Fuel pump wires, Location |
trojanhorsepower |
Nov 23 2018, 02:46 PM
Senior Member Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Believe it or not, I cant seem to find them in my harness. Not that they aren't there, I just don't know what they look like. So my understanding is that on a 73 the pump is located under the engine shelf, but all the wires go into the engine bay via the snorkel, so do the pump wires pass back down through the engine shelf?..
jcd914 |
Nov 23 2018, 03:11 PM
They run along the top of the engine shelf with the battery wires.
They go down through the engine shelf over by the hell hole. Jim |
JeffBowlsby |
Nov 23 2018, 03:18 PM
914 Wiring Harnesses Group: Members Posts: 8,806 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Where are you looking for them within the harness?
trojanhorsepower |
Nov 23 2018, 06:54 PM
OK, so maybe these two?
Two largish red wires in this bundle might be batter cables? |
yellowporky |
Nov 23 2018, 07:03 PM
Member Group: Members Posts: 429 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
looks like them
clapeza |
Nov 23 2018, 07:04 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
I couldn't find mine either. A previous owner of my '70 had some hell hole work done AND did a carb conversion, so my stock FI pump was long gone. It was replaced with a Facet rattle-box pump, wired directly off the distributor!
I could never find the original wire, so I ended up connecting into the factory multi-connector plug at the relay board. The relay board diagram that's on this site will show you which pin to use. |
trojanhorsepower |
Nov 23 2018, 07:27 PM
Thanks all!
Now I just need to figure out how to get my new wire through the snorkel to relocate the pump in the front..... |
trojanhorsepower |
Nov 23 2018, 08:11 PM
Any idea what the little green wire with the black stripe is for?
yellowporky |
Nov 23 2018, 08:48 PM
JeffBowlsby |
Nov 23 2018, 09:00 PM
The late cars required a 12ga wire and ground to the front for the FP.
trojanhorsepower |
Nov 23 2018, 09:07 PM
Looks good. Did you notch out the base of the snorkel to make room for the new wires? Dang it. Now I have to pull the 14 awg wire I already ran and replace it with a 12 ga....
yellowporky |
Nov 23 2018, 09:22 PM
i guess i will re run 12 gauge wire now.
No i did not notch the snorkel |
trojanhorsepower |
Nov 23 2018, 10:47 PM
Ah, i see now, you ran it in through another hole beside the snorkel and added another grommet. It looked so good i thought it was factory.
barefoot |
Nov 24 2018, 07:23 AM
Senior Member Group: Members Posts: 1,337 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
trojanhorsepower |
Nov 25 2018, 03:59 PM
So what about the little green wire with the black stripe poking out with the pump wires?
JeffBowlsby |
Nov 25 2018, 04:09 PM
Nov 25 2018, 04:11 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So what about the little green wire with the black stripe poking out with the pump wires? Oil temp sender going from the bottom of the engine (taco plate) to the front of the center tunnel where you can connect a gauge if you have the center console. There's another thread about it on the front page right now: http://www.914world.com/bbs2/index.php?showtopic=334716 Also, all the wires and their colors are described in detail in the wiring diagrams ... (IMG:style_emoticons/default/shades.gif) |
trojanhorsepower |
Dec 1 2018, 04:18 PM
Got it. Now how long should it be. The wire is about 2" right now....
Lo-Fi Version | Time is now: 15th January 2025 - 05:57 AM |
