Wipers park position |
Bartlett 914 |
Mar 14 2018, 02:46 PM
I just did a quick scan of the parking lot. Every car without exception had the wipers park on the right. Why water hitting the 914 windshield would be different escapes me
Mar 14 2018, 03:30 PM
914-6 GT in waiting Group: Members Posts: 19,600 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
douglastic |
Mar 14 2018, 03:34 PM
not a real person Group: Members Posts: 62 Joined: 7-November 16 From: Beaumont, CA Member No.: 20,566 Region Association: Southwest Region |
I just did a quick scan of the parking lot. Every car without exception had the wipers park on the right. Why water hitting the 914 windshield would be different escapes me I believe that is because you are looking at newer cars - they swipe with the drivers arm almost vertical against the driver A-pillar - leaving a much more cleared area overall for driver's view. 914s park almost horizontal and have a mirrored image swipe pattern, resulting in clearing the same amount for both driver and passenger regardless of which side they park on. The difference is they park higher up on the window (visible) and newer cars park way down under the hood cowl more (less visible) That's my unofficial observation anyway! (IMG:style_emoticons/default/idea.gif) |
Bartlett 914 |
Mar 14 2018, 03:48 PM
Pretty good answer!
mgphoto |
Mar 14 2018, 04:25 PM
"If there is a mistake it will find me" Group: Members Posts: 1,365 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
My wipers don't automatically go to a park position when they are cancelled. They just stop wherever they happen to be in the cycle when the switch is turned off. After reading through this thread, I am assuming they should? Any idea what could cause this? Hello A&P Mech, I took a look at the factory repair manual and found that your problem could be related to the switch located in the wiper motor. There is a round disk attached to the bearing housing on the motor (section of the motor which houses the worm gear), this is a switch. When switched off, the sweep contacts on the disk, within the unit keeps the power flowing until it reaches the parked section, power does not flow, wipers stop. This repair can be a very tough one. The manual says everything has to come out, fuel tank, fresh air blower and than the rack for the wiper motor. Good luck! |
mgphoto |
Mar 14 2018, 04:38 PM
I just did a quick scan of the parking lot. Every car without exception had the wipers park on the right. Why water hitting the 914 windshield would be different escapes me A quick look at Jaguar UK and the right hand drive cars have the wipers on the right. We drive left hand cars here in the US so left hand wipers. |
rgalla9146 |
Mar 14 2018, 05:04 PM
Advanced Member Group: Members Posts: 4,652 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Failure to go to the park position is a wiring issue.
If my memory is any good..... early car with dash mounted switch ? it is more likely at the switch. If it is a later car it is probably at the motor. |
A&P Mech |
Mar 15 2018, 08:54 AM
Member Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
mgphoto and rgalla9146, thanks for the Information! I will pull the wiper motor and take a look.
malcolm2 |
Mar 15 2018, 09:24 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I see mucho driver's side windshield trim overlap. Is this the factory setting? No this is the factory setting: This is good info. Looks "funny" tho, so I am guessing not very many folks have them adjusted like this. I like my drivers wiper to be a bit longer and stop a bit shorter. It does touch the trim. Looks like it touches the trim here too. |
Lo-Fi Version | Time is now: 25th November 2024 - 10:51 PM |
