Engine compartment....?. |
Retroracer |
Jul 10 2021, 03:43 PM
Senior Member Group: Members Posts: 622 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
So not the cleanest, but here's the engine bay of my faux GT build; no insulation, I removed some of the brackets and relocated the relay board to the battery tray (battery relocated in front trunk); GT engine lid release means a shorter tube run. The firewall access is just visible in front of the cooling fan:
To get to Singer levels of detail / clean, you could go much further - relocating ground studs, bespoke liners, etc. Relocating the dry sump tank in the front would clean up all those connections, fasteners, filler and such. Depends on how much time and planning you want to invest...! - Tony |
barefoot |
Jul 11 2021, 06:30 PM
Senior Member Group: Members Posts: 1,334 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Literati914 |
Jul 12 2021, 01:59 PM
Senior Member Group: Members Posts: 1,780 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I've always thought about using an air box from a 911 (zenith / MFi type, other?) as a starting point, and re-work it for an air-box for a carb set up in a 914.
Would probably have to cut it into 3rds and elongate it.. weld up everything on the underside and then cut and re-drill for the Webers, etc. But what about volume - too much there? Other obvious problems? Thoughts? . |
Cairo94507 |
Jul 12 2021, 02:44 PM
Michael Group: Members Posts: 10,130 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Shivers |
Jul 12 2021, 04:23 PM
Senior Member Group: Members Posts: 2,825 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
"They just don’t look as appealing as, 911’s or 356’s, 912’s or even VW bugs....."
This deserves a a response I used to give when I first got the 914. Bugs were very popular in the early 80's, and I heard how I just had a VW engine, just like them..."Yes", I'd say, "but like buying the right house, it's all about location, location, location..." |
windforfun |
Jul 12 2021, 07:18 PM
Senior Member Group: Members Posts: 1,999 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
raynekat |
Jul 12 2021, 08:49 PM
Advanced Member Group: Members Posts: 2,167 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Engine bays are tough on 914's.
Hard to see in there and just as hard to keep it clean and tidy. Easier when you've just rebuilt the car, but then it's still tough to maintain the cleanliness. I think it looks better without the sound/heat pad on the firewall but then you've got a lot more engine noise in the cockpit. This was what mine looked like after the rehab. Unfortunately the crown jewel of a 911 engine, the fan, is impossible to see in a 914. Ha |
raynekat |
Jul 12 2021, 08:50 PM
mlindner |
Jul 13 2021, 04:29 AM
Senior Member Group: Members Posts: 1,591 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
rgalla9146 |
Jul 13 2021, 08:07 PM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
All stock except for air filters.......and louvered engine lid.
Attached thumbnail(s) |
rgalla9146 |
Jul 13 2021, 08:11 PM
All stock except for air filters and ....conversion car with louvered engine lid
ssuperflyoldguy |
Jul 14 2021, 12:17 PM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
rgalla9146 |
Jul 14 2021, 08:00 PM
iamchappy |
Jul 14 2021, 09:14 PM
just a little bit cluttered
ClayPerrine |
Jul 15 2021, 08:36 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
rgalla9146 |
Jul 15 2021, 10:57 AM
Engine bays are tough on 914's. Hard to see in there and just as hard to keep it clean and tidy. Easier when you've just rebuilt the car, but then it's still tough to maintain the cleanliness. I think it looks better without the sound/heat pad on the firewall but then you've got a lot more engine noise in the cockpit. This was what mine looked like after the rehab. Unfortunately the crown jewel of a 911 engine, the fan, is impossible to see in a 914. Ha Forgot the big question...what are the engine specs ? |
PaulFV8 |
Jul 15 2021, 07:09 PM
Member Group: Members Posts: 86 Joined: 2-August 20 From: Virginia, USA Member No.: 24,562 Region Association: None |
Anyone paint the engine bay a different color than the car?
Lo-Fi Version | Time is now: 26th December 2024 - 08:09 PM |
