Brake Pedal Won't Release |
sdthomas |
Aug 8 2018, 09:31 AM
Member Group: Members Posts: 64 Joined: 14-June 11 From: Seattle Member No.: 13,193 Region Association: Pacific Northwest |
As I was driving home from work yesterday, I noticed my brake pedal seemed to get firmer and firmer. It got the point where just tapping it slightly would engage the brakes, as though there was no more travel in the pedal. When I got home I noticed all four wheels were very hot to the touch so the brakes had clearly not been fully releasing. I let it cool down and checked the pedal and it felt normal but now I'm worried about driving it.
What could cause this? |
Eric_Shea |
Aug 8 2018, 09:42 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Remove the carpet and floorboard and check for fluid in the pan. This would mean a failed/failing master cylinder. When that happens (and just from age) your old nylon bushings can fail. It is probably time for a new MC and Pedal rebuild.
dr914@autoatlanta.com |
Aug 8 2018, 09:52 AM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
probably bad pedal cluster bushings causing the pedal to stick the brakes to get hot boiling the fluid
As I was driving home from work yesterday, I noticed my brake pedal seemed to get firmer and firmer. It got the point where just tapping it slightly would engage the brakes, as though there was no more travel in the pedal. When I got home I noticed all four wheels were very hot to the touch so the brakes had clearly not been fully releasing. I let it cool down and checked the pedal and it felt normal but now I'm worried about driving it. What could cause this? |
sdthomas |
Aug 9 2018, 06:11 PM
OK I finally was able to check out the pedal cluster. It was rebuilt about 4 years ago the bushing still looked to be in good shape. No sign of any brake fluid. I drove it around the block and the pedal froze up again. I lifted the front end and could barely turn the wheels. It's as though the MC isn't releasing when pushed in. What's the next step?
Aug 9 2018, 06:15 PM
When’s the last time you replaced the MC and soft lines.
sdthomas |
Aug 9 2018, 06:31 PM
I haven't replaced the MC since I've had owned (about 5 years). The soft lines were relatively new when I bought it so I suppose are about due for replacement. Is there a way to verify that the MC is the problem?
porschetub |
Aug 9 2018, 07:14 PM
I haven't replaced the MC since I've had owned (about 5 years). The soft lines were relatively new when I bought it so I suppose are about due for replacement. Is there a way to verify that the MC is the problem? The soft lines can look fine on the outside and be buggered on the inside,is your master cylinder pushrod returning freely after pushing the pedal in ? is the fluid clean or rusty coloured? whole bunch of stuff to look at,sounds like sticking caliper pistons to me...sure Eric will sort it for you. |
sixnotfour |
Aug 9 2018, 07:22 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
make sure you have a bit of free play (rattle) before the pushrod hits the master to tight does just as described
porschetub |
Aug 9 2018, 11:08 PM
mgphoto |
Aug 10 2018, 08:06 AM
"If there is a mistake it will find me" Group: Members Posts: 1,336 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Rear venting clearance to tight, check .004"
Tbrown4x4 |
Aug 10 2018, 08:57 AM
Senior Member Group: Members Posts: 702 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
If all 4 brakes are dragging, the last thing I would suspect is a hose or stuck caliper.
Your brake master cylinder has two rubber cups inside (primary and secondary) that seal inside the bore and build pressure when you push on the brake pedal. Just in front of these cups is a small inlet port. As you use the brakes and heat up the fluid, it expands, and travels back to the reservoir through the ports. If there is not enough pedal free play, these ports can be blocked by the rubber cups. The fluid has no where to go when it expands, and the brakes drag. The first thing I would check is pedal free play (as suggested above), and make sure the pedal returns to the stop every time. That said, your master cylinder looks a little crusty. There should be a rubber boot on the end to keep dirt and moisture out. I would suggest replacing it and bleeding the brakes. Might be a good time to replace the hoses too. (Also suggested above.) I would recommend PMB for all the replacement parts. 914 rubber has a nice M/C for sale as well. I just rebuilt my front calipers, and replaced the M/C and hoses. A little challenging to bleed, but the results are worth it. |
sdthomas |
Aug 10 2018, 11:41 AM
Thanks for all the advice; it's super helpful. First things first though: how do I free up the brakes? If I just open up a caliper bleeder and let out some fluid will it relieve pressure in the system?
Spoke |
Aug 10 2018, 11:42 AM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
It's as though the MC isn't releasing when pushed in. What's the next step? So after you drove it and the brake pedal froze up, did you check the free play in the pedal to eliminate it from suspicion? The pedal should be loose before it contacts the plunger on the MC. You can check the free play with your hands as it's more sensitive than pressing with your foot. Was the pedal loose with free play when the brakes were froze? |
wndsrfr |
Aug 10 2018, 07:06 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Thanks for all the advice; it's super helpful. First things first though: how do I free up the brakes? If I just open up a caliper bleeder and let out some fluid will it relieve pressure in the system? It certainly should...and if the wheel won't rotate then it's a stuck caliper piston.. |
sdthomas |
Aug 11 2018, 01:11 PM
The free play goes away once you push on the pedal. I checked it this morning and there was a little play in pedal. But it went away after using the brakes.
I guess at this point I'm wondering if there's a quick fix, or is time to refurbish everything (MC, calipers, lines, rotors) which will put an end to the 'fun car' for the year (IMG:style_emoticons/default/sad.gif) So after you drove it and the brake pedal froze up, did you check the free play in the pedal to eliminate it from suspicion? The pedal should be loose before it contacts the plunger on the MC. You can check the free play with your hands as it's more sensitive than pressing with your foot. Was the pedal loose with free play when the brakes were froze? |
KELTY360 |
Aug 11 2018, 01:19 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Do it in increments Shawn. Start with the MC; it's a likely culprit and you're going to end up replacing it anyway as part of a more complete process.
Tbrown4x4 |
Aug 11 2018, 01:38 PM
Agreed. Do the master cylinder first. Not too difficult. The worst part is pushing the supply lines into the grommets. I have a pressure bleeder you can use, if nobody closer does.
Aug 11 2018, 02:08 PM
Aug 11 2018, 02:29 PM
I would look at 914rubber’s MC that uses screw in lines.
steuspeed |
Aug 11 2018, 03:16 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Sounds like MC issue. Maybe just blockage? I did mine last year. Pedal was going to the floor. I bought a 17mm from Pelican Parts. Lots of debate on stock 17mm vs 911 19mm. Be sure to bench bleed before install. I could not get the air out until I used a pressure bleeder. Also, getting the tubes back in the top of the MC is not easy. Could be a trick?
Lo-Fi Version | Time is now: 25th April 2024 - 11:07 PM |
