Dealer installed condenser size? |
agenovez |
Mar 22 2019, 02:47 PM
Newbie Group: Members Posts: 1 Joined: 25-September 18 From: Dallas TX Member No.: 22,521 Region Association: None |
Looking at adding a parallel flow condenser to my 914 and was wondering what the size of the original dealer installed tube and fin condenser was?
David Billo |
Mar 25 2019, 07:11 PM
Member Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
I have one in my attic. I'll go up there tomorrow and measure it.
Literati914 |
Mar 25 2019, 10:20 PM
Senior Member Group: Members Posts: 1,437 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Looking at adding a parallel flow condenser to my 914 and was wondering what the size of the original dealer installed tube and fin condenser was? (IMG:style_emoticons/default/welcome.png) Dallas ? We have a new one in the metroplex ...thats great. You'll have to let us know what you're workin' on. I was asking some A/C questions myself just the other day, so I'll be interested in what you find out abouth the condensor too. Good luck! |
Chris914n6 |
Mar 25 2019, 11:59 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
13x14 and 10x18. ~2" Thick. Yes I have one of each (IMG:style_emoticons/default/biggrin.gif)
The condenser is just a heat exchanger, so the bigger the better, with lots of air flow. |
jcd914 |
Mar 26 2019, 12:35 AM
13x14 and 10x18. ~2" Thick. Yes I have one of each (IMG:style_emoticons/default/biggrin.gif) The condenser is just a heat exchanger, so the bigger the better, with lots of air flow. The original system was designed around R12 and R134a is not as thermally efficient as R12. So for a R134a conversion a larger evaporator helps even more. Jim |
David Billo |
Mar 26 2019, 12:41 PM
Dimensions of the overall enclosure of my (AFAIK) dealer installed A/C condensor ('73 2.0), as it would have been positioned in the car:
Width (side to side): 20 3/4" Length (front to rear): 13 7/8" Height (top to bottom): 5 1/8" This enclosure includes space at the front for a fan. I have a photograph of it if you need it. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:12 AM |
