Modified 914 or 911 RS Type steering wheel (my version), 30mm grip, 340mm Dia , 40mm deeper than stock |
sb914 |
Mar 20 2019, 06:14 AM
Surf Guru Group: Members Posts: 4,410 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Nice job Oscar!
jim_hoyland |
Mar 20 2019, 07:26 AM
Get that VIN ? Group: Members Posts: 9,559 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Nice job Oscar! (IMG:style_emoticons/default/agree.gif) What creativity ! A sharkskin covering might enhance the grip... (IMG:style_emoticons/default/biggrin.gif) |
ValcoOscar |
Mar 20 2019, 08:27 AM
Garage Life Group: Members Posts: 2,480 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
It took me several attempts and unfortunately I scrapped out two steering wheels in the process.
I played with different rim diameters until I settled on 340mm with 30mm grip. Tried .875 and 1.125 tubing but didn't care for look or feel. Too cartoonish. I didn't want to distort the overall look of the wheel. I also toyed with milling holes on all four spokes...looked good but I felt it weakened wheel so I tossed it. At the end I slotted the newly rolled rim and inserted reshaped spokes prior to tig welding. I would not recommend mig welding. Result was a stout modified wheel that felt right. I will share more photos once I finish paint and leather wrapping. oh yeah...I formed tube ring in house but there are many metal rolling houses out there. I have a single seam on my finished ring. I tried welding two halves but not happy with results. I need a few more for my other cars so If there is enough interest maybe I could do a very limited GB so we can leverage cost of leather wrapping. Your thoughts? Oscar |
gereed75 |
Mar 20 2019, 08:43 AM
Senior Member Group: Members Posts: 1,315 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
My plan was to cut the rim portion out of flat stock and then laminate both side with some clear white pine to achieve a round cross section. The maybe advantage would be that you could replicate the blended rim to spoke transition of the stock wheel.
Additional advantage would be ease of MIG welding the flat circular rim to the flat spokes. It will all be covered. Was also considering a slight center offset of maybe 3/4 to 1 inch to get added thigh clearance. I have one of 914 Rubbers last plastic hockey puck cores from their aborted attempts to replicate the original. Not perfect but workable. This has motivated me to get out my collection of steering wheel parts and get the project going. I would be in on a group covering buy. |
Mark Henry |
Mar 20 2019, 08:46 AM
It took me several attempts and unfortunately I scrapped out two steering wheels in the process. I played with different rim diameters until I settled on 340mm with 30mm grip. Tried .875 and 1.125 tubing but didn't care for look or feel. Too cartoonish. I didn't want to distort the overall look of the wheel. I also toyed with milling holes on all four spokes...looked good but I felt it weakened wheel so I tossed it. At the end I slotted the newly rolled rim and inserted reshaped spokes prior to tig welding. I would not recommend mig welding. Result was a stout modified wheel that felt right. I will share more photos once I finish paint and leather wrapping. oh yeah...I formed tube ring in house but there are many metal rolling houses out there. I have a single seam on my finished ring. I tried welding two halves but not happy with results. I need a few more for my other cars so If there is enough interest maybe I could do a very limited GB so we can leverage cost of leather wrapping. Your thoughts? Oscar Maybe offer it as a finished wheel and also as a DIY kit. (IMG:style_emoticons/default/idea.gif) |
ValcoOscar |
Mar 20 2019, 08:49 AM
My plan was to cut the rim portion out of flat stock and then laminate both side with some clear white pine to achieve a round cross section. The maybe advantage would be that you could replicate the blended rim to spoke transition of the stock wheel. Additional advantage would be ease of MIG welding the flat circular rim to the flat spokes. It will all be covered. Was also considering a slight center offset of maybe 3/4 to 1 inch to get added thigh clearance. I have one of 914 Rubbers last plastic hockey puck cores from their aborted attempts to replicate the original. Not perfect but workable. This has motivated me to get the project going. I would be in on a group covering buy. I like this!!!! "Was also considering a slight center offset of maybe 3/4 to 1 inch to get added thigh clearance." (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) Perhaps, Oscar |
