2056cc with 94mm dished, can someone explain how ? |
Literati914 |
May 27 2018, 09:22 PM
Senior Member Group: Members Posts: 1,664 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I was under the impression that a 2056cc engine was always a 96mm bore x a 71mm stroke... but the following link is a set of 94mm pistons and specifies 2056cc engine. They are dished pistons and I'm wanting to understand how this works out. Anybody understand how this works and can offer an explanation? thx.
http://www.texasaircooled.com/catalog/AA-P...R-2.0-Case.html |
Beebo Kanelle |
May 27 2018, 09:29 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Typo.
Literati914 |
May 27 2018, 09:46 PM
jcd914 |
May 27 2018, 09:58 PM
Typo. No, it's not... AA themselves describes it the same way, as does others that offer the VW9400T4 model piston set. It is a typo, it just has been passed around. You can't get to 2056 with 94mm pistons and 71mm stroke, the math doesn't work. They are AA pistons and they made the typo in their description of the piston set. Resellers are using AA's description. There is no compression ratio listed either. Jim |
May 27 2018, 10:38 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
94mm x 71mm gives you 1971cc.
You can get a 2056cc motor with 94mm pistons, but you need a longer stroke to do it. About 74.3mm would do it. But that's not what they have in the ad; they are saying 94x71. I agree with Jim; it's a typo that has propagated. --DD |
Literati914 |
May 27 2018, 10:40 PM
McMark |
May 28 2018, 05:50 AM
Displacement is just math. There can be no tricks. 94x71 is 1971. 96x71 is 2056. That's it and nobody can change that. Anyone or anything that says differently is mistaken or lying.
Mark Henry |
May 28 2018, 06:33 AM
It is a typo, but just be aware those are the AA part number for 94mm dished pistons. It' should say 1971cc
Literati914 |
May 28 2018, 09:10 AM
It is a typo, but just be aware those are the AA part number for 94mm dished pistons. It' should say 1971cc Yes the AA website says 2000cc as a general description, rounding up from 1971 just like Porsche did (2.0L).. as I mentioned Texas Aircooled is the only one who has it completely wrong by specifying 2056cc. I now assume typo too (like the rest of y'all), highly doubt that's intentional tho. |
settador |
May 28 2018, 09:44 AM
Newbie Group: Members Posts: 31 Joined: 16-May 05 From: Lee, NH Member No.: 4,086 Region Association: None |
volume of a cylinder = pi r squared h, so 3.14159 x 48squared x 71 = 513914.29...mm cubed. Multiply by 4 to get 2,055,657.17 cubic mms, then divide by 1000 to convert to ccs and you end up with 2055.657 cc displacement....
TheCabinetmaker |
May 28 2018, 10:02 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That's for 96mm pistons. The pistons in question are 94mm.
settador |
May 28 2018, 10:08 AM
Lo-Fi Version | Time is now: 26th September 2024 - 05:30 PM |
