Strut repairs, For the guys trying to keep a factory six original. |
ClayPerrine |
Mar 5 2019, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,958 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Recently, I found the left front strut on Elwood clunking when I moved it. Seems the ball joint was moving in the bottom of the strut. The ball joint setup is the pinch type, and it is too damaged to repair. I wanted to keep it stock. So I talked with the machinist that is helping with the adapter plate for the 4.0. I suggested a sleeve, but that wouldn't leave enough structure on the ball joint. We came up with the idea of replacing the casting in the bottom of the strut with a later wedge pin type strut. Porsche put them on starting in 72 for safety reasons.
So I gave him the two 914-6 struts, and two /4 struts with the wedge type ball joint connections. He was able to remove the ball joint mount from the /4 struts, and put them into the /6 struts. He told me that to remove the old bottoms from the /6 struts, he had to set them up in the lathe and turn them as slowly as possible, and the 4k lb lathe started to hop anyway. The welds looked factory when done, and now Elwood has the updated, safer ball joints in him. So if you find yourself in the same situation, contact Zims Autotechnic at 817-267-4451 and they can fix your factory /6 struts up to use the wedge type ball joints. Sorry for no pictures, mine would have looked just like ball joint replacement picts. Maybe my machinist (he is a member here) can throw some pictures up. |
partsguy22 |
Mar 5 2019, 09:29 AM
Enabler of bad ideas Group: Members Posts: 24 Joined: 8-November 17 From: FT Worth, Tx Member No.: 21,587 Region Association: None |
Thanks Clay
I didn't take many pictures of the process This is after cutting off the original "Pinch bolt" bottom in the band saw, the rest of the material inside the strut must be removed so in the lathe it goes, Attached thumbnail(s) |
partsguy22 |
Mar 5 2019, 09:41 AM
I am also working on making new wedge bolt strut bottoms from scratch, so we don't have to cannibalize original struts
These will be hardened 4140 ChroMoly This is the prototype and its still not done so I apologize for the bad surface finish Attached thumbnail(s) |
eeyore |
Mar 5 2019, 12:54 PM
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube?
sixnotfour |
Mar 5 2019, 01:18 PM
914 Wizard Group: Members Posts: 10,693 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
yes but pn is important
dr914@autoatlanta.com |
Mar 5 2019, 01:21 PM
914 Guru Group: Members Posts: 8,111 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
some people have all of the skill!
ClayPerrine |
Mar 5 2019, 02:15 PM
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. |
Mar 5 2019, 03:04 PM
funny but we have at least 16 nos RIGHT front 914-6 Strut housings but no left ones, must be the left one that gets all of the ball joint abuse over the years
ClayPerrine |
Mar 5 2019, 03:41 PM
funny but we have at least 16 nos RIGHT front 914-6 Strut housings but no left ones, must be the left one that gets all of the ball joint abuse over the years Somewhere, in some lost Porsche warehouse is 16 NOS left 914-6 struts. (IMG:style_emoticons/default/laugh.gif) |
partsguy22 |
Mar 5 2019, 04:37 PM
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube? Thats easier said than done My attempt to " Just cut the welds and press 'er off " well... lets just say that didn't work like I wanted it to (hint: there is no good surface to press against on a 914-4 spindle to take it apart ,with out possibly damaging something) Not to mention the way the -4 spindle is welded to the tube is very difficult to cut all the weld out with damaging the tube And I'd also have to cut and transfer the brake line tabs and that would be just way to much work (IMG:style_emoticons/default/biggrin.gif) |
Mark Henry |
Mar 5 2019, 05:18 PM
Krieger |
Mar 5 2019, 07:37 PM
Advanced Member Group: Members Posts: 4,771 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
[/quote] Thats easier said than done My attempt to " Just cut the welds and press 'er off " well... lets just say that didn't work like I wanted it to (hint: there is no good surface to press against on a 914-4 spindle to take it apart ,with out possibly damaging something) Not to mention the way the -4 spindle is welded to the tube is very difficult to cut all the weld out with damaging the tube And I'd also have to cut and transfer the brake line tabs and that would be just way to much work (IMG:style_emoticons/default/biggrin.gif) [/quote] I just tried to remove the spindle from a 4 cylinder strut can as well. I had the same exact problems. It did not happen. I was able to remove the spindle off a 6 cylinder can though. The welds are different. |
ClayPerrine |
Mar 6 2019, 09:41 AM
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube? Thats easier said than done My attempt to " Just cut the welds and press 'er off " well... lets just say that didn't work like I wanted it to (hint: there is no good surface to press against on a 914-4 spindle to take it apart ,with out possibly damaging something) Not to mention the way the -4 spindle is welded to the tube is very difficult to cut all the weld out with damaging the tube And I'd also have to cut and transfer the brake line tabs and that would be just way to much work (IMG:style_emoticons/default/biggrin.gif) You also have to remember, I have to pay him for this type of work. So "way too much work" translates to $$$$ for me. (IMG:style_emoticons/default/biggrin.gif) |
mskala |
Mar 6 2019, 09:56 AM
R Group: Members Posts: 1,927 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube? If the wedge bolt strut was desired but originality of the part numbers was not an issue, then the simple way would be just to get 3" brake-caliper spacing 911 struts that had the wedge bolt (not sure of year range). |
Mark Henry |
Mar 6 2019, 09:57 AM
Not just for 914/6, I have two 914's with 914/6 or 911T struts, which IIRC are the same 914 part #.
Mar 6 2019, 10:41 AM
914-6 GT in waiting Group: Members Posts: 19,670 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. So it’s important to have an original part number on a non original part because ??? (IMG:style_emoticons/default/poke.gif) |
ClayPerrine |
Mar 6 2019, 11:15 AM
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. So it’s important to have an original part number on a non original part because ??? (IMG:style_emoticons/default/poke.gif) The majority of the part is original. The only reason I had the ball joint type changed was for safety reasons. And our objective for the car is to keep it as original as possible. |
partsguy22 |
Mar 6 2019, 11:33 AM
So it’s important to have an original part number on a non original part because ??? (IMG:style_emoticons/default/poke.gif) the time old question of: original yet broken Or slightly modified yet working That being said , you could also replace the bottom with a "like" bottom the biggest reason to use the wedge bolt style is its quite a bit more durable (not that Clay will be tracking his -6) , from what the original bottoms looked (fit ?) like, they were what I would consider unsafe. The pinch bolt style suffers from being able to stretch and deform when the pinch bolt is tightened (over tightened ?) eventually the gap/ split will distort and close up and will no longer tighten up correctly on a ball joint ETA: looks like Clay beat me to it |
toolguy |
Mar 6 2019, 12:12 PM
Senior Member Group: Members Posts: 1,275 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
be sure to refinish them in the correct gray color, not black on 914-6's
Mar 6 2019, 02:07 PM
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. So it’s important to have an original part number on a non original part because ??? (IMG:style_emoticons/default/poke.gif) The majority of the part is original. The only reason I had the ball joint type changed was for safety reasons. And our objective for the car is to keep it as original as possible. I understand it’s a good fix and a good modification. I’m just wondering at what point do we stop using the word original on a modified part. |
Lo-Fi Version | Time is now: 2nd January 2025 - 09:56 AM |
