> Low idle and stalling, 1.7 FI
sobolewski
post Jun 5 2005, 08:57 AM
Help!
After running the car on the freeway on a warm day the RPMs will be very low once I exit and come to a stop. About 5 minutes after that the engine will finally stall. It will restart if I put the pedal to the floor and crank away. It continues wanting to stall unless I continuously give it gas. Once it cools down it runs fine.
I have had a tune up but it hasn't changed the outcome.
Any suggestions?
1972, 1.7 FI
Thanks!
Bleyseng
post Jun 5 2005, 09:48 AM
Aircooled Baby!
#1 the CHT is starting to go and its going rich
#2 the MPS is cracked and its starting to go rich-check it with a vacuum pump
#3 the idle is set when cold but should be set when the engine is hot
Joe Bob
post Jun 5 2005, 09:53 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Add intake leak.....
- Lo-Fi Version Time is now: 22nd December 2024 - 12:22 AM
