> Electric Windshield Washer Conversion 914, Complete kit
rothaus
post Jul 15 2018, 01:20 PM
On the Porsche 914 the original windshield washer is operated by compressed air supplied from the Spare tire.
Here is the switch that replaces the original valve in the steering column. With this switch installed, an electrical washer pump can be operated with the wiper switch.
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1531682421.1.jpg)
I got some requests if it would be possible to have a complete kit available. So I put together a complete kit, and also have now options. It's not yet on the website, however here is the information with the options and prices.
Option 1: Switch only - $15.00 PLUS $5 s/h
Option 2: Relay kit only - $35.00 plus $6 s/h
Option 3: Switch and relay kit - $50.00 plus $6 s/h
Option 4: Option 3 plus pump - $72.00 plus $8 s/h
The switch is pre-wired and includes the mounting plate and some washer for adjustment if needed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.1.jpg)
The relay kit includes all wires, a fuse, and connectors, shrink tubing, bolt to mount the relay, as well the disc for the filler cap.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.2.jpg)
Here is the wire diagram which will also be included in the step by step instructions.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg)
The switch can be ordered at http://carmagic.us/washer.html
Cheers
Engelbert
orthobiz
post Jul 19 2018, 04:24 AM
I did this conversion in the 80's on an old car of mine with Radio Shack parts. I wish this thing was available at the time, way more elegant and a good value. Betcha some would like the motor and tubing as a complete bundle...
Paul
bretth
post Jul 19 2018, 06:20 AM
Awesome! Beats having windshield fluid dripping in your lap.
Brett
amfab
post Sep 13 2018, 08:38 PM
well thats just a fantastically simple solution. Will buy one when I get to reassembly
cary
post Sep 15 2018, 09:21 AM
That's cool ............. Well done.
I think I'll inventory a few for future projects.
BillC
post Oct 23 2018, 04:25 PM
I installed one of these in my 914 a couple of weeks ago. Very straightforward installation, and basically went as well as you could expect.
A couple of minor points, though:
  1. You'll have to drill out the hole in the wiper switch frame that the old valve pin goes through, since the pin in the new switch is a larger diameter. Do this carefully, so you don't damage the lever end that presses on the switch pin.
  2. I added a plug on the switch wires, a little bit further out than the location for the stock harness plug, to allow the new wiring to be disconnected. If you don't do this, you'll need to pull all the new wiring if you ever want to remove the wiper switch or the column. Fortunately, with the hoses out of the way, there's plenty of room for a small plug to fit through the column. Maybe Rothaus can offer a plug/connector as an option?
buck toenges
post Feb 7 2019, 03:19 PM
Can somebody help me with the electrical hook up? I have 2 wires from the switch and I have 2 wires from the pump. How do I hook those wires up and get power to the pump?
Thanks,
Buck
rothaus
post Feb 7 2019, 07:11 PM
Here is a video from A electric washer pump conversion. This may help. The only difference is that there will be no switch to be installed in the dash, and the lever can be used to operation the electric pump.
Video
davep
post Feb 8 2019, 10:45 PM
914 Historian
The wiring is very simple. From a fused 12 volt source (fuse panel) run a hot wire to the pump positive side. From the pump negative side run a wire to the switch. From the other side of the switch run a ground wire to the multiple ground stud near the fuse box. I am not sure what the switch rating is, so a relay could be added to keep the switch current in line with it's rating. I came up with a mounted switch years ago to do this very task.
http://www.914world.com/bbs2/index.php?sho...7916&st=29#
rothaus
post Feb 10 2019, 05:04 PM
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch.
Hope this will help.
Thanks
Engelbert
cary
post Jan 25 2020, 12:18 AM
Bump
russmoffat
post Feb 28 2020, 08:34 PM
I did this exact setup here. Wondering if anyone else has had issue with the switch going off unintentionally? Seems like it is too sensitive and has gone off a few times for me when I didn’t want it to. Considering inserting a spring to ensure that it stays put unless you put pressure on it?
Mikey914
post Feb 29 2020, 08:27 PM
The rubber man
QUOTE(orthobiz @ Jul 19 2018, 02:24 AM) *
Paul
I can supply tubing if you need it.
FUEL14
post Sep 9 2020, 06:06 PM
Region Association: Australia and New Zealand
If I want to use the column stalk for the washer, can Engelbert's switch be used in conjunction with SirAndy's method as described here http://www.914world.com/specs/tech_el_washer.php ?
FlacaProductions
post Sep 11 2020, 09:12 AM
@FUEL14 - yes. I did just that. Just use the new column switch for step 8 in Andy's method.
FUEL14
post Sep 11 2020, 06:07 PM
QUOTE(FlacaProductions @ Sep 12 2020, 01:12 AM) *
Fantastic, thanks for confirming.
ThinAir
post Oct 21 2020, 02:31 PM
Best friends
Where has this been all my life? Ordered!!!!!
DRPHIL914
post Apr 25 2021, 04:53 PM
Dr. Phil
QUOTE(rothaus @ Feb 10 2019, 07:04 PM) *
Thanks
Engelbert
since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions.
Zaffer
post Apr 25 2021, 08:10 PM
Will definitely order soon as I expect to have the car (possibly) back on the road this year.
cary
post Apr 25 2021, 08:20 PM
We've installed a couple without any issues in the shop.
I'll have to ask the clients.
- Lo-Fi Version Time is now: 28th November 2024 - 09:50 AM
