Wiring for an Engine Run Stand with DJet |
Spoke |
Jan 2 2020, 10:06 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Spoke ??? I ran separate fused wires to 12 & 14 on the relay board. What size fuse ? I see you call out 50amp on on the double wire. I used 50amp since the fuel pump is powered by these pins and the fuel pump itself has a 20amp fuse. The 50amp is a swag at something that would be high enough to not blow under normal operation and low enough not to fry wires. |
Lo-Fi Version | Time is now: 26th December 2024 - 10:22 PM |
