914-6 wiper motor question |
mb911 |
Jun 2 2019, 10:32 AM
914 Guru Group: Members Posts: 7,385 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
As I work on my -6 clone I was wondering what most use for the wiper motor? I swear someone mentioned using a 944 motor??
rgalla9146 |
Jun 2 2019, 01:15 PM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
What harness and switch are you using ?
If a 6 or 911 switch use a 911 3 speed motor adapted to your 914 wiper rack. |
Jun 2 2019, 02:27 PM
914-6 GT in waiting Group: Members Posts: 19,671 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I didn't realize the 6 switch needed a 6 motor. Will the 914-4 motor work?
sixnotfour |
Jun 2 2019, 02:45 PM
914 Wizard Group: Members Posts: 10,695 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I didn't realize the 6 switch needed a 6 motor. Will the 914-4 motor work? 3spds baby (IMG:style_emoticons/default/driving.gif) but ya you can and make it interval option |
rgalla9146 |
Jun 2 2019, 05:08 PM
Sixes always had a 3 speed wiper like a 911
Choose a 911 motor that is configured like the original 914 one. There are versions with the 'snail gearbox' on one side and others with it on the opposite side. Are you adapting a 911 steering column and switches ? |
mb911 |
Jun 2 2019, 05:20 PM
Yes I am using an early 911 switch and happen to have an extra 944 motor and thought that may work..
bbrock |
Jun 2 2019, 05:57 PM
Yes I am using an early 911 switch and happen to have an extra 944 motor and thought that may work.. Stealing parts from your son's car is not "extra." (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
burton73 |
Jun 2 2019, 06:01 PM
burton73 Group: Members Posts: 3,703 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Mark Henry |
Jun 2 2019, 06:13 PM
Damn another thing to collect (IMG:style_emoticons/default/dry.gif)
I have a wiper motor from a '76 911.....Yay? nay? (IMG:style_emoticons/default/unsure.gif) |
914Sixer |
Jun 2 2019, 08:18 PM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Use a 914 rack and put the later 911 3 speed motor that looks just like the 914 2 speed. Wire from there. -6 motors are unique to themselves.
Mark Henry |
Jun 2 2019, 09:29 PM
Thanks ...now to find where I put it.
porschetub |
Jun 3 2019, 12:31 AM
Advanced Member Group: Members Posts: 4,759 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Ben ,go for the 914 drive gear and Boxster motor,good upgrade,I think Mcmark detailed it a ways back,seemed pretty easy,sorry cant find the link.
I bought a Boxster motor to do mine,another future job (IMG:style_emoticons/default/rolleyes.gif) . |
Gary |
Jun 3 2019, 03:54 AM
Senior Member Group: Members Posts: 746 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
mb911 |
Jun 5 2019, 07:20 AM
Just an update the 944 motor is 3 speed.. Confirmed this morning.
racerbvd |
Jun 5 2019, 04:24 PM
Advanced Member Group: Members Posts: 2,369 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Use a 914 rack and put the later 911 3 speed motor that looks just like the 914 2 speed. Wire from there. -6 motors are unique to themselves. True, and if you are lucky enough to find one, it won't be cheap. A$k me how I know (IMG:style_emoticons/default/beer.gif) |
porschetub |
Jun 5 2019, 08:49 PM
Just an update the 944 motor is 3 speed.. Confirmed this morning. Yes I think you will be ok ,the 944 one has a good speed on full ,appears there is a lot of other motors they may fit within the VW group when they went to 3 speed,if adding to a 911 switch this is an easy option with wiring matched up. I see no point in replacing a motor @ this point unless it works better,the 914 one is rather (70's) slow (IMG:style_emoticons/default/sad.gif) . |
mb911 |
Jun 6 2019, 05:12 AM
I am doing the complete 911 /left hand ignition so now is good enough time as any to do the swap..
ClayPerrine |
Jun 8 2019, 05:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,958 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just buy a 911 wiper motor setup. Set the 911 wiper rack next to the 914. You will see that the tubes that pass the arms through the cowl are longer on a 911. So take the 911 wiper rack apart and shorten the tubes to the same length as the 914 rack. Then put the shafts and arms from the 914 rack into the 911 rack. Use the 911 motor. Or, just get a 964 wiper rack assembly. It will bolt right into the holes on the 914, and it sits much closer to the cowl on the underside. You will have to make a support for the motor though. |
Lo-Fi Version | Time is now: 3rd January 2025 - 12:58 AM |
