63 Pages V « < 54 55 56 57 58 > »
> Why Didn't You do Anything to Your 914 Today?, or, What the Fuch is Keeping You From Working on it?
AZBanks
post Jan 3 2024, 10:03 PM
Post #1101
Became this:
914 Ranch
post Jan 12 2024, 06:24 AM
Post #1102
Team Sharp where the 914 grow wings
7am here and just back from the store with 6 racks of Bade back ribs
To go with the 9 already here. The process takes me all-day, 2.5 hrs of smoking. When they look good enough I wrap them in pink butcher paper after coating them in SMOKED TALLOW. These last 2 things changed up my game. My RIBS are sweeter and juicy plus wrapped in the pink butcher paper they cooked quicker. I leave the ribs in the smoker until they have about 3/8" of pull back(3/8" of bone showing past the meat). I'll post a picture when I unwrap them. 15 racks that's about 270 bones.
The picture shows about 1/2" pull back, if I twist a bone it will just come out...
Oh boy, I can see some guacamole coming my way.
Gatornapper
post Jan 12 2024, 07:48 AM
Post #1103
As noted on my rebuild thread, pulled my tranny yesterday with engine staying in car, car on lift. Strangely lost 4/5 after about 30 min. of near perfect shifting on 1st drive after tranny rebuild.
Pulled end plate off tranny last night, pulling gears out today. Dr. Evil (Mike Lesniak) & I agree on most likely cause. Will see.......
GN
Front yard mechanic
post Jan 12 2024, 09:02 AM
Post #1104
BrrAttached Image
rangrbob
post Jan 12 2024, 08:20 PM
Post #1105
Been working on another restoration, and unfortunately the 914 is in storage.
https://forums.ifsja.org/forum/tire-kickin/...10-golden-eagle
East coaster
post Jan 13 2024, 06:46 AM
Post #1106
QUOTE(rangrbob @ Jan 12 2024, 07:20 PM) *
Cool, here’s my J10 I picked up this summer
anderssj
post Jan 13 2024, 09:50 AM
Post #1107
Dog is my copilot...
More Volvo fun:
(IMG:style_emoticons/default/barf.gif)
Volvo ran the alternator harness (B+, D+, oil pressure sender wire) between the engine block and the alternator bracket. Good for 30 years. Battery drained through the pressure sender and the warning light on the dash. Fortunately the short was contained inside the harness cover. REALLY lucky!
Jett
post Jan 13 2024, 03:18 PM
Post #1108
Put a Bluetooth adapter in-line of the Becker CDR-210 in our 996 turbo…pretty simple
Root_Werks
post Jan 14 2024, 05:21 PM
Post #1109
Village Idiot
New 3-4-5 gears in my Bug. Been having fun driving it the past few days. The 914 is a bit envious.
rgalla9146
post Jan 14 2024, 08:34 PM
Post #1110
I fixed this...my crooked ash tray. It's adjuatable.
There are two 7mm nuts. One on each side...difficult to reach but worth the effort
Jett
post Jan 15 2024, 09:13 AM
Post #1111
QUOTE(rgalla9146 @ Jan 14 2024, 06:34 PM) *
Good motivation… mine is doing the same…
Beach914
post Jan 15 2024, 09:23 AM
Post #1112
Playing with a new toy.
euro911
post Jan 22 2024, 04:19 PM
Post #1113
Following the progress on the replacement for my final 914 ...
Shivers
post Jan 22 2024, 07:27 PM
Post #1114
QUOTE(euro911 @ Jan 22 2024, 02:19 PM) *
Looks great
ClayPerrine
post Jan 29 2024, 06:56 AM
Post #1115
Yesterday I was helping out my neighbor and his son with their car project. It is a 1986 Volvo 240DL Wagon that had an 6.0L LS engine and transmission swap from a Silverado pickup. It was done by the previous owners as a Lemons car build, but was never raced. It has really nice suspension upgrades as well.
We have dubbed the car "The Volvolet."
I helped them replace the cable driven speedometer with an electronic speedo driven from the ECU. The new cluster also came with a tachometer, so I wired that to the ECU as well. I used a 240 ohm pullup resistor to get the tack to trigger off the ECU input.
I originally got involved with it because it was losing power and hard to start. Found the fuel pressure was low, and traced it back to the hose between the in tank pump and the sender body. The hose was split and bleeding fuel pressure back into the tank. What made it such a bitch to find was that there was no external fuel leak. Once we got that fixed, the car was much happier and way more powerful.
Our next task on it is to install the coolant temp sensor from the Volvo into the chevy coolant passages in the intake so the coolant temp gauge will work.
I actually considered inviting them to Okteenerfest just to see this beast tear up the tail of the dragon.
Cairo94507
post Jan 29 2024, 03:53 PM
Post #1116
Michael
Wow! What a sleeper. (IMG:style_emoticons/default/beerchug.gif)
anderssj
post Jan 29 2024, 07:02 PM
Post #1117
Nice work, Clay!
And it’s a wagon! Geez I miss mine….
euro911
post Apr 28 2024, 05:25 PM
Post #1118
Been building another shelter in the back yard. Need enclosed space for a bunch of stuff that needs to get moved out of my garage so I can park a car in it again ...
Building the permanent double barn doors next, then going to install a metal roof (IMG:style_emoticons/default/idea.gif)
Freezin 914
post Apr 28 2024, 05:54 PM
Post #1119
Went with my stepson to a VW swap meet in IL, buying up some parts for his 73 Beetle.
Jett
post Apr 28 2024, 08:20 PM
Post #1120
Cleaned the garage after disassembling the underside of our 76 and sending it all off for restoration . …now the robots are vacuuming and mopping the floors (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 19th April 2025 - 02:51 PM
