| yeahmag |
Dec 17 2018, 01:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,483 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I've never had a Stage 1 clutch in a Type 4. The KEP Stage 1 (modified Sachs) feels really heavy on the pedal. I'm OK with it as long as nothing is wrong. Anybody had the same?
I imagine if this is "normal", I should switch to a Delrin pulley... Attached thumbnail(s) |
| SirAndy |
Dec 17 2018, 01:46 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Are you sure the throw is adjusted properly?
I had KEP Stage I, II and III clutches and i currently run a special made one-off KEP clutch on my 3.6L and while they do feel a bit firmer, i never had any of them feel heavy. Once adjusted properly, you should feel a very distinct point where the clutch disengages and once past that point, the pedal should move freely without much force needed to hold it. (IMG:style_emoticons/default/idea.gif) |
| yeahmag |
Dec 17 2018, 01:48 PM
It's adjusted a bit low at this point. I don't get that "over center" feel I had in the other Sachs kit, so maybe I'm not fully utilizing some magic leverage point(s)...???
| yeahmag |
Dec 17 2018, 07:20 PM
Adjusting it to the correct range definitely helped. Still heavy, but not as bad.
Think I need to adjust my pedal stop some now (for shorter throw). |
| SirAndy |
Apr 14 2019, 10:44 PM
| yeahmag |
Apr 14 2019, 10:54 PM
Changed the clutch cable from a Terry to a Cofle and it’s much better. There was something wrong with that Terry cable...
| '73-914kid |
Apr 15 2019, 09:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Terry cables do not have the plastic sheaths in the tunnel that the OEM style cables have. Braided cable on the steel tube causes a lot of drag.
| jkb944t |
Apr 15 2019, 10:31 AM
Member ![]() ![]() Group: Members Posts: 470 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
| yeahmag |
Apr 15 2019, 11:11 AM
It would probably be tough if it's in the car already. The cable is thinner on a stock one, but without a reference, it would be hard to gauge. The sheath that is a dead giveaway is hidden in the tunnel.
| jcd914 |
Apr 15 2019, 12:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Some cables have the brand on the black cable housing between the firewall and transmission.
Jim |
Lo-Fi Version | Time is now: 20th June 2026 - 02:17 AM |
