2 Pages V < 1 2
> Un-used wiring under the center carpet behind the shifter
Tdskip
post Nov 25 2018, 08:18 PM
Post #21
Thanks Jeff
horizontally-opposed
post Jan 24 2021, 06:56 PM
Post #22
QUOTE(JeffBowlsby @ Nov 25 2018, 02:19 PM) *
P had a specific cable for connecting the dash mounted combo gauge with the oil temp gauge in it, for the later cars that did not have a center console. I make that too.
Oil Temp Gauge Sender Cable 3
914.612.155.10
1973-76
Cable from center console to dash combo gauge, w/o center console gauges
Here is a photo of the NOS cable I have:
One for @JeffBowlsby (or anyone else): I'm thinking about using at the unused center console harness in my early 1973 to power a 2.4-amp smartphone charger—does this seem feasible?
I guess next question is whether the power wires in these are hot in all cars, and/or tied to the headlight switch.
sixnotfour
post Jan 24 2021, 07:17 PM
Post #23
check the red one
rhodyguy
post Jan 24 2021, 07:20 PM
Post #24
You should put the other combo gauge in.
JeffBowlsby
post Jan 24 2021, 07:40 PM
Post #25
914 Wiring Harnesses
Pete the clock circuit should be live +12V full time.
post Jan 24 2021, 07:42 PM
Post #26
QUOTE(rhodyguy @ Jan 24 2021, 05:20 PM) *
Thanks—but I'm all gauged out with the 914-6/2.0 Non-Appearance Package oil temp plus fuel tank gauge in the main cluster and then oil pressure, volts, and outside temp where the radio would normally go.
QUOTE(JeffBowlsby @ Jan 24 2021, 05:40 PM) *
Ah, many thanks Jeff! Now to see if I can find some of the factory wire ends I've saved over the years…
2 Pages V < 1 2
- Lo-Fi Version Time is now: 14th January 2025 - 10:31 PM
