63 Pages V « < 8 9 10 11 12 > »
> Why Didn't You do Anything to Your 914 Today?, or, What the Fuch is Keeping You From Working on it?
euro911
post Aug 4 2019, 01:22 PM
Post #181
I feel your pain when it come to letting smoke escape ... (IMG:style_emoticons/default/laugh.gif)
ValcoOscar
post Aug 4 2019, 01:28 PM
Post #182
Garage Life
QUOTE(euro911 @ Aug 4 2019, 12:22 PM) *
Dang Mark..I can see you're a part time Dentist.
Oscar
Superhawk996
post Aug 4 2019, 01:43 PM
Post #183
QUOTE(euro911 @ Aug 4 2019, 03:22 PM) *
Nice bench! Resolution a bit low but looks suspiciously like HAM radio gear.
I wonder how many folks we have on here that live in both electronic/electrical worlds and the mechanical side? I've made a career of being the Mechanical Engineer that could understand and work with the Electrical Engineers. (IMG:style_emoticons/default/dry.gif) Especially so now as everything is electro-mechanical.
Someone once said the 19th century was improved by ME's, the 20th by the EE's, and now 21st is going to dominated by the Software Engineers. Seems right so far. I'm just a man from a bygone time. (IMG:style_emoticons/default/biggrin.gif)
914Sixer
post Aug 4 2019, 01:48 PM
Post #184
103 Degrees today
Superhawk996
post Aug 4 2019, 01:56 PM
Post #185
QUOTE(914Sixer @ Aug 4 2019, 03:48 PM) *
103 Degrees today
That a valid excuse!
Last winter I insulated my metal garage doors. It's now paying dividends - window A/C now keeps up with the summer heat!
euro911
post Aug 4 2019, 04:21 PM
Post #186
Every mechanic worth his/her salt should have a good assortment of dental picks, Oscar ... but I do also have a nice assortment of pliers (and pain meds) too (IMG:style_emoticons/default/poke.gif)
Yep, I still tinker with old tube and early transistor radio communications gear every now and then. The new surface mount stuff is for the kids with good eyes and steady hands (IMG:style_emoticons/default/shades.gif)
My AZ main garage door is shaded from the front deck so it doesn't get too warm in the summer, but it DID get real cold in the winter. I also installed those 1" foil-sided foam boards and it made a huge difference in the winter.
My RV garage gets full sun all day long, but I had the house painted last summer and went with a light tan color on the garage doors. It's helped to keep the heat down, but winter's a different story. It's a roll-up door so I don't think it can be insulated (?). I may have to install a roll-up curtain or something (IMG:style_emoticons/default/confused24.gif)
euro911
post Aug 6 2019, 04:25 AM
Post #187
More Ghia work. Installed a 70's circa JetSounds AM/FM/Cassette deck in the dash. It was originally in my '71 914 when I bought it. I also replaced the deteriorated cardboard glove box insert with a new one made from ABS. The trunk release lever is mounted in the glove box, and it had broken loose ripping the cardboard to shreds, and making somewhat of a trick to open the trunk. The toughest part of this task was making sure to drill the (7) holes to mount the entire mechanism in the exact spot it needed to be in, plus cutting a slot in the bottom for the release cable to exit. It was originally installed with rivets, but I used #8 screws, flat washers and nutz to reinstall it (just in case I fuched-up my measurements). Thankfully, it all worked out just fine (IMG:style_emoticons/default/mueba.gif)
Found a bag with all the front 3-point seat belts parts, so those got installed too. Also found and installed the little spring that flips the gas filler door open. No more reaching in to pull the handle under the dash with the left hand while stretching to pry the door open with the finger nails on the other hand (IMG:style_emoticons/default/aktion035.gif)
Then I decided to wash it. A prospective buyer is coming to check it out on Wednesday, so it'll look nice and pretty (IMG:style_emoticons/default/cheer.gif)
... Then I drove it around the neighborhood to make sure any water I missed while wiping it dry got blown off (IMG:style_emoticons/default/driving.gif)
Spoke
post Aug 6 2019, 05:29 AM
Post #188
Jerry
QUOTE(Superhawk996 @ Aug 4 2019, 01:22 PM) *
QUOTE(Spoke @ Aug 4 2019, 08:05 AM) *
Had to design and print this. Any guesses to what this is?
