Loose Rear Control Arm |
EdwardBlume |
Jul 11 2003, 08:36 PM
I just noticed while I was changing tires that my drivers side rear inner swing arm has about 1/4 inch play where the 3 17MM bolts are. The bolts don't seem to tighten either.
What's the cause / problem? Fix? THANKS |
ChrisReale |
Jul 11 2003, 09:13 PM
Are they stripped?
EdwardBlume |
Jul 11 2003, 11:24 PM
I didn't pull the bolts but they seem to be on very tight. This is where the "shim" is for the camber adjustment.
Is it common for these bolts to strip??? |
ChrisReale |
Jul 12 2003, 12:17 AM
Are they torqued to 50 lbs? Each? Other than that, I have no idea. Do not over tighten them, I can only guess how fun it would be getting those bolts out after they break (IMG:style_emoticons/default/headbang.gif)
Dave Cawdrey |
Jul 12 2003, 12:36 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Maybe the plate circled below is F'ed up (bent, missing, etc.)
Just an idear... Attached image(s) |
EdwardBlume |
Jul 12 2003, 06:43 AM
THANKS
The plate is there, it just shifts. I think its off because of the camber angle. Time for new bolts? Thanks for the torque setting, I'll give it a go. THANKS AGAIN |
Lo-Fi Version | Time is now: 24th June 2024 - 05:25 AM |
