anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,736 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
Water heater leaking...in attic on second floor (IMG:style_emoticons/default/dry.gif)
Fortunately, I new where the all the water and gas cutoffs were. Unfortunately, the access to attic is smaller than the water heater (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/mad.gif) ![]() ![]() Sides of access hole are vertical members of prefab trusses (of course), with wiring/junction boxes (of course). |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,271 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
QUOTE(anderssj) http://www.914world.com/bbs2/uploads_offsi...611425688.1.jpg[/img]1, 11:36 AM' post='2885102'] Water heater leaking...in attic on second floor (IMG:style_emoticons/default/dry.gif) and access to attic is smaller than the water heater (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/mad.gif) ![]() ![]() Sides of access hole are vertical members of prefab trusses (of course), with wiring (of course). (IMG:http://www.914world.com/bbs2/uploads_offsite/i.etsystatic.com-1143-1611425688.2.jpg) |
anderssj |
Well, OK then...
I was able to cut a new access hole from inside the upstairs bedroom's closet. New access is between the trusses where the heater sits. (IMG:style_emoticons/default/piratenanner.gif) ![]() New heater going in now. We will have to be careful around the lines coming out of the floor...and it will be some work to reframe and insulate, but nothing like expanding the existing access would have been. I'm thinking of adding an auto shut-off (that second floor thing again). And maybe replacing the heater at about 10 years... |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,260 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
So I have to ask... why is the water heater on the second floor (and in the attic)? The leaking issue aside (as you have discovered), but a full water heater is 300-400 lbs, depending on capacity, PLUS the weight of the empty unit. Seems like floor loading would also be a concern.
AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,064 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
I can't work on the 914 because the 944 Cab is hogging the jack stands.
anderssj |
So I have to ask... why is the water heater on the second floor (and in the attic)? The leaking issue aside (as you have discovered), but a full water heater is 300-400 lbs, depending on capacity, PLUS the weight of the empty unit. Seems like floor loading would also be a concern. Finished the job around 4PM. Old unit came out fine, new unit went right in too. So far, so good. And you're right, 50 gal unit weighs 400+ lbs when full. AC, gas furnace, and air handler are also in the attic. Go figure. FWIW, I agree with you, but that's how the builder designed it...and it seems to be a relatively common approach here in VA. This particular installation (with the too-small access) should NOT have passed code/inspection. (IMG:style_emoticons/default/confused24.gif) Already planning to raise that issue with the city/county inspectors just so they are aware in the future. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,791 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Attached thumbnail(s) ![]() |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,878 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Maybe the builder installed the tank in the attic to keep the system from freezing in the winter months?
Have you thought about building a door for the opening? ... less hassle for when 'the next time' comes to pass (IMG:style_emoticons/default/idea.gif) Also, does the catch basin have a drain hose going to the exterior of the house? |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,559 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Still no work, but getting stuff moving in the garage...got the 356 started for the first time in years...and the last time had a fuel leak, got that fixed.
Also loaded the bridge jacks on the lift, but they roll like ass and Amy trying to figure out why. Next I need to restore/paint some cabinets and get them in place. Fingers crossed 914 work begins this year. |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,843 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Spent quality time with the wife. Happy wife.. more Porsche parts!!
euro911 |
LOL ... my wife's happy when I get rid of stuff (IMG:style_emoticons/default/dry.gif)
Saturday morning, I braved the rain - washed the Tacoma, the Subaru and the Vanagon ('Eileeen') (IMG:style_emoticons/default/FERG.gif) - and let the downpours apply the final rinse (IMG:style_emoticons/default/pat.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Early B-day present from the wife...hope to have it up and running next week.
For scale the red plate is 10" in diameter. Lathe is a 12"x36" capacity. (Dia x length for part in theory ) ![]() ![]() ![]() |
roundtwo |
Member ![]() ![]() Group: Members Posts: 314 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California ![]() ![]() |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,550 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
I traded some of my time doing metal work on a friend's hot rod for his 2001 CL500. It's actually pretty fast!
Sadly, they are depreciation kings of the highest order. It's mechanically sound but has a ton of broken little cosmetic things and needs too much to make it worth "fixing". So, I'm thinking gut it, cage it and go Group 5-style wide body! (IMG:style_emoticons/default/aktion035.gif) Lemons / track / drift car anyone? (IMG:style_emoticons/default/shades.gif) Attached thumbnail(s) ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,297 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
That will be a beast!
brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Although I didn't drive it today, I removed the bumpers and have them out to be refinished. I didn't drive today because my car now has no carbs and as you guys know, it don't run too well without them carb thingys........... The other thing I will tell you from my experience is do not park your car in the remote parking are of the SoCal Ritz Carlton coastal Resort. That is where the unfortunate theft occurred.
Not of the carbs - My Isuzu trooper about twenty years ago. (IMG:style_emoticons/default/lol-2.gif) The IDT3C and C1 carbs are in SoCal sitting on the Carb Guru's bench in exchange for a fully rebuilt top to bottom set of 40IDA's now due a week out from now. (see PIX) (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) ![]() |
tygaboy |
Benz track day car prep is well under "weigh"! (IMG:style_emoticons/default/lol-2.gif)
This beasty is HEAVY! 3977 lbs. The interior is now mostly gutted. The seats are heated, ventilated and have a massage feature. They must weigh 100 lbs each. Not kidding. This thing is so over-engineered/built/full of ridiculous luxury, it's no wonder no one uses them as the basis for a race ca, er, wait... Fear not, this was all but a throw away car as it needed all that luxury stuff fixed and it wasn't worth fixing. First load to the dump was just over 200 lbs and that didn't include the seats, glass, airbags (8 of those in the car) and a ton - pun intended - of other crap that will be removed. Cage building starts soon. Attached thumbnail(s) ![]() Attached image(s) ![]() ![]() |
Mueller |
That car is going to fun there Chris.
I spent some time the last few days cleaning and organizing the garage again. Made some holders for the nut drivers so it would easier to access and grab the correct one instead of flopping around in the top drawer of my tool box. Made these from some material I've had sitting in the shop for like 20 years, I think it is nylon? ![]() ![]() ![]() ![]() |
Mueller |
Double double...
Lo-Fi Version | Time is now: 20th April 2025 - 09:28 PM |
