> Toe and camber guages, any experience (s)??
qa1142
post Jun 21 2005, 02:44 PM
Whiplash
looking at toe or toe and caster guages for my cars. Any one have experience with Longacre tools, smart racing products or pole postition
http://www.polepositionrp.com/CHASSIS%20SE...GAUGES.htm#9100
Cheapest is JC Whitney toe guage $38
Pole postion does both for about $200
advanced racing - http://www.advancedracing.com/ has string based toe unit for $80
Longacre has $55 toe solution.
Anyone have any experience?
redshift
post Jun 21 2005, 02:48 PM
Bless the Hell out of you!
You can do it with common tools.... hold on... is it Pelican that has the tech thingy?
By John Rogers (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
http://www.pelicanparts.com/techarticles/h...home_toe_in.htm
M
qa1142
post Jun 21 2005, 02:53 PM
Whiplash
yes, saw this, I don't have 2 18"X24" 40 guage aluminum laying around. Local hardware has steel (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
This system would lay against tire not on the rim. That is what I like about pole position fast trak system.
I can use these on rear wheels too when I do the rear control arms
TimT
post Jun 21 2005, 03:12 PM
retired
I have a smart race camber gauge it works well, and I set toe with a set of toe plates
10"x24" alum with a bevel bent about 1" in top and botton, and a some slots that recieve a steel tape.
thats the trackside stuff..
have a 4 wheel alignment machine at the shop.
anthony
post Jun 21 2005, 03:53 PM
2270 club
You can get the same digital leveling unit as the SmartCamber uses at Amazon for $85. It's called a SmartTool:
http://www.amazon.com/exec/obidos/tg/detai...l/-/B0000225AL/
On a 5 lug Fuch, you can take the center cap off and put the gauge right on the wheel. Or, one could easily attach the gauge to a straight piece of aluminum if you wanted to measure from rim edge to rim edge. Or buy the SmartCamber for $200 if you want a fancy $115 bracket.
You can easily measure toe with two thumb tacks, two plumb weights and a tape measure. One of the measuring tools may make it easier though.
- Lo-Fi Version Time is now: 26th December 2024 - 02:38 PM
