Exhaust Bolts... 1 or 2 per Cylinder? |
rickso71 |
Jun 19 2005, 08:27 PM
Member Group: Members Posts: 74 Joined: 31-October 04 From: Derry, NH Member No.: 3,041 |
The heads on my 914's 1.7 motor was rebuilt by the PO and I have the task of installing it in the car. All four exhaust ports have only one threaded bolt and a threaded hole.
Should there be two threaded shafts and two nuts per port or is there one threaded shaft and one nut plus one bolt (for the enpty threaded hole) for each cylinder? Seems odd there wouldn't be "two of the same" but photos in the Hayne's Manual show only one threaded shaft per cylinder also. |
mihai914 |
Jun 19 2005, 09:01 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
There is two studs per exhaust port. I'd go over the work of the PO real closely if something like that was overlooked.
Jun 20 2005, 02:54 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Stud == "threaded shaft".
Two studs per cylinder, zero bolts. One special copper-coated flanged exhaust nut goes on each of the studs. --DD |
rickso71 |
Jun 20 2005, 09:20 PM
Dave,
Tried looking for the exhaust studs at Pelican but couldn't find them. |
bd1308 |
Jun 20 2005, 10:07 PM
Jake Raby said he ordered 2,000 of each size (there are two different sized studs)
ask him for some.... |
Jun 21 2005, 12:03 PM
Or phone the Sales staff at Pelican. Not everything we carry can fit into the catalog...
--DD |
type47 |
Jun 21 2005, 08:11 PM
standard exhaust stud is 8x52mm
Lo-Fi Version | Time is now: 3rd January 2025 - 03:38 AM |