11tenths |
Mar 20 2019, 02:44 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
The offset idea is great for us tall guys-
JWest offers an eccentric wheel mount of 12mm vert and 16mm closer mounting; http://www.jwesteng.com/shop/914/15-steeri...c-adapter.html# I had to go with a MOMO and removable adapter to easily get in&out, but miss the look of the orig. Keep up the good work Oscar- you're a valuable resource for us all. -Harry |
914Sixer |
Mar 20 2019, 07:57 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Here is a 911 candidate for you. 911 347 082 00 8/72
ValcoOscar |
Mar 20 2019, 08:13 PM
burton73 |
Mar 20 2019, 09:50 PM
burton73 Group: Members Posts: 3,692 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Here is a 911 candidate for you. 911 347 082 00 8/72 I can use it....thx Pm sent Oscar Hi Oscar, I have been thinking of your steering wheel and wanted to point out some observation’s. The new style wheel has a deeper offset and when you make them this way with the ring you lose the finger indents. Now I am not passing judgments on that as far as whether or not it is better, but I do notice that it is not there. As an inventor in the plastic business for so many years I always think of things like this. Maybe that's not there for a reason. A wheel could be poured in a casting urethane with the indents molded in and set to a given weight by using light fillers like micro balloons. I am more than happy to go over this with you if you like. Best regards, Bob Burton |
whitetwinturbo |
Mar 20 2019, 10:29 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
porschetub |
Mar 21 2019, 01:02 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Great idea,like the larger diameter rim should have a great feel when covering is on,think it was on Pelican a guy used a 944 outer rim and 911 spokes.
I have a double wrapped wheel with hockey puck but I'am tall so found it a pain getting in and out of the car,I swapped out to a smaller aftermarket wheel with Momo adaptor but it is smaller diameter rim and not as good to hold...a trade off really. |
ValcoOscar |
Mar 22 2019, 04:40 PM
Here is a 911 candidate for you. 911 347 082 00 8/72 I can use it....thx Pm sent Oscar Hi Oscar, I have been thinking of your steering wheel and wanted to point out some observation’s. The new style wheel has a deeper offset and when you make them this way with the ring you lose the finger indents. Now I am not passing judgments on that as far as whether or not it is better, but I do notice that it is not there. As an inventor in the plastic business for so many years I always think of things like this. Maybe that's not there for a reason. A wheel could be poured in a casting urethane with the indents molded in and set to a given weight by using light fillers like micro balloons. I am more than happy to go over this with you if you like. Best regards, Bob Burton Appreciate your input Bob. Here's my version of finger indents with the help of my P50 Piranha iron worker. Oscar |
TravisNeff |
Mar 23 2019, 07:32 AM
This is outstanding Oscar! I love the look of the GT wheel, but don't like how thin the stock wheel is and is large it is, like a tractor or an old 50's pickup.
I like the version without the finger indents. Trying to replicate that completely would be very, very difficult. |
sixnotfour |
Mar 23 2019, 10:18 AM
914 Wizard Group: Members Posts: 10,680 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
heres my modified Rial.... 370mm ,,,,914ish fashion its sprayed with bed liner..
or is it a Racemark , I did both Attached image(s) |
gereed75 |
Jan 21 2020, 07:02 PM
ValcoOscar |
Feb 9 2020, 07:46 PM
One finished.... (IMG:style_emoticons/default/dance.gif) (IMG:style_emoticons/default/monkeydance.gif)
30mm Grip/1.25" w leather covering 340mm Diameter/ 13.5" 40mm/1.5" Dished deeper than stock Oscar |
sb914 |
Feb 9 2020, 08:03 PM
That deserves a Oscar !
914Sixer |
Feb 9 2020, 09:16 PM
Looking good (IMG:style_emoticons/default/biggrin.gif)
sixnotfour |
Feb 9 2020, 11:40 PM
That deserves a Oscar ! That deserves an Oscar (IMG:style_emoticons/default/first.gif) mines full alloy (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 05:51 PM |
