3 Pages V < 1 2 3 >
> Wiring for an Engine Run Stand with DJet
doug_b_928
post May 23 2019, 08:51 PM
Post #21
I finally got my engine run stand completed. It took a lot more work than I had thought it would. This stand is very specific to my needs, but I thought I'd share in case it gives anyone else some ideas for their own stand. I made the distance between the castors at 45" so that I can load and unload it from my trailer without moving the ramps. It also sports a hitch for attaching my winch and tie down points on all four corners.
Here it is in the 'installation position', meaning the bars that hold the relay board on the left side and the MPS and decel valve on the right side are folded down.
I have a max jax, so I simply roll the stand under the car
I made the back side open so that I can roll my lift table under the stand
Then I raise the lift table to support the engine and unbolt the engine from the car.
Then I lower the engine onto the stand
I also made a bar that I can install from underneath. It supports both the engine and the transmission. In theory, I can then separate the trans from the engine and have both still supported (makes it easier for doing this work alone).
Here is the stand with the attachments in the 'run' position.
I made a throttle lever that I can tighten in position with a wing nut, so that I can hold rpms over 2000 for cam break in. Here's a pic of the control panel.
Many thanks again to Spoke for his help with the wiring. Everything works as expected.
bbrock
post May 23 2019, 08:56 PM
Post #22
Wow Doug! That is the mother of all run stands. Nice work (IMG:style_emoticons/default/thumb3d.gif)
Superhawk996
post May 24 2019, 03:44 AM
Post #23
(IMG:style_emoticons/default/biggrin.gif) Nice stand. Great job!
I'll likely build something similar to start an engine and just make sure I can get D jet firing and the engine running before I go to the trouble of installing the engine.
One point of note. Don't assume the engine stand will provide a complete break in. You want varying load on the engine as well as just varying RPM's without load.
You probably know that already but I wanted to put it out there. Stands are a great way to verify basic functionality though!
doug_b_928
post May 24 2019, 06:17 AM
Post #24
Thanks guys. I didn’t know that about break-in. So once you have the cam broken-in on the stand and the engine installed in the car, do you just do like the new cars and keep it under 4,000 rpm for x number of miles?
Superhawk996
post May 24 2019, 06:50 AM
Post #25
QUOTE(doug_b_928 @ May 24 2019, 08:17 AM) *
Break in is a debated topic full of myth, legend and handed down stories. (IMG:style_emoticons/default/happy11.gif)
I'd suggest reading various opinions from engine builders and deciding for yourself. Tom Wilson How to Rebuild your Volkswagen Air Cooled Engine book is a good starting point.
I'll give you a couple of personal opinions:
New cars do really don't need break like we typically think of for vintage engines. I say this as an automotive engineer working in the industry. There are a ton of reasons for this ranging from metallurgy to manufacturing methods and modern tolerances. That said, a mild break in is still called for and isn't a bad thing. Bottom line we design cars knowing that most can't or won't take the time to do a break in. We now do extensive dyno testing and thermal shock type testing that wasn't done in the 70's. We do lots of -40F cold starts and rapid drive away testing that would make you cringe and engines still survive. The list goes on.
The reason for varying load and RPM's is to get the rings well seated to the cylinder walls and within the piston groves. Varying RPM and load helps expedite this process. I'll spare you the long form explanation of why this is so. Think rod stretch, thermal expansion, and variances in combustion pressures and you'll be on the right track.
The best thing during this process is to get it running, let it run under light load with some variance of RPM's and then to dump the oil after say 20 minutes. Get rid of the fine particles of metal that are shedding from everywhere.
Then change oil after about 100 miles driving. Then again at 300. And again at 1000 miles. keep the oil clean during this process. Use Dinosaur oil. It will work better for break in and is cheaper too since you'll be using a lot of it.
Now let the controversy begin. (IMG:style_emoticons/default/stirthepot.gif)
VaccaRabite
post May 24 2019, 07:08 AM
Post #26
En Garde!
The break in that I used is the Raby method from many years ago.
