bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
We talk about removing side warts a lot, but I haven't seen much on the actual process. I have a good idea how I would proceed, but since so many have BTDT, I thought I'd see if you might share tricks, wisdom, and pics. (IMG:style_emoticons/default/beerchug.gif)
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Weld in a metal disk the size of the hole. Tie off the wires.
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,768 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Nothing special on my end ,just as Mark said.: Metal disc welded in.
I used the wire for the “wart” to power my front euro park lamp. So the orange signal portion only lites in signal mode. |
bbrock |
As you know, I like to over think... Yes, weld disc in the middle, but did you pre-curve it before to match the subtle curve of the fender, just weld in flat disc then hammer and dolly to shape after, or....? Then there are 3 additional holes to fill. My instinct is to just zap them shut using a copper backing spoon - slowly and carefully to avoid warping the fender. The goal, of course, is to accomplish without having to use filler. It looks like a simple enough task, but given the location in the middle of a thin and gently curved panel, I suspect there is a little more to it.
I have my own plans for the wires but will save that as a surprise. (IMG:style_emoticons/default/beerchug.gif) |
Dion |
Ok amateur here. I didn’t even think about the curves! I think I solved that
with filler :-( ......plus the flares on mine creep into that area as well. |
bbrock |
Ok amateur here. I didn’t even think about the curves! I think I solved that with filler :-( ......plus the flares on mine creep into that area as well. Ah! I forgot about your flares. That would change things. Although my goal is always to patch without needing filler, I don't think I've completed a single patch that doesn't need at least a touch of filler. But less is more of course (IMG:style_emoticons/default/beer.gif) |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
As you know, I like to over think... Yes, weld disc in the middle, but did you pre-curve it before to match the subtle curve of the fender, just weld in flat disc then hammer and dolly to shape after, or....? Then there are 3 additional holes to fill. My instinct is to just zap them shut using a copper backing spoon - slowly and carefully to avoid warping the fender. The goal, of course, is to accomplish without having to use filler. It looks like a simple enough task, but given the location in the middle of a thin and gently curved panel, I suspect there is a little more to it. I have my own plans for the wires but will save that as a surprise. (IMG:style_emoticons/default/beerchug.gif) Getting that curve right is a real benefit of removing the wart. Wish I had some good advice, but I'm just a spectator. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:00 AM |
