| stevend914 |
Jun 10 2019, 09:25 AM
Member ![]() ![]() Group: Members Posts: 386 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest
During my recent travels to Texas, California, and Route 66 Rallye I noticed a bit of a hiccup while driving - the engine has a drop in power but immediately is back to full power. I noticed the same thing on my trip to Wisconsin this past Thursday. However on Saturday during a rather spirited drive in SW Wisconsin, the engine stopped and after pressing harder on the accelerator pedal with no results, I drifted to the side of the road. On the second try at restarting, the engine fired up and I was able to drive off and had no further issues (ok, I did a 180 degree spin at one hairpin curve). Anyway, I'm driving back to STL on Sunday and after driving 300 miles all of a sudden I have no power on Interstate 55. So after hitting the accelerator pedal again with no results I start drifting over to the right lane and get ready to stop on the shoulder of the highway...but after drifting for 5 seconds or so, the car restarted and had no further problems for the remaining 130 miles home. My question is, does anyone know what the problem is, I'd like to fix it before it fails completely!! Thanks
| barefoot |
Jun 10 2019, 09:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,569 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Carbs,,? Fuel Injection? Stock ignition ? need more info
| dr914@autoatlanta.com |
Jun 10 2019, 10:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,253 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| stevend914 |
Jun 10 2019, 10:58 AM
Carbs,,? Fuel Injection? Stock ignition ? need more info yup sure do, for example if a fuel injected 1.8 could be a bad connection at the dual relay or bad dual relay Stock ignition, fuel injection, stock '74 2.0 engine |
| pvollma |
Jun 10 2019, 06:40 PM
Member ![]() ![]() Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region
My question is, does anyone know what the problem is, I'd like to fix it before it fails completely!! Thanks This happened to me once (76 2.0). A couple of slow-downs, then a complete lack of power. Couldn't restart it, had it towed to the shop, whereby it immediately fired right up. Problem was traced to a loose connection on the fuel pump in the front trunk. |
| worn |
Jun 10 2019, 07:29 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,660 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
My question is, does anyone know what the problem is, I'd like to fix it before it fails completely!! Thanks This happened to me once (76 2.0). A couple of slow-downs, then a complete lack of power. Couldn't restart it, had it towed to the shop, whereby it immediately fired right up. Problem was traced to a loose connection on the fuel pump in the front trunk. Or it could be the condenser for the points or the points themselves... |
| Nie Zu Alt |
Jun 11 2019, 02:05 PM
Member ![]() ![]() Group: Members Posts: 173 Joined: 1-June 05 From: Centennial, CO Member No.: 4,184 Region Association: Rocky Mountains |
I had a similar problem on my '74 2 liter. Would run fine, then die completely and without any advance warning. Move the car, fiddle with the wires, it might or might not start back up. No consistent pattern. Turned out to be the wire to the Aux Air Regulator had a crack in the insulation and was causing a direct short against the case. I found it by looking at the engine in the dark and moving wires around. It was easy to see the sparking.
Good luck! Doug H. |
| IronHillRestorations |
Jun 11 2019, 07:16 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Check the obvious first.
Air; is there something restricting air flow, take the top off the air filter housing and give it a visual. Spark; you can get a cheap spark tester to plug inline that will let you know if you're getting fire. Fuel; this is more involved as the first thing I like to check is fuel pressure. Next thing I'd check is trigger points; whenever someone has FI problems I always say "trigger points". It's not always the case but you'd be surprised how often they are over looked, and they don't last forever. I don't remember the resistance test values, but I had a fellow teener passing through that died about 40 miles from here, and everything checked out until we got to the trigger points which were bad. I'm no FI guru, and was always intimidated by it (especially the AFC on my '74 1.8). Years ago one of the guys (James Thoruson) on the popular 914 website of the day started making FI testers. Ninefourtronics FI tester is what he called it, and that thing has saved me time and trouble. |
Lo-Fi Version | Time is now: 12th November 2026 - 12:27 PM |
