Idle temperature, CHT under #3 |
nditiz1 |
Jun 24 2018, 05:45 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I just finished rebuilding my 2056 and while I'm not done setting everything (carbs), it was idling pretty smooth around 1100 RPM. The temp on the CHT gauge raised to 300 after about 20 mins. Just checking if this is normal idle behavior. The stock temp gauge didn't go up much. Running 10/40 Brad Penn. 84 degrees and humid outside (car was in the garage)
era vulgaris |
Jun 24 2018, 06:03 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
The typical fully warmed idle temp for my old 2270 on #3 was around 325. You're in good shape (IMG:style_emoticons/default/biggrin.gif)
Also, in regards to your oil pressure from the post in your other thread...my cold oil idle pressure was around 60 and warm was approx 18 (or just slightly under 20). If it was the middle of the brutal days of summer it would be around 15 at idle. |
VaccaRabite |
Jun 25 2018, 06:47 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
That seems about right for mine too.
You will see temp changes WAY faster with the spark plug meter then the oil temp meter. They are measuring different things. Oil responds much faster then the spark plugs, and #3 is the hottest plug. Zach |
falcor75 |
Jun 25 2018, 06:56 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Mine runs around 250 at idle and 325 when cruising at around 3000 rpm and ambient being around 70.
Mark Henry |
Jun 25 2018, 08:23 AM
Gas engines are not meant to be left idling like a diesel, they will actually overheat if left idling for long periods of time.
I agree it's normal. |
McMark |
Jun 25 2018, 10:24 AM
Timing and carb tuning first. (IMG:style_emoticons/default/wink.gif)
Make absolutely sure you've correlated/synced what you see with a timing light and what the 123Ignition says. |
nditiz1 |
Jun 25 2018, 12:11 PM
Thanks all!
I definitely need to ensure the timing is matching the 123. The carbs were actually in sync as far as the idle settings. I still need to adjust air/fuel mixture. |
VaccaRabite |
Jun 25 2018, 06:58 PM
When you sync your carbs and set idle, REMEMBER that you idle will change when the engine is hot. If you set idle while the engine is still warming up, your nice 1100 rpm idle will be an 1500rpm idle when warm.
Waiting for the engine to be warm will ensure a good driving idle, but may make starting the car a bit more tricky, since there is no choke. Zach |
Rand |
Jun 25 2018, 07:22 PM
You will see temp changes WAY faster with the spark plug meter then the oil temp meter. They are measuring different things. Oil responds much faster then the spark plugs, and #3 is the hottest plug. Zach You all know Zach meant head temps respond faster than oil. He knows what he's talking about, but just to clarify in case someone took this wrong. Oil responds slower. Head temps are the quickest tell. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:25 PM |
