> Boxster axles
partwerks
post May 10 2018, 01:24 PM
From what I understood the 5 speed Boxster trans, the axles were two different lengths. At the start he said the axles fit, I thought something didn't seem right, but now that we finally got to doing the wheel alignment, I was correct in that the passenger side is too short. He said about 1/2".
Does anyone know what the correct length of axle would be on the passenger side using the 5 speed Boxster trans, and if so, where I can acquire one at?
burton73
post May 10 2018, 02:04 PM
Senior member, and old dude
Renegrade in Las Vegas does these with V8s call them and ask.
Bob B
Chris914n6
post May 10 2018, 03:22 PM
Jackstands are my life.
QUOTE(burton73 @ May 10 2018, 01:04 PM) *
Bob B
They use the "S" 6 speed. Different setup.
Mark Henry
post May 10 2018, 04:13 PM
that's what I do!
Try Sway a Way
https://swayaway.com/product-category/axles/
Worst case they will make custom axles for you.
krazykonrad
post May 10 2018, 06:30 PM
(IMG:style_emoticons/default/pirate.gif)
Not to hijack your thread, but I played football at Hastings College right down the road from you.
Konrad
partwerks
post May 10 2018, 07:50 PM
QUOTE(krazykonrad @ May 10 2018, 04:30 PM) *
Konrad
I did a lot of blood drives over at that college also.
Andyrew
post May 11 2018, 09:35 PM
Spooling.... Please wait
Are you using the boxster trans on the 914? Sorry I think I miss read your post first time. Mike bellis had a 5 speed boxster/Passat unit in the car before he put the 6 speed. Check his build thread for measurements.
I have one in my car but I removed the trans mounts and moved them as they are offset in a 914 and it was also in the way of the shifter assembly. I have equal length axles and use an off the shelf vw Bus axle like rennegade hybrid uses on their 500hp axle solution.
partwerks
post May 22 2018, 05:08 PM
Is anyone else using the 5 speed boxster trans with the LS3 engine that could advise me on the axle lengths?
yellowporky
post May 22 2018, 10:23 PM
I have a boxster 5 speed in one of my cars and as far as i recall the reason for the different lengths was because of an offset in the trans and has nothing to do with the type of engine. my rear suspension is not 914 so i have no idea if the boxster axels and trans would work with the 914 suspension or as others have mentioned you might need custom axels or spacers.
Good luck.
Chris914n6
post May 22 2018, 11:19 PM
QUOTE(partwerks @ May 22 2018, 04:08 PM) *
An LS3 will destroy a Boxster/VW/Audi 5 speed. All the adapters I've seen have been to the 6 speed as it's more than twice as beefy.
The 5 speed is only a little bit stronger than a built 914 box.
Andyrew
post May 23 2018, 10:01 AM
QUOTE(Chris914n6 @ May 22 2018, 10:19 PM) *
Exactly.. The only way Im getting away with the 5spd box on my car is with how large my turbo is the initial impact to the trans is much lower, regardless of my actual HP.. I wouldnt put anything more than a 5.3 in front of the 5spd, even then I wouldnt expect it to last very long. A 4.8 would be a decent match.
Andyrew
post May 23 2018, 10:04 AM
QUOTE(Chris Scott @ May 22 2018, 09:23 PM) *
Good luck.
Correct. When I mounted my setup I equally spaced the trans so the axles would be the same length, this allowed me to run off the shelf axles. Location of the axles placed the whole engine setup for me. I did so to avoid the issues Bellis ran into with the popping out of the axles.
JRust
post May 23 2018, 10:17 AM
I think the consensus is you better get the 6 speed Lyle. I would try to get with Mike Bellis to make sure you get the right stuff. He's got it down pat
partwerks
post May 24 2018, 07:23 PM
If I decided to go that route, where would be a good place to get the 6 speed, and everything I would need to complete the setup?
Mike Bellis
post May 25 2018, 06:59 AM
Resident Electrician
My setup is totally custom. I run 930CV's with both my 6 and 5 speed. My 5 speed has custom 108mm stubs. I use the same axles on both with the addition of a 7/16 CV spacer that doubles at the magnetic speedo pickup.
I purchased multiple axle lengths until I found the sweet spot.
I run non-plunging CV's. This requires me to run sliding axles. (normal CV are plunging with fixed axles).
I fine tuned my setup to work with either tranny.
I spoke to Lyle and I'm not convinced that his mechanic have the skills to complete this build. I base this on some of the basic component setup confusion on his part.
If there is an "easy" way... Make your build use the same size CV for both the inner and outer. Then buy the correct length axles. They will be about 3/4"-1" different in length.
Remove the rear wheel and disconnect the shock. This will allow you to easily raise and lower the suspension until you find the closest distance between the tranny and wheel hub. Take this shortest measurement and subtract 1/2" this is your maximum axle length. Then buy axles with a spline count that matches your CV's.
If you have 100mm CV's, you spline count most likely is 33. If you run 108mm CV's you spline count is 28. If both CV's match, axles can be purchased off the shelf. If you need 33 on one side and 28 on the other, this requires a custom machined axle.
If you have a 5 speed, this is 100mm. If you have a 6 speed, this is 108mm.
Mike Bellis
post May 25 2018, 05:52 PM
If you do 6 speed, it will have 108mm stubs. You can buy 108mm wheel stubs from an early 911 and run 930 CV's. This would be the easiest way to complete the axle build. The cost is a 6 speed tranny.
- Lo-Fi Version Time is now: 12th June 2026 - 12:44 AM
