WTB - complete Subaru conversion kit |
finchmunoz |
May 20 2019, 05:23 AM
Newbie Group: Members Posts: 34 Joined: 3-July 11 From: Manila, Philippines Member No.: 13,272 Region Association: None |
Hi.
Does anyone know where I can get a complete Subaru conversion kit? Cradle, cable shifter, etc. The daughter is gonna start driving it and needed to make it reliable... I want t include the Subaru transmission so easier to drive. Also, is this "reversible"? Meaning I can put back my type4 engine by just unbolting and remounting? Thanks Finch |
Chi-town |
May 20 2019, 09:33 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Nobody makes a good complete kit at the moment.
You can overpay for the renegade stuff which is questionable quality and is designed to fit with the 901 trans. |
May 20 2019, 10:59 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Nobody makes a good complete kit at the moment. You can overpay for the renegade stuff which is questionable quality and is designed to fit with the 901 trans. (IMG:style_emoticons/default/agree.gif) There are a few suppliers of different parts that will let you put together a “kit”. Besides the suby trans, which is a good idea, what engine are you thinking of and how much work can you do yourself? I think everything can be easily reversible in the future. Even some of the mods that people do, like holes and clamps for the radiator and a welded bulkhead engine mount wouldn’t be more work to reverse than typical rust repair. |
Chris914n6 |
May 20 2019, 01:28 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
For the amount of money and effort to do a full swap you can make the VW reliable.
Chi-town |
May 20 2019, 04:47 PM
For the amount of money and effort to do a full swap you can make the VW reliable. Did you just VW and reliable in the same sentence? (IMG:style_emoticons/default/screwy.gif) |
76-914 |
May 20 2019, 06:24 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
For the amount of money and effort to do a full swap you can make the VW reliable. True, but it will still be a 50yo antique with a diminishing supply of OEM parts. Throw a Subaru in there and when it's time for a repair you can get parts at an Auto Zone or throw another engine in it for <$1000. |
finchmunoz |
May 21 2019, 04:24 AM
finchmunoz |
May 21 2019, 04:31 AM
Nobody makes a good complete kit at the moment. You can overpay for the renegade stuff which is questionable quality and is designed to fit with the 901 trans. (IMG:style_emoticons/default/agree.gif) There are a few suppliers of different parts that will let you put together a “kit”. Besides the suby trans, which is a good idea, what engine are you thinking of and how much work can you do yourself? I think everything can be easily reversible in the future. Even some of the mods that people do, like holes and clamps for the radiator and a welded bulkhead engine mount wouldn’t be more work to reverse than typical rust repair. Nothing too strong really. Just maybe the ej20 non-turbo. I think the mounting is the easy part. It's the shifter I'm worried about. Does anyone know how to convert from the 914 shifter to a Subaru shifter? (Do I need to)? |
May 21 2019, 05:59 AM
Sorry dp
May 21 2019, 06:00 AM
Nobody makes a good complete kit at the moment. You can overpay for the renegade stuff which is questionable quality and is designed to fit with the 901 trans. (IMG:style_emoticons/default/agree.gif) There are a few suppliers of different parts that will let you put together a “kit”. Besides the suby trans, which is a good idea, what engine are you thinking of and how much work can you do yourself? I think everything can be easily reversible in the future. Even some of the mods that people do, like holes and clamps for the radiator and a welded bulkhead engine mount wouldn’t be more work to reverse than typical rust repair. Nothing too strong really. Just maybe the ej20 non-turbo. I think the mounting is the easy part. It's the shifter I'm worried about. Does anyone know how to convert from the 914 shifter to a Subaru shifter? (Do I need to)? A company called very cool parts.com makes a shifter, cable, linkage setup for the suby trans. Or you can just use their linkage and use a stock shifter from an mr2 and 7 foot cables. @finchmunoz |
Chi-town |
May 21 2019, 08:42 AM
SW20 MR2 shifter, cables and Bell crank system are readily available thanks to the FFR 818 guys.
Stick with an NA motor. Wether it's a 2.5 or a 3.0/3.6 they all make way more power than a beginner driver needs in a 914. The turbo motors create headaches with intercooler mounting and air flow. And stay away from the jdm imported engines! |
JOEPROPER |
May 21 2019, 04:38 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
SW20 MR2 shifter, cables and Bell crank system are readily available thanks to the FFR 818 guys. Stick with an NA motor. Wether it's a 2.5 or a 3.0/3.6 they all make way more power than a beginner driver needs in a 914. The turbo motors create headaches with intercooler mounting and air flow. And stay away from the jdm imported engines! What's wrong with JDM engines??? |
finchmunoz |
Dec 29 2019, 10:39 PM
Nobody makes a good complete kit at the moment. You can overpay for the renegade stuff which is questionable quality and is designed to fit with the 901 trans. (IMG:style_emoticons/default/agree.gif) There are a few suppliers of different parts that will let you put together a “kit”. Besides the suby trans, which is a good idea, what engine are you thinking of and how much work can you do yourself? I think everything can be easily reversible in the future. Even some of the mods that people do, like holes and clamps for the radiator and a welded bulkhead engine mount wouldn’t be more work to reverse than typical rust repair. I'm in the Philippines. Labor is dirt cheap. So I guess I can have someone do the work for me. Problem is the "know how" and finding the right parts. Traffic is so horrible here an stock 1.7L air-cooled engine with air conditioning will overheat here. |
finchmunoz |
Dec 29 2019, 10:43 PM
So, anyone here recommend a kit to adapt an ej20 engine to my 71 using 901 transmission? Maybe I'd just get a rennshifter instead.
Chi-town |
Dec 29 2019, 11:37 PM
You can get the parts from Renegade hybrids of you want to keep the stock trans
Steve |
Dec 30 2019, 11:55 AM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Everything is reversible except for the hacking of the front trunk for the radiator.
Mueller |
Dec 30 2019, 12:01 PM
Kennedy Engineering will have a kit to adapt the engine and transmission together.
The rest of the swap has to be put together from other sources. https://www.kennedyeng.com/engine-adapters |
ahycaramba |
Dec 30 2019, 12:52 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
From my experience I highly recommend doing the work yourself. You have control of quality over your own project. When you rely on others you are at their mercy financially and your projects definition of quality may not be at par with yours.
Other than the plenty of great advise and articles here on the world I have found a couple of good pages on Facebook that would benefit you. “Subaru powered Porsches” and “Subaru Powered Volkswagens” Good luck on your project. |
914forme |
Dec 30 2019, 05:40 PM
Everything is reversible except for the hacking of the front trunk for the radiator. Even that is reversible if done correctly (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/welder.gif) just like fixing rust, or that hole that got cut in the front for A/C by the dealer with a screwdriver and a can opener. |
Jonathan Livesay |
Dec 30 2019, 06:05 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Everything is reversible except for the hacking of the front trunk for the radiator. that hole that got cut in the front for A/C by the dealer with a screwdriver and a can opener. I've never seen a better description. (IMG:style_emoticons/default/134.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 05:36 PM |
