,372 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
That does suck !! Hope there's not any major damage
toolguy |
Feb 15 2018, 09:15 PM
The oil filter canister should have a spring for oil bypass if it gets clogged so that probably isn't it. . The oil filter base assembly has a pressure bypass also. . Scavenge pump and pressure pump are always turning so oil should be returning to the oil tank always . . . the bypass valve on the side of the engine case is the over pressure bypass valve that bleeds off excess pressure right out of the oil pump . . there is another over pressure on the bottom of the sump which is the end of the oil supply galley. . . either of those could bleed off some pressure but i wouldn't expect a total loss that returns when you reved the motor. . that is puzzling. .
I would pull the sump cover off and see if the wire screen is plugged at the oil inlet tube. |
MarkV |
Feb 15 2018, 09:25 PM
If after the event you had 30 psi at an idle I wouldn't think you damaged bearings? What was the idle pressure before the event?
Feb 15 2018, 09:29 PM
If after the event you had 30 psi at an idle I wouldn't think you damaged bearings? What was the idle pressure before the event? Same as after, about ~30 at idle and ~80 under load ... (IMG:style_emoticons/default/confused24.gif) PS: Also should mention, the noise went away once the oil pressure came back up, but it sure was a loud mechanical noise like a bad bearing or a valve hitting a piston |
Chris914n6 |
Feb 15 2018, 09:31 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
3.6L right?
Hydraulic lifters? Hydraulic cam guides? What do you think the noise was? |
Feb 15 2018, 09:32 PM
3.6L right? Hydraulic lifters? Hydraulic cam guides? What do you think the noise was? Doh, yes, could it be that the lifters ran out of oil??? (IMG:style_emoticons/default/idea.gif) |
Krieger |
Feb 15 2018, 09:33 PM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
This may be stupid, but was the engine about to die because of some sort of idling issue? Hence the noise and green light on. Maybe some shaking?
Feb 15 2018, 09:34 PM
This may be stupid, but was the engine about to die because of some sort of idling issue? Hence the noise and green light on. Maybe some shaking? Nope, the engine was running ok through all of it, no shaking. Oil pressure was at dead 0 though ... (IMG:style_emoticons/default/popcorn[1].gif) |
Krieger |
Feb 15 2018, 09:46 PM
From my wondrous experience with my 3.0L I learned a lot. I couldn't get oil out of the case fast enough and the extra 3-4 quarts in the engine sump really slowed the motor a lot. I could feel the loss of power. There also was evidence near the breather on top of the case for this. It doesn't sound like this was you problem and it didn't leak out. My thoughts would be why a full tank of oil wasn't making it to/through the pump, or how am I bleeding ALL the pressure.
Krieger |
Feb 15 2018, 09:56 PM
Hope this is helpful.
Attached thumbnail(s) |
Feb 15 2018, 10:04 PM
Hope this is helpful. Well that explains it, i was running everything upside down! (IMG:style_emoticons/default/huh.gif) |
sixnotfour |
Feb 15 2018, 10:32 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
youve had a good run on that 3.6...time for case through bollt o rings rod bearings bolts, rod bearings, rings, valve job..min,,good catch , 90% sure you have at least one or two thin rod bearing...the way of the 3.6,,If it not leaking ouut the #8 or partingline..
914_teener |
Feb 15 2018, 10:34 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I vote for dissecting the Oil filter. Car sitting a while Andy? Sludge into an oil passage and rev cleared the sludge? |
SO.O.C914er |
Feb 15 2018, 10:35 PM
Senior Member Group: Members Posts: 1,236 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Andy if you were running everything upside down I would think the pressure on your head would have been unbearable! (IMG:style_emoticons/default/av-943.gif)
Mueller |
Feb 15 2018, 10:57 PM
What 911 did the motor come out of? If 964 based I thought those are solid lifters.
Feb 15 2018, 11:05 PM
What 911 did the motor come out of? If 964 based I thought those are solid lifters. '95 993, last of the true air cooled ... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 11:12 PM |
