> Model Specific Information
3 Pages V < 1 2 3 >
> Engine Sticker, 1.8 liter engine tune sticker
StarBear
post May 3 2020, 09:33 AM
Post #21
OK; I think I have it. Have added the decimal in front of 006" and cleaned up/mocked up the timing marks. The bottom one still looks odd (no separate notch horizontal line like the top, but that's what the original seems to look like). What do you think, @oakpark , @VG-914 and @JeffBowlsby ?
StarBear
post May 4 2020, 07:53 AM
Post #22
One last set of touch-ups. If interested, also made a parallel one with double lines across the bottom timing mark to match the top, but don't think the original had it.Attached Image
StarBear
post May 6 2020, 10:32 AM
Post #23
Final tune up (pun intended) on the sticker image. Sent to member for printing!
Not concours grade by any means, but then neither am I.... (IMG:style_emoticons/default/smile.gif)
StarBear
post May 11 2020, 06:32 PM
Post #24
@oakpark , @VG-914 and @JeffBowlsby ;
Haven't seen or heard anything lately, so wondering if there's still any interest in pursuing this. If so, a) is the one shown above sufficient, or b) should I keep pursuing a more intensive cleanup as shown below (redid the letters, numbers and far right graphic)?
If b), then could use a bit of others' eyes to figure out what the graphic for the valve clearance should look like - sort of like two arrows showing the gap between two spacing lines?
oakpark
post May 11 2020, 09:03 PM
Post #25
Oak Park 914
QUOTE(StarBear @ May 11 2020, 04:32 PM) *
As a concours guy, I'd like it as original looking as possible
JeffBowlsby
post May 11 2020, 09:11 PM
Post #26
This looks great! I have a 2.0L so I am not a customer but others will be I am sure.
StarBear
post May 12 2020, 09:21 AM
Post #27
@oakpark ; Does that mean leave the age/blurring (e.g. aged original) or continuing cleaning (e.g. as if new original)? Not sure. Thanks.
StarBear
post May 14 2020, 10:22 AM
Post #28
Getting closer. Text, valve clearance section and timing section are done. Now onto the hardest part - the dizzy section. Learning a lot about graphic software and techniques.
oakpark
post May 18 2020, 08:59 PM
Post #29
Oak Park 914
QUOTE(StarBear @ May 14 2020, 08:22 AM) *
Looking good. Obviously, as clear as it can be, but I'm liking what I'm seeing.
davep
post May 19 2020, 02:08 PM
Post #30
914 Historian
It does look pretty good. I think the more crisp it is the better; that is they way the originals were. I don't need the 1.8 since most of mine are 2.0, but I do have some NOS labels from 30 years ago. I think they are all in the parts list above.
StarBear
post May 20 2020, 11:31 AM
Post #31
QUOTE(davep @ May 19 2020, 04:08 PM) *
@DaveP Have any NOS 1.8L stickers? I'm having a hard time understanding the detailed lines, working off the wrinkled, dirty photo. Working off a fresh one would really help! Will PM you.
davep
post May 21 2020, 09:14 PM
Post #32
914 Historian
No, I do not have that decal.
StarBear
post May 22 2020, 12:08 PM
Post #33
OK, really getting closer (see photo). Question for @oakpark @VG-914 and others: What to do with the three "blob" circles to the left of the dizzy - remove or keep? If keep, what are they supposed to look like? Can't tell from the original photo nor from looking at my actual one.
StarBear
post May 23 2020, 08:04 AM
Post #34
@davep - I had an idea; if the base images are the same on the 2L sticker (see image above), could I buy one from you?
I'd then do a high-res scan (to get a good, clean and correct base), then overwrite the numbers and letters (which I've already done once, so could easily redo). This, I believe, would provide a clear, accurate reproduction of the 1.8L sticker.
If so, I'll PM you my home address.
Thanks.
StarBear
post May 25 2020, 02:50 PM
Post #35
DONE! (IMG:style_emoticons/default/piratenanner.gif) Have created 3 versions, all at proper size (75mm x 40mm) - 1. Original; 2. Cleaned and 3. Restored. If anyone wants to print, just PM me with your email address and which file you'd like; I'll send the full file to you.
Here they are:
1. Original
2. Cleaned
3. Restored (Don't know why this is showing up in a slightly larger size)
Not perfect, but as I noted early on, I'm not a graphic artist and doubt folks could detect glitches in a rather small sticker, in a semi-dark engine compartment. Onward!
PS: @VG-914 if you print them, could you send me two?
StarBear
post May 27 2020, 08:21 AM
Post #36
@oakpark @jeffbowlsby @dr914 @autoatlanta.com
All done - see above.
davep
post May 27 2020, 09:20 PM
Post #37
914 Historian
Looks good. It does not appear that I have the 2,0 decal either. The little lumps on the side of the distributor are probably the clamps for the cap.
StarBear
post May 28 2020, 07:19 AM
Post #38
QUOTE(davep @ May 27 2020, 11:20 PM) *
Ah, yes - the clamps. Good catch. Deciding whether if the effort to attempt to draw them in or not.
StarBear
post May 29 2020, 12:01 PM
Post #39
Here it is, with the "clamps" inserted. Haven't done final high-res version, pending any input or other suggestions. Whew!
oakpark
post Jul 5 2020, 11:04 AM
Post #40
Oak Park 914
QUOTE(StarBear @ May 29 2020, 10:01 AM) *
I can't believe it's been two months since I followed this chain of commentary. I'm very impressed with the work that's been done. I would put my name on the dotted line for a sticker.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 4th April 2025 - 12:23 PM
