> oil temp sender cover plate torque?
LCOX
post Jul 11 2018, 10:40 AM
Does anyone know the proper torque on the 2 small 6mm bolts that mount the oil temp sender cover plate to the bottom of the engine case? The plate that has the big red o ring?
Dave_Darling
post Jul 11 2018, 01:23 PM
914 Idiot
Very little, on the order of 5-7 lb-ft. Google "torque M6 bolt into aluminum" for more details.
--DD
bandjoey
post Jul 11 2018, 01:40 PM
bandjoey
The Haynes book is 6 I think. Someone will confirm this soon.
Mark Henry
post Jul 11 2018, 04:03 PM
that's what I do!
IIRC They're 7.5 ft/lbs or 90 inch pounds.
The 996 has a million M6 screws, all 90in/lbs. OK... I'm exaggerating...but it's a lot. (IMG:style_emoticons/default/smile.gif)
Part of a T4 rebuild I just helicoil those two holes, I'm always finding them stripped out by PO's. If it won't torque up it's stripped.
- Lo-Fi Version Time is now: 9th November 2026 - 02:32 PM