Mini electric chairs?
Close. This will be a test fixture for a CPU PCB and a sensor PCB. The printed plate they are on will be a PCB. The "electric chairs" are clamps to hold the PCBs in place. There will be spring loaded probe pins on the test PCB to make all the connections to the CPU and sensor PCBs.
falcor75
post Aug 6 2019, 05:42 AM
Post #189
https://www.youtube.com/watch?v=PlU5BStIb1s
Because the wifes daily decided it was too good for boost. (IMG:style_emoticons/default/biggrin.gif)
AZBanks
post Aug 6 2019, 08:06 AM
Post #190
Because I am in Orlando and it is in Phoenix.
post Aug 6 2019, 10:28 AM
Post #191
QUOTE(Larmo63 @ Aug 3 2019, 12:46 PM) *
I did a solo drive out, up, and over the Ortega Highway. My car is in good nick and there was open road both ways!
Beautiful morning.
Stopped there many a time. It reeks of Piss smell if the wind is out of the east. (IMG:style_emoticons/default/sunglasses.gif)
Ferg
post Aug 6 2019, 10:37 AM
Post #192
Lots of two wheel action this summer.
post Aug 6 2019, 10:44 AM
Post #193
QUOTE(euro911 @ Aug 6 2019, 03:25 AM) *
I know lots of KG's have those bumper deletes but they look out of place. Like the represent speed. On a KG? (IMG:style_emoticons/default/av-943.gif) IMHO, KG's look beautiful when dressed out with the proper bumpers and overriders. FWIW, the nose on mine was virgin which is rare. It sold quickly because of the unmolested nose cone. GLWS Mark. (IMG:style_emoticons/default/beerchug.gif)
Mikey914
post Aug 6 2019, 10:46 AM
Post #194
The rubber man
QUOTE(Dion @ Aug 3 2019, 03:09 PM) *
Nothing exciting....catalogued and sorted inventory so I can put my car
back together (IMG:style_emoticons/default/idea.gif)
Love it !
Maybe we should just sell a tool chest fully loaded like this (IMG:style_emoticons/default/idea.gif)
ValcoOscar
post Aug 6 2019, 10:47 AM
Post #195
Garage Life
Dion-
@Dion
I like your parts organization.
Great use of old flat file cabinets too.
I threw away about five of them a few years ago (IMG:style_emoticons/default/headbang.gif)
(IMG:style_emoticons/default/beer3.gif)
Oscar
Dion
post Aug 6 2019, 10:58 AM
Post #196
RN
QUOTE(ValcoOscar @ Aug 6 2019, 08:47 AM) *
Dion-
@Dion
Oscar
Thanks Oscar! A shop was closing down a few years back so Dave & I ran over there and
snagged 4 of them. (IMG:style_emoticons/default/beerchug.gif)
Dion
post Aug 6 2019, 11:01 AM
Post #197
RN
QUOTE(Mikey914 @ Aug 6 2019, 08:46 AM) *
Love it !
I like it, Buy in bulk! I would have gone for it Mark!
jd74914
post Aug 6 2019, 01:09 PM
Post #198
Its alive
QUOTE(Superhawk996 @ Aug 4 2019, 12:37 PM) *
Check out these power supply capacitors. There are four of them at 47,000 uF. 7oz mini Mountain Dew for relative size comparison.
You should see the ones I changed on our laser...$1300 ea and the size of a gallon paint thinner can; 75 uF @ 2.5kV. Making sure they were discharged correctly was just a little scary-the official instructions actually said to use a screwdriver. (IMG:style_emoticons/default/blink.gif)
Gatornapper
post Aug 6 2019, 01:13 PM
Post #199
Not 103, but still too hot to work in garage until the sun goes down......
GN
QUOTE(914Sixer @ Aug 4 2019, 01:48 PM) *
103 Degrees today
914-300Hemi
post Aug 6 2019, 01:16 PM
Post #200
Car is in So. Cal and I’m in Maui.
- Lo-Fi Version Time is now: 19th April 2025 - 02:52 PM
