Electric Windshield Washer Conversion 914, Complete kit |
rothaus |
Apr 26 2021, 05:26 AM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. This is basically a Bosch type relay. 87a is normal activated. 87 is activated when the coil is energized. So 87a is not used. |
DRPHIL914 |
Apr 26 2021, 08:18 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. This is basically a Bosch type relay. 87a is normal activated. 87 is activated when the coil is energized. So 87a is not used. super thanks for the response, i am going to install this relay tonight! i should have a working washer pump soon! yay! when i go the car 12 years ago i had dry rotted water lines leaking, and i changed them out but still had issues, 2 years ago after paint and body , i put in the new lines and squirters with anticipation of getting a pump. just nice to. wrap up a few small details like this that didn’t get done at the time. |
rothaus |
Jun 7 2021, 03:26 PM
I added some options and now a complete kit is available. Check the first post where I added all the info.
Thanks Engelbert |
Warren914 |
Jun 8 2021, 09:22 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
The only issue I see using that relay is the potential of the relay having a built in diode across the coil. If there's no diode you're good to go. Adding a reverse bias diode will reduce sparking across the switch when the relay is released, potentially eliminating another problem down the road. [/quote] since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. [/quote] |
Lo-Fi Version | Time is now: 28th November 2024 - 11:41 AM |
