Through-the-Hood Filler Kit |
Marek |
Oct 27 2018, 01:38 PM
Newbie Group: Members Posts: 20 Joined: 27-April 15 From: Copenhagen , Denmark Member No.: 18,672 Region Association: None |
FS: Through-the-Hood Filler Kit for 914
Finally The kit contains all you need, to make your "through the hood filler look" complete with out any welding or painting !!!! the kit includeds * Original 100mm vented Blau fuel cap, in stainless steel with a 5 hole fin * A bolt on fuel neck you screw direct on to your tank , gaskets to adjust the height you can combine the gasket depending on the height you need * A "Dog bowl" to overfill fuel or rain it has a 1 m long drain tube, on top it has a rubber seal, so its tight closing against the hood, without damage * A Stainless bezel to mount on the hood, by screwing it on, with the incl 6 screws btw every bolt , screw etc you need are included incl a shortl instruction the only work you have to do your self is *messure up and drill a hole 127 mm in your bonnet , use some epoxy primer on the edge *remove the expansion tank on top of the tank by unscrewing the 8 bolts *screw on the Fuel kneck , it got the correct angle put gaskets under it to get the height ( BE AWARE YOU CAN ADJUST THE TANK IT SELF A BIT ,SO MAKE SURE ITS STRAP´ ON THIGHT BEFORE YOU DO ANYTHING ) *put on the dog bowl ,mount the gasket and drain tube ,use silicone to set the height of the dogbowl *screw on the top stainless or silver bezel with the included 6 stainless screws to the "under the hood" bezel , you might need to shorten the screws os they dont scrath the rubber seal , and use a drop of loctite to be sure the screws a lock thight A silver mat painted cap / bezel option is available , see pics later in the post For those of you that are not a fan of the screw on bezel on the hood , there is a option! For the 911 kit we offered a square adapter you see on the last picture its easy and simple and you get the perfect "hole in you hood" but its requiers welding / paint job This version is also on stock now with a Silver or polished Price 350 EURO + shipping ( to USA 37€ ) - 445 USD incl postage to US Importen Do note !!! I am shipping by DHL from Germany which is the cheapest option, I have been using them the last 10 years , so full tracking number never had a problem BUT expect up to 4 weeks delivery , DHL said its long security checks in at US customs Paypal ok, BUT save 25 EURO by a direct bank wire By interest drop me a mail early911parts@gmail.com I have posted some pictures below and much more to come ASAP Regards Marek ( Denmark ) Attached thumbnail(s) Attached image(s) |
Marek |
Oct 27 2018, 01:44 PM
The finish look mounted More installation pictures will follow ASAP Marek Attached image(s) |
sfrenck |
Oct 27 2018, 03:38 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Take some pics of the finished product a little further away? Hood up and hood down? |
pdlightning |
Oct 27 2018, 09:13 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
Sure looks pretty!
jmitro |
Oct 28 2018, 06:46 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
looks great; i'll be interested pending your other installation photos.
what is the price in US dollars? |
Chi-town |
Oct 28 2018, 09:24 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Can I get it in non-polished?
burton73 |
Oct 28 2018, 09:41 PM
burton73 Group: Members Posts: 3,497 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
BuddyV |
Oct 28 2018, 10:53 PM
Robert Group: Members Posts: 553 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
Chi-town |
Oct 28 2018, 11:31 PM
Can I get it in non-polished? If you send it out for anodizing it would look hot. Bob B I was thinking more a raw brushed stainless (IMG:style_emoticons/default/sunglasses.gif) |
Marek |
Oct 29 2018, 01:52 AM
Hi Guys I will post more pics asap from the instalation this week BUT It will only come in 2 finishes a polished version and a silver painted one, as on the 4th pic in the first post the cap it self is stainless , not sure you can anodize stainless but its possible to polish the cap your self ,if you want a more brusched look I did this kit also for the 911 now allmost 9 years ago and sold over 1000 pcs thanks to the magnus walker fever :-) and have seen different versions what people did to it , but I will only offer the 2 versions polished and silver painted, the silver have a satin finish to it M |
Chi-town |
Oct 29 2018, 10:18 AM
Silver painted works (IMG:style_emoticons/default/biggrin.gif)
ValcoOscar |
Oct 29 2018, 10:38 AM
Garage Life Group: Members Posts: 2,374 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
FOR ME...I like the last image of Post #1...weld in trim piece.
