Dipping a 914 - Prices?, I'm Planning on getting my tub dpped........ |
BPic |
Mar 19 2018, 10:08 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I am considering getting my car dipped to strip off everything to bare metal. After stripping they dip it again to neutralize and then again for rust inhibitor.
Has anyone done this? If so what was the charge? I have a place near my house in Miami that will do it for $2800. Does that seem high? (IMG:style_emoticons/default/confused24.gif) |
sithot |
Mar 19 2018, 10:11 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
I am considering getting my car dipped to strip off everything to bare metal. After stripping they dip it again to neutralize and then again for rust inhibitor. Has anyone done this? If so what was the charge? I have a place near my house in Miami that will do it for $2800. Does that seem high? (IMG:style_emoticons/default/confused24.gif) Preferred to sand blasting. You never get all the sand out. |
Krieger |
Mar 19 2018, 10:23 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
There are a few threads here. Do a search. The heater channels in the longs are not happy with that method.
Mar 19 2018, 10:41 AM
It will dissolve the heater tubes. You will also need to E-cote the chassis. Dipping strips all the seems and inner channels to bare metal. These will rust unless you put some protective coating back on. Epoxy or etch primer wont flow to all these spots. Plan on $5-6K when all done.
dr914@autoatlanta.com |
Mar 19 2018, 11:12 AM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I agree, no dipping! media blast the sheetmetal, sand blast the underneath, some are even doing the blasting with dry ice to avoid all of the media debris
It will dissolve the heater tubes. You will also need to E-cote the chassis. Dipping strips all the seems and inner channels to bare metal. These will rust unless you put some protective coating back on. Epoxy or etch primer wont flow to all these spots. Plan on $5-6K when all done. |
Coondog |
Mar 19 2018, 11:32 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Plus one on the dry ice method. I watched a Boeing 737 stripped of its paint using this method. Pretty awesome process. |
McMark |
Mar 19 2018, 11:52 AM
(IMG:style_emoticons/default/agree.gif) It feels like a thorough and necessary process, but the cost-benefit doesn't work in my opinion. Too many compromises and too many concerns. I also prefer the dry ice or baking soda blasting.
Mar 19 2018, 11:57 AM
I wish there was one, great way to remove paint but there isn't. Soda, plastic media and dry ice all work on paint. sand, coal slag or dupont's media for rust. media gets inside of seams and crevices. Dustless blasting/wet media leaves sand or glass inside nooks and crannies that can rust later. Most blasting won't remove seam sealer. Dipping isn't great for a unibody, even if you e-coat.
It also depends where you live and the time of year. We get flash rust within a day or two unless its winter time. |
BPic |
Mar 19 2018, 12:02 PM
This is why I use this website! I forgot about the heater tubes in the longs. (IMG:style_emoticons/default/051103-stupid4.gif) Dry Ice or Soda blasting it is.
Thanks I appreciate everyone here! (IMG:style_emoticons/default/clap56.gif) |
GeorgeRud |
Mar 19 2018, 03:41 PM
What about the Dustless Blasting system that’s being advertised on the Velocity Channel programs? It seems much nicer than sandblasting, but I don’t know any particulars. The easier cleanup seems attractive.
McMark |
Mar 20 2018, 07:18 AM
What about the Dustless Blasting system that’s being advertised on the Velocity Channel programs? It seems much nicer than sandblasting, but I don’t know any particulars. The easier cleanup seems attractive. It's dustless not 'media-free'. So it's essentially normal media blasting carried by a liquid instead of just air. So the dust that's created is just washed away. But you're still media blasting -- just like using air -- and only preventing the dust. Soda is highly water soluble: so you can wash the car out and get rid of the media. Yes you're hitting it with water, but I don't feel that's an issue over time. Dry Ice 'melts' into a gas: so once you're done blasting, the media literally disappears. Neither of these medias are particularly harsh, so any heavy coatings (like undercoating) won't be removed by soda/ice. The true way to 'geek out' on stripping your car, in my opinion, is to put the chassis on a rotisserie, and spend as much time as you can stand cleaning with scrapers and wire brushes. Think of the media blasting as the final step that comes in to clean up only what you missed or couldn't reach effectively. But that's a time commitment reserved for only the most thorough of restorations. I've only done it a couple times. Mostly it's just not necessary to go to that level for most restorations. |
rgalla9146 |
Mar 20 2018, 09:34 AM
What are the issues if the heater tubes are removed before dipping / ecoat ? |
McMark |
Mar 20 2018, 10:57 AM
No issues, just compromises. So everybody will weigh the factors differently.
I don't like the idea of cutting and repairing the main structural member of the car for a superficial* process (dipping). Can you do the work correctly and safely? Absolutely. But what do you gain from all your effort? And especially if you're looking to eCoat the body afterwards. You'll still have to go back and weld the longs shut again. That welding will leave a bare metal section that's been heated (which increases surface rust penetration). Welds will always rust before 'virgin' metal. So your eCoat process, which is typically chosen for its 100% coverage, will never live up to 100% coverage on our cars. So then you're eCoating to get it 'mostly covered', and if you're only getting 'mostly covered' how much different is that than just shooting the inside of the long with a wax/oil protectant like Cosmoline? For me, the whole question of rust prevention must also take into account two important factors: 1) What life did the car have in the past that made it rusty? 2) What type of life will you give the car when you're done? If the car is rusty from sitting outside for 10 years, and you're going to park it in a heated garage 100% of the time, then you really aren't at much risk for repeating the past. Your restored car in the garage will never end up like the 10-years-in-a-field car. *I'm calling dipping superficial, because IMHO there are other more effective processes for stripping a car, and the difference between those processes and dipping is the part that I'm calling superficial. i.e. cleaning the inside of the longs on a solid car is superficial. |
Mueller |
Mar 20 2018, 11:03 AM
I have not tried it on the 914, however on my Volvo 242 it had the tar like undercoating in the wheel wells so I used my oxy/acet torch and basically "cooked" the tar and turned it into carbon which which came off easier with my soda blaster.
jmitro |
Mar 20 2018, 12:21 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I dipped a BMW 320 for $1500 about 6 years ago.
If the car has heavy undercoating, media blasting will not get that off. I was building a racecar and wanted every ounce of weight off the car. |
rick 918-S |
Mar 20 2018, 02:04 PM
Hey nice rack! -Celette Group: Members Posts: 20,422 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Love the process. Totally depends on the car and how far you have gone with the welding and panel replacement. This car has all NOS body panels, inner structure, floors from the trunk to the cowl. Thick rubber under body coating. The car was cooked at 800 deg. dipped, rinsed twice and e-coated. There is no way I could have done with top coatings what was done internally for 3k. Hell, I couldn't crawl under the car with a wire wheel and strip the rubber coating for 3k! The wheel wells were 3/4" and thicker in some places. The way I look at it is this. I would rather only have to protect four horizontal spot weld flanges and four vertical butt welds on the longs than every internal patch and weld point over the whole car.
This process is not for every car. Only extensive rebuilds worth the investment. |
rick 918-S |
Mar 20 2018, 02:06 PM
mb911 |
Mar 20 2018, 04:13 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
rick 918-S |
Mar 20 2018, 05:06 PM
Mercedes 280 SL Pagoda
mb911 |
Mar 20 2018, 06:04 PM
Lo-Fi Version | Time is now: 25th April 2024 - 06:16 PM |