As soon as the engine starts for the first time after a rebuild, run it for 20 minutes at 2K RPM. That is to break in the cam and lifters.
Once the engine is in the car, go for a drive to get it warm. Then hammer it in 2nd gear all the way to redline and let it cost back down to a crawl, then hammer it all the way back up to redline and let the car coast back down again. And that is the break in to seat the rings.
Zach
doug_b_928
post May 25 2019, 07:30 AM
Post #27
Interesting info on break-in, guys. Jake's method certainly sounds like fun!
I have to say it's very satisfying to see it actually work. Here's a link to a short youtube video of the stand 'in action':
https://youtu.be/o4QHTLtkIzU
Superhawk996
post May 25 2019, 07:55 AM
Post #28
I was wondering what you were going to do with that stand on that awesome patio as I thought to myself about notorious 914 oil leaks.
Glad to see you employed the standard solution - cardboard box. (IMG:style_emoticons/default/av-943.gif)
Improved version = built in oil catch pan. (IMG:style_emoticons/default/laugh.gif)
Really nice job -- video is great. (IMG:style_emoticons/default/first.gif)
doug_b_928
post May 25 2019, 10:52 AM
Post #29
Well....I admit that some leaked on the concrete before I noticed. It's leaking like a sieve from the right valve cover. Sealing that concrete is one of my many 'yard tasks' that has been delayed due to the time it took to finish this engine stand. On that note, I'm sticking with the cardboard rather than engineering a removable oil catch tray... (IMG:style_emoticons/default/biggrin.gif)
cary
post Nov 28 2019, 10:31 AM
Post #30
Thanks doug b 928, Jack and I are about ready to start wiring our test stand.
doug_b_928
post Nov 28 2019, 10:40 AM
Post #31
Post up some pics/link to vid when you get it done. (IMG:style_emoticons/default/beerchug.gif)
cary
post Nov 28 2019, 10:43 AM
Post #32
D Jet was just plug and play coming out of the relay board ?
doug_b_928
post Nov 28 2019, 10:46 AM
Post #33
I'm not sure exactly what you're asking. Everything from the relay board to the engine is as it is in the car. Everything from the relay board to the control panel I made myself from scrap pieces from an old harness.
cary
post Nov 28 2019, 11:13 AM
Post #34
That was the question. As it is.
Didn't see anything in your schematic, but thought I should ask. Thanks.
cary
post Dec 21 2019, 01:19 PM
Post #35
Here's a couple shots of our progress. Engine drop stand is detachable. Car drops right onto to stand. Run portion is a separate cart. Arms will turn 90 degrees and out of the way when not in use.
Can't thank you enough for the wiring diagram.
doug_b_928
post Dec 22 2019, 07:54 AM
Post #36
Looks really nice Cary!
BeatNavy
post Dec 22 2019, 08:10 AM
Post #37
That is a super sweet setup, Cary. Wouldn't expect anything less from you, though (IMG:style_emoticons/default/smile.gif)
Spoke
post Dec 22 2019, 09:28 AM
Post #38
Jerry
Nice looking stands. One thing I noticed about the schematic I showed before, the alternator was not part of the schematic. Here is an updated schematic with the alternator shown connected directly to the battery as in the car.
The 3 wire cable from the alternator to the VR on the relay board is not shown as that is a direct connection and not something that needs to be detailed on this schematic.
cary
post Dec 30 2019, 11:12 AM
Post #39
Spoke ???
I ran separate fused wires to 12 & 14 on the relay board. What size fuse ?
I see you call out 50amp on on the double wire.
cary
post Jan 2 2020, 09:46 AM
Post #40
After sitting 8 years assembled the DP engine finally running on the engine stand.
Can't help you with the muffler sound .............. Might buy a new Bursch for my car
and let DP hear the difference.
https://www.youtube.com/watch?v=SJ03kmJpZfE
https://www.youtube.com/watch?v=jb55tGh-Cpg
Wish I could tinker some more, but she'll sit till the chassis is repaired.
I'll take some shots of the control unit when I pull it off today.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 26th December 2024 - 10:22 PM
