dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,136 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
factory publications. They are real Brad. Part numbers still exist in the Porsche price guide but all have been discontinued. Please remember sway bars from the factory were not offered on the four until 1973 and on the six in 1971-1972
The reason for the different sized bars is because of the weight difference, the four understeered the six over steered. SO to change under steer, bigger rear bar smaller front bar. To change over steer, bigger front bar smaller rear bar. The four cylinder really lit up with the addition of the bars, 16 front 15 rear. Became quite crisp. The six really benefited from the bars as it made the car more stable rather than worrying about the rear end coming around in a hard quick turn. Yes that extra six cylinder engine weight made a difference 15 front 16 rear for the four cylinder, 16 front 15 rear for the six cylinder @dr914 @autoatlanta.com I have never seen a 16mm front or a 15mm rear on any 914 or 914-6. No references in PET to those sizes. What is you source for that information George ? |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,703 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Great discussion
I could list all of the different 914 sizes and parts numbers if anyone is seriously interested. The fronts are just like the 911 ones of the period, the rears (two of them) were 914 unique
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,692 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I could list all of the different 914 sizes and parts numbers if anyone is seriously interested. The fronts are just like the 911 ones of the period, the rears (two of them) were 914 unique Does anyone have a picture of a 15mm rear bar ? Someone here whose had many many cars must have a picture. Attached thumbnail(s) ![]() |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
the 916 has one on it !
quote name='rgalla9146' date='Dec 29 2018, 10:46 AM' post='2677468'] [quote name='dr914@autoatlanta.com' post='2677457' date='Dec 29 2018, 12:07 PM'] I could list all of the different 914 sizes and parts numbers if anyone is seriously interested. The fronts are just like the 911 ones of the period, the rears (two of them) were 914 unique [/quote] Does anyone have a picture of a 15mm rear bar ? Someone here whose had many many cars must have a picture. [/quote] |
front 12 90134370301
front 14 90134370302 front 15 90134370303 front 16 90134370304 front 11 90134370305 rear 15 91433370105 rear 16 91433370106 rear 16 (914-4) 91433305506 |
rgalla9146 |
[quote name='dr914@autoatlanta.com' date='Dec 29 2018, 03:59 PM' post='2677495']
the 916 has one on it ! Excellent ! and a picture ? quote name='rgalla9146' date='Dec 29 2018, 10:46 AM' post='2677468'] [quote name='dr914@autoatlanta.com' post='2677457' date='Dec 29 2018, 12:07 PM'] I could list all of the different 914 sizes and parts numbers if anyone is seriously interested. The fronts are just like the 911 ones of the period, the rears (two of them) were 914 unique [/quote] Does anyone have a picture of a 15mm rear bar ? Someone here whose had many many cars must have a picture. [/quote] [/quote] |
rgalla9146 |
New twist.
check the factory recommendation lower right no part numbers provided still want to see a 15mm Attached thumbnail(s) ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,754 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
front 12 90134370301 front 14 90134370302 front 15 90134370303 front 16 90134370304 front 11 90134370305 rear 15 91433370105 rear 16 91433370106 rear 16 (914-4) 91433305506 Thanks George, I never knew about those other size bars. Looks like 901.343.703.01 is a 13mm front 911 and 912 SWB bar not 13mm as you listed. Those are the ones I have most often seen on SWB cars. Do you know what size bars the GT 914-6 used ? And the name is Bruce not Brad. (IMG:style_emoticons/default/poke.gif) @dr914 @autoatlanta.com Attached thumbnail(s) ![]() |
Sorry for the name error Bruce, I got this information from the Porsche factory 914-6 GT parts book. Who am I to question them?)LOL)
front 12 90134370301 front 14 90134370302 front 15 90134370303 front 16 90134370304 front 11 90134370305 rear 15 91433370105 rear 16 91433370106 rear 16 (914-4) 91433305506 Thanks George, I never knew about those other size bars. Looks like 901.343.703.01 is a 13mm front 911 and 912 SWB bar not 13mm as you listed. Those are the ones I have most often seen on SWB cars. Do you know what size bars the GT 914-6 used ? And the name is Bruce not Brad. (IMG:style_emoticons/default/poke.gif) @dr914 @autoatlanta.com |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,725 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
might as well add this one
Sway Bar Front 18mm 91134370500. 75-76 turbo |
Marek |
Newbie ![]() Group: Members Posts: 20 Joined: 27-April 15 From: Copenhagen , Denmark Member No.: 18,672 Region Association: None ![]() |
Hi Guys
just wanted to give a heads up We are in the final stage in produccing the 16 mm and 18 mm Rear sway bars all hardware for it is also made all made to factory specs and they will be priced VERY good you can buy them seperat or just the parts for it if you got the swaybar or the other way around thanks for all the Feedback , I came to the conclusion that most are interested in 18 mm but we did the 16 mm also in the future we will do a test run of 20 mm Marek ![]() |
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 8th February 2025 - 03:48 AM |