Is this piece included in complete 914 kit? IMHO I don't care for fastened trim ring. Oscar |
Marek |
Nov 5 2018, 01:01 PM
Sorry guys , forgot that the boys in the shop had 3 days off last week
Thanks for all the response I got Here are a few more info and answeres to some of the questions I got how its the bezel screwed on By the "down under the hood" :-) bezel as you see on the pictures the included screws are 5*12 mm in some case depending what bonnet you got steel or fiber , you have might to shorten the screws a bit, so they dont scratch or puncture the rubber seal and a good idea is to use a drop of loctite on each screw , when you are all messured up ( hope the "upside down" pics makes sense :-) you also see the the hole we made in the bonnet by messuring up the bezel the hole must be 127 mm as you can see the cap is a bit below level there are servel "spacers" in the kit , ( 5 mm , 8 mm , 1 mm etc ) going all up to 1,5 Cm which should cover it , we have tried this on 3 cars and all where different by any questions please send me a mail to early911parts@gmail.com first paid kits are now in the mail , I hope I got back to everybody , or pls send me a mail Regards Marek Attached image(s) |
Marek |
Nov 19 2018, 02:54 PM
Silver painted version , tested and on stock
The screws are glass blasted stainless steel screws Attached image(s) |
johnvan8 |
Nov 20 2018, 04:08 PM
Newbie Group: Members Posts: 2 Joined: 21-October 14 From: Orange, CA Member No.: 18,044 Region Association: None |
Very interested. What is the best way to figure out exact location to cut hood? Is there a template or is it better to cut specifically to where your tank/hood are located in relation to each other?
mb911 |
Nov 20 2018, 04:38 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
FOR ME...I like the last image of Post #1...weld in trim piece. Is this piece included in complete 914 kit? IMHO I don't care for fastened trim ring. Oscar (IMG:style_emoticons/default/agree.gif) |
Marek |
Nov 20 2018, 04:57 PM
Very interested. What is the best way to figure out exact location to cut hood? Is there a template or is it better to cut specifically to where your tank/hood are located in relation to each other? Well john , no template but I can post some ruff messurements to point you in a direction , but we can not make a template due to the bonnet and tank can be a few mm off in messurement on every car so it requiers some messuring , I can tell how we did we removed the expansion tank on top of the tank by unscrewing the 8 bolts we tape the fuel opening with papper tape we marked a cross on the center of the fuel openning then we drilled a small hole 20 mm or so ,as closed to the center mark as we could predict and when we saw we are close to center we did the hole larger and larger step by step hope it gives an idea Marek |
Marek |
Nov 20 2018, 05:00 PM
Hi Oscar the weld in trim is included,
Marek FOR ME...I like the last image of Post #1...weld in trim piece. Is this piece included in complete 914 kit? IMHO I don't care for fastened trim ring. Oscar (IMG:style_emoticons/default/agree.gif) |
ValcoOscar |
Nov 20 2018, 05:20 PM
Hi Oscar the weld in trim is included, Marek FOR ME...I like the last image of Post #1...weld in trim piece. Is this piece included in complete 914 kit? IMHO I don't care for fastened trim ring. Oscar (IMG:style_emoticons/default/agree.gif) Now we're talking (IMG:style_emoticons/default/piratenanner.gif) ...I need to bridge a few weeks but I'll be placing an order for two kits as a Christmas gift to myself. (IMG:style_emoticons/default/santa_smiley.gif) In addition, can I also purchase a separate weld in trim ring ONLY? Oscar |
Marek |
Nov 20 2018, 05:23 PM
Sure no problem just drop me a mail when you are ready
Marek Hi Oscar the weld in trim is included, Marek FOR ME...I like the last image of Post #1...weld in trim piece. Is this piece included in complete 914 kit? IMHO I don't care for fastened trim ring. Oscar (IMG:style_emoticons/default/agree.gif) Now we're talking (IMG:style_emoticons/default/piratenanner.gif) ...I need to bridge a few weeks but I'll be placing an order for two kits as a Christmas gift to myself. (IMG:style_emoticons/default/santa_smiley.gif) In addition, can I also purchase a separate weld in trim ring ONLY? Oscar |
Lo-Fi Version | Time is now: 25th April 2024 - 07:00 PM |
